Oi pessoal,
Estou com dificldade em colocar o bind 9.4 para trabalha com o logging no named.conf, alguem deste forum ja conseguiu que ele funcione?, segue minha configuracao do bind!, estou achando q e problema de permisao, isso e minha opniao, gostaria da ajuda de todos.
>names.conf
include "/etc/log.conf";
>/etc/log.conf
logging {
channel default_file { file "/var/log/named/default.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel general_file { file "/var/log/named/general.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel database_file { file "/var/log/named/database.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel security_file { file "/var/log/named/security.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel config_file { file "/var/log/named/config.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel resolver_file { file "/var/log/named/resolver.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel xfer-in_file { file "/var/log/named/xfer-in.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel xfer-out_file { file "/var/log/named/xfer-out.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel notify_file { file "/var/log/named/notify.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel client_file { file "/var/log/named/client.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel unmatched_file { file "/var/log/named/unmatched.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel queries_file { file "/var/log/named/queries.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel network_file { file "/var/log/named/network.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel update_file { file "/var/log/named/update.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel dispatch_file { file "/var/log/named/dispatch.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel dnssec_file { file "/var/log/named/dnssec.log" versions 3 size 5m; severity dynamic; print-time yes; };
channel lame-servers_file { file "/var/log/named/lame-servers.log" versions 3 size 5m; severity dynamic; print-time yes; };
category default { default_file; };
category general { general_file; };
category database { database_file; };
category security { security_file; };
category config { config_file; };
category resolver { resolver_file; };
category xfer-in { xfer-in_file; };
category xfer-out { xfer-out_file; };
category notify { notify_file; };
category client { client_file; };
category unmatched { unmatched_file; };
category queries { queries_file; };
category network { network_file; };
category update { update_file; };
category dispatch { dispatch_file; };
category dnssec { dnssec_file; };
category lame-servers { lame-servers_file; };
Obs. meu bind esta em chroot!!
Grato,
