    Padrão Erro na migração squid
    Boa tarde, eu tinha um server rodando squid 2.6, troquei a maquina e instalei o squid 3, porem quando eu reinicio o squid esta apresentando seguinte erro
    luna:/var/log/squid3# squid3 -k reconfigure
    2009/03/24 08:50:48| cache_cf.cc(346) squid.conf:1 unrecognized: ']'
    ja viram isso no log consta a seguintes line
    2009/03/24 08:31:16| Reconfiguring Squid Cache (version 3.0.STABLE8)...
    2009/03/24 08:31:16| FD 11 Closing HTTP connection
    2009/03/24 08:31:16| FD 13 Closing ICP connection
    2009/03/24 08:31:16| Processing Configuration File: /etc/squid3/squid.conf (depth 0)
    2009/03/24 08:31:16| cache_cf.cc(346) squid.conf:1 unrecognized: ']'
    2009/03/24 08:31:16| Starting Authentication on port 0.0.0.0:34835
    2009/03/24 08:31:16| Disabling Authentication on port 0.0.0.0:34835 (interception enabled)
    2009/03/24 08:31:16| DNS Socket created at 0.0.0.0, port 1046, FD 10
    2009/03/24 08:31:16| Adding domain palei.net from /etc/resolv.conf
    2009/03/24 08:31:16| Adding nameserver 192.168.3.252 from /etc/resolv.conf
    2009/03/24 08:31:16| Accepting transparently proxied HTTP connections at 0.0.0.0, port 5000, FD 11.
    2009/03/24 08:31:16| Accepting ICP messages at 0.0.0.0, port 3130, FD 13.
    2009/03/24 08:31:16| HTCP Disabled.
    2009/03/24 08:31:16| Loaded Icons.
    2009/03/24 08:31:16| Ready to serve requests.
    Fala que esta ok mais não roda, achei uns artigos no google falando desse erro relacionando o transparent na porta ja coloquei tb e nada, grato.
    Ja resolvi este erro, tinha uma [ no arquivo de conf perdida, porem meu squid num navega,
    no firewall puis a seguinte regra
    iptables -t nat -A PREROUTING -s 192.168.3.0/24 -p tcp --dport 80 -j DNAT --to 192.168.3.252:5000
    5000 ta rodando o squid
    minhas acl estão assim
    acl localnet src 192.168.3.0/24 # RFC1918 possible internal network
    acl SSL_ports port 443
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 443 # https
    acl CONNECT method CONNECT
    http_access allow localnet
    http_access allow localhost
    no access.log tem isso
    1237900442.398 23674 192.168.3.41 TCP_MISS/000 0 GET http://www.uol.com.br/ - DIRECT/www.uol.com.br -
    1237900622.012 179614 192.168.3.41 TCP_MISS/504 2621 GET http://www.uol.com.br/ - DIRECT/200.221.2.45 text/html
    1237901280.007 179301 192.168.3.41 TCP_MISS/504 2633 GET http://www.google.com/ - DIRECT/64.233.163.104 text/html
    1237901578.001 179868 192.168.3.41 TCP_MISS/504 2532 GET http://www.terra.com.br/ - DIRECT/200.176.3.142 text/html
    1237901721.247 69751 192.168.3.41 TCP_MISS/000 0 GET http://www.uol.com.br/ - DIRECT/www.uol.com.br -
    1237901791.498 70248 192.168.3.41 TCP_MISS/000 0 GET http://www.uol.com.br/ - DIRECT/www.uol.com.br -
    1237901806.535 15036 192.168.3.41 TCP_MISS/000 0 GET http://www.google.com/ - DIRECT/www.google.com -
    1237901861.452 54915 192.168.3.41 TCP_MISS/000 0 GET http://www.dropsdeaniz.net/ - DIRECT/www.dropsdeaniz.net -
    1237901909.503 48049 192.168.3.41 TCP_MISS/000 0 GET https://under-linux.org/ - DIRECT/under-linux.org -
    Se eu tirar o prerouting navega fora do squid, funcinava no 2.4 agora paro alguem tem alguma dica ?
    Última edição por GuE; 24-03-2009 às 16:24.
    Citação Postado originalmente por GuE Ver Post
    1237900442.398 23674 192.168.3.41 TCP_MISS/000 0 GET UOL - O melhor conteúdo - DIRECT/www.uol.com.br -
    1237900622.012 179614 192.168.3.41 TCP_MISS/504 2621 GET UOL - O melhor conteúdo - DIRECT/200.221.2.45 text/html
    1237901280.007 179301 192.168.3.41 TCP_MISS/504 2633 GET Google - DIRECT/64.233.163.104 text/html
    1237901578.001 179868 192.168.3.41 TCP_MISS/504 2532 GET Terra - Notícias, vídeos, esportes, economia, diversão, música, moda, fotolog, blog, chat - DIRECT/200.176.3.142 text/html
    1237901721.247 69751 192.168.3.41 TCP_MISS/000 0 GET UOL - O melhor conteúdo - DIRECT/www.uol.com.br -
    1237901791.498 70248 192.168.3.41 TCP_MISS/000 0 GET UOL - O melhor conteúdo - DIRECT/www.uol.com.br -
    1237901806.535 15036 192.168.3.41 TCP_MISS/000 0 GET Google - DIRECT/www.google.com -
    1237901861.452 54915 192.168.3.41 TCP_MISS/000 0 GET Pousada.gif - DIRECT/www.dropsdeaniz.net -
    1237901909.503 48049 192.168.3.41 TCP_MISS/000 0 GET Under-Linux.Org O Portal do Administador de Sistemas - DIRECT/under-linux.org -
    Vou postar para vc um conf do squid3 básico:
    acl localhost src 127.0.0.1/32
    acl redelocal src 192.168.1.0/24
    http_access deny manager
    http_access deny !Safe_ports
    http_access allow redelocal
    http_access deny all
    icp_access deny all
    htcp_access deny all
    http_port 192.168.1.1:3128 transparent
    hierarchy_stoplist cgi-bin ?
    cache_mem 128 MB
    maximum_object_size_in_memory 64 KB
    memory_replacement_policy heap GDSF
    cache_replacement_policy heap LFUDA
    cache_dir aufs /var/spool/squid3/1 8192 16 256
    minimum_object_size 0 KB
    maximum_object_size 102400 KB
    cache_swap_low 90
    cache_swap_high 95
    access_log /var/log/squid3/access.log squid
    cache_log /var/log/squid3/cache.log
    cache_store_log none
    refresh_pattern (cgi-bin|\?) 0 0% 0
    refresh_pattern . 0 20% 4320
    ie_refresh on
    half_closed_clients off
    cache_mgr webmaster
    httpd_suppress_version_string on
    visible_hostname my_squid
    detect_broken_pconn on
    icp_port 0
    error_directory /usr/share/squid3/errors/Portuguese
    coredump_dir /var/spool/squid3
    Vc pode copiar e colar no seu squid.conf original, observer todas a linhas e repare nas que estao em vermelho, e mude conforme a sua rede.
    Quanto a opção cache_mem, tome cuidado para não prejudicar o seu server causando esgotamento de memoria e uso excessivo de swap, coloque para cache em memoria no squid até 25% da memoria total do se server ex:
    512MB RAM * 25% = 128MB RAM
    Nas configurações acima ele estrá trabalhando em modo transparente portanto será necessário redirecionarmos o tráfego web para a porta do squid;
    iptables -t nat -A PREROUTING -s 192.168.1.0/24 -p tcp --dport 80 -j REDIRECT --to-port 3128
    Coloque essa linha acima das regras de compartilhamento NAT ok
    Padrão Input tambem
    Precisa de regra de input
    iptables -A INPUT -p tcp -d iplocal --dport 5000 -m state --state NEW -j ACCEPT
    Abraço
    Citação Postado originalmente por wps Ver Post
    Abraço
    Olá!
    isso vai depender das políticas padrão do seu firewall (caso vc utilize um firewall estruturado), mas se vc usa um script simples onde o mesmo só compartilha o acesso para a rede local, e redireciona o tráfego para o squid, não há nescessidade de estabelecer nada para input.
    Meu firewall não é o servidor do squid, por isso tem o prerouting -dnat no ip dele, se estou correto se a maquina que roda squid não é o firewall o squid não pode ser transparent, so que outra coisa tenho um server dedicado apache mysql em uma outra maquina e tudo que chega na placa de rede wan na porta 80 ele joga na maquina do apache, meu firewall pode estar pegando os pacotes que estão na porta 80 e jogando pro apache ? segue firewall
    iptables -t nat -A PREROUTING -p tcp -s 192.168.3.0/24 --dport 80 -j DNAT --to 192.168.1.252:5000
    iptables -t nat -A PREROUTING -p tcp -i eth0 --dport 80 -j DNAT --to 192.168.3.253
    iptables -A INPUT -p tcp --dport 80 -j ACCEPT
    Help eu !!!
