Bom dia a todos,
Observando o post do Airking, obtive problemas ao finalizar as configurações do freeradius 1.1.7
Alguem poderia me ajudar?
Etapa da Instalação.
- Mysql Instalado!
- Freeradius Instalado! <Problema>
Efetuei todas as configurações nos arquivos.
radiusd.conf - Conforme o post do Airking
sql.conf - Configurações do Banco
clientes.conf - Conforme o post
proxy.conf - Conforme o post
Ao executar o comando para teste
radiusd -x
Observe o retorno.
Citação:
Starting - reading configuration files ...
Using deprecated naslist file. Support for this will go away soon.
Module: Loaded exec
rlm_exec: Wait=yes but no output defined. Did you mean output=none?
Module: Instantiated exec (exec)
Module: Loaded expr
Module: Instantiated expr (expr)
Module: Loaded PAP
Module: Instantiated pap (pap)
Module: Loaded CHAP
Module: Instantiated chap (chap)
Module: Loaded MS-CHAP
Module: Instantiated mschap (mschap)
Module: Loaded System
Module: Instantiated unix (unix)
Module: Loaded SQL
rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked
rlm_sql (sql): Attempting to connect to [email protected]:/phdimega
rlm_sql (sql): starting 0
rlm_sql (sql): Attempting to connect rlm_sql_mysql #0
rlm_sql_mysql: Starting connect to MySQL server for #0
rlm_sql (sql): Connected new DB handle, #0
rlm_sql (sql): starting 1
rlm_sql (sql): Attempting to connect rlm_sql_mysql #1
rlm_sql_mysql: Starting connect to MySQL server for #1
rlm_sql (sql): Connected new DB handle, #1
rlm_sql (sql): starting 2
rlm_sql (sql): Attempting to connect rlm_sql_mysql #2
rlm_sql_mysql: Starting connect to MySQL server for #2
rlm_sql (sql): Connected new DB handle, #2
rlm_sql (sql): starting 3
rlm_sql (sql): Attempting to connect rlm_sql_mysql #3
rlm_sql_mysql: Starting connect to MySQL server for #3
rlm_sql (sql): Connected new DB handle, #3
rlm_sql (sql): starting 4
rlm_sql (sql): Attempting to connect rlm_sql_mysql #4
rlm_sql_mysql: Starting connect to MySQL server for #4
rlm_sql (sql): Connected new DB handle, #4
Module: Instantiated sql (sql)
radiusd.conf: "SQL" modules aren't allowed in 'authenticate' sections -- they have no such method.
radiusd.conf[1907] Failed to parse authenticate section.
Hum dos problemas q eu constatei foi de q ele está buscando a senha ao invés do nome do banco.
'phdimega' foi senha que eu configurei no banco de dados.
Obs.
Sim, tenho 2 bancos criados.. o phdimega e o radius.
O sql.conf está sim com o nome phdimega, o q o freeradius está buscando.
