  1. Estou tentando configurar um load balance com 2 links há dias, mas não funciona de jeito nenhum.
    Todos navegam tranquilamente, uns pelo primeiro outros pelo segundo link. Acontece que o MK está dando prioridade para o primeiro link, ou seja, coloca muito mais clientes no primeiro.
    Agora mesmo tenho 21 o primeiro e 9 no outro. Quando no meu ponto de vista deveria ter 15 em cada já que os links são de velocidades iguais.
    Estou usando a versão 2.9.51
    Abaixo posto minhas regras:
    Código :
    add chain=prerouting action=mark-connection new-connection-mark=odd passthrough=yes connection-state=new src-address=100.100.9.0/24 src-address-list=link1 \
        comment="Clientes listados" disabled=no
    add chain=prerouting action=mark-routing new-routing-mark=odd passthrough=no connection-state=new src-address=100.100.9.0/24 connection-mark=odd comment="" \
        disabled=no
    add chain=prerouting action=mark-connection new-connection-mark=even passthrough=yes connection-state=new src-address=100.100.9.0/24 src-address-list=link2 \
        comment="" disabled=no
    add chain=prerouting action=mark-routing new-routing-mark=even passthrough=no connection-state=new src-address=100.100.9.0/24 connection-mark=even comment="" \
        disabled=no
    add chain=prerouting action=mark-connection new-connection-mark=odd passthrough=yes connection-state=new src-address=100.100.9.0/24 nth=1,1,0 \
        comment="Direciona clientes para cada link" disabled=no
    add chain=prerouting action=add-src-to-address-list src-address=100.100.9.0/24 connection-mark=odd address-list=link1 address-list-timeout=3h comment="" \
        disabled=no
    add chain=prerouting action=mark-routing new-routing-mark=odd passthrough=no src-address=100.100.9.0/24 connection-mark=odd comment="" disabled=no
    add chain=prerouting action=mark-connection new-connection-mark=even passthrough=yes connection-state=new src-address=100.100.9.0/24 nth=1,1,1 comment="" \
        disabled=no
    add chain=prerouting action=add-src-to-address-list src-address=100.100.9.0/24 connection-mark=even address-list=link2 address-list-timeout=3h comment="" \
        disabled=no
    add chain=prerouting action=mark-routing new-routing-mark=even passthrough=no src-address=100.100.9.0/24 connection-mark=even comment="" disabled=no
    Agradeço a quem puder ajudar.
  2. concordo plenamente!!
    1 simples clik tava massa!
  3. Então essas regras de load balance rolaram mo meu mikrotik, porém eu não consigo redirecionar o trafego da porta 80 para o meu squid. Como vcs fizeram isso? Tentei algumas regras e nada. Até marcar os pacotes e criar uma rota no ip route eu fiz e não rolou. Quem tá usando proxy transparente externo ao mikrotik está fazendo como?
    obrigado pela contribuição desse load balance.
  4. Citação Postado originalmente por jeanfrank Ver Post
    Bom dia a todos
    Testei vários balanceamentos e tive muitos problemas com msn, bancos conectividade social etc
    Então pesquisando implementei um load balance por nth + permanent conection e ficou muito bom, aqui estou utilizando 5 links de velocidade iguais e mesma operadora e detalhe os links tem que estar bons pra dar tudo certo no meu caso tenho 2 links locais na sede da empresa e 3 links remotos vindo de outras partes da cidade não entrarei em detalhes esta parte somente o balanceamento mas se alguem tiver duvida é só postar e ajudamos no que puder. Segue:
    Comece criando faixas de ip pras interfaces dos links no server mk tenho 7 interfaces lan;
    Minha interface que distribui o sinal chama-se clientes.
    ip/address list
    Link1 = 192.168.4.253/24
    Link2 = 192.168.2.253/24
    Link3 = 192.168.3.253/24
    Link4 = 192.168.1.253/24
    Link5 = 192.168.9.253/24
    Agora vamos criar 5 address list uma pra cada link
    ip/firewall/address list
    +/name:Link1 / 192.168.4.253/ok
    +/name:Link2 / 192.168.2.253/ok
    +/name:Link3 / 192.168.3.253/ok
    +/name:Link4 / 192.168.1.253/ok
    +/name:Link5 / 192.168.9.253/ok
    Continuando vamos criar todas as regras de mangle
    ip/firewall/mangle
    General#chain-prerouting/In. interface: Clientes#Advanced/Src. address list: Link1#Action/Action: mark connection/New connection mark:Link1/passthrough=yes
    General#chain-prerouting/In. interface: Clientes#Advanced/Src. address list: Link1#Action/Action: mark routing/New routing mark:Link1/passthrough=no
    General#chain-prerouting/In. interface: Clientes#Advanced/Src. address list: Link2#Action/Action: mark connection/New connection mark:Link2/passthrough=yes
    General#chain-prerouting/In. interface: Clientes#Advanced/Src. address list: Link2#Action/Action: mark routing/New routing mark:Link2/passthrough=no
    General#chain-prerouting/In. interface: Clientes#Advanced/Src. address list: Link3#Action/Action: mark connection/New connection mark:Link3/passthrough=yes
    General#chain-prerouting/In. interface: Clientes#Advanced/Src. address list: Link3#Action/Action: mark routing/New routing mark:Link3/passthrough=no
    General#chain-prerouting/In. interface: Clientes#Advanced/Src. address list: Link4#Action/Action: mark connection/New connection mark:Link4/passthrough=yes
    General#chain-prerouting/In. interface: Clientes#Advanced/Src. address list: Link4#Action/Action: mark routing/New routing mark:Link4/passthrough=no
    General#chain-prerouting/In. interface: Clientes#Advanced/Src. address list: Link5#Action/Action: mark connection/New connection mark:Link5/passthrough=yes
    General#chain-prerouting/In. interface: Clientes#Advanced/Src. address list: Link5#Action/Action: mark routing/New routing mark:Link5/passthrough=no
    General#chain-prerouting/In. interface: Clientes/Connection State: new#Extra: nth every=4, Counter=4, Packet=0/Action/Action: mark connection/New connection mark:Link1/passthrough=yes
    General#chain-prerouting/In. interface: Clientes/Connect mark:Link1#Action/Action: add src to address list/address list:Link1/timeout: 1d 00:00:00
    General#chain-prerouting/In. interface: Clientes/Connection mark: Link1#Action/Action: mark routing/New routing mark:Link1/passthrough=no
    General#chain-prerouting/In. interface: Clientes/Connection State: new#Extra: nth every=4, Counter=4, Packet=1/Action/Action: mark connection/New connection mark:Link2/passthrough=yes
    General#chain-prerouting/In. interface: Clientes/Connect mark:Link2#Action/Action: add src to address list/address list:Link2/timeout: 1d 00:00:00
    General#chain-prerouting/In. interface: Clientes/Connection mark: Link2#Action/Action: mark routing/New routing mark:Link2/passthrough=no
    General#chain-prerouting/In. interface: Clientes/Connection State: new#Extra: nth every=4, Counter=4, Packet=2/Action/Action: mark connection/New connection mark:Link3/passthrough=yes
    General#chain-prerouting/In. interface: Clientes/Connect mark:Link3#Action/Action: add src to address list/address list:Link3/timeout: 1d 00:00:00
    General#chain-prerouting/In. interface: Clientes/Connection mark: Link3#Action/Action: mark routing/New routing mark:Link3/passthrough=no
    General#chain-prerouting/In. interface: Clientes/Connection State: new#Extra: nth every=4, Counter=4, Packet=3/Action/Action: mark connection/New connection mark:Link4/passthrough=yes
    General#chain-prerouting/In. interface: Clientes/Connect mark:Link4#Action/Action: add src to address list/address list:Link4/timeout: 1d 00:00:00
    General#chain-prerouting/In. interface: Clientes/Connection mark: Link4#Action/Action: mark routing/New routing mark:Link4/passthrough=no
    General#chain-prerouting/In. interface: Clientes/Connection State: new#Extra: nth every=4, Counter=4, Packet=4/Action/Action: mark connection/New connection mark:Link5/passthrough=yes
    General#chain-prerouting/In. interface: Clientes/Connect mark:Link5#Action/Action: add src to address list/address list:Link5/timeout: 1d 00:00:00
    General#chain-prerouting/In. interface: Clientes/Connection mark: Link5#Action/Action: mark routing/New routing mark:Link5/passthrough=no
    Bom ufa...finalizado as regras de mangle vamos pra regras de nat...
    General#chain:srcnat/Connection mark: Link1#Action/Action: src-nat/to addresses:192.168.4.253/to ports: 0-65535
    General#chain:srcnat/Connection mark: Link2#Action/Action: src-nat/to addresses:192.168.2.253/to ports: 0-65535
    General#chain:srcnat/Connection mark: Link3#Action/Action: src-nat/to addresses:192.168.3.253/to ports: 0-65535
    General#chain:srcnat/Connection mark: Link4#Action/Action: src-nat/to addresses:192.168.1.253/to ports: 0-65535
    General#chain:srcnat/Connection mark: Link5#Action/Action: src-nat/to addresses:192.168.9.253/to ports: 0-65535
    Finalmente as regras de ip/route list...vamos lá
    Destination: 0.0.0.0/0
    gateway: 192.168.4.254
    Mark: Link1
    gateway: 192.168.2.254
    Mark: Link2
    gateway: 192.168.3.254
    Mark: Link3
    gateway: 192.168.1.254
    Mark: Link4
    gateway: 192.168.9.254
    Mark: Link5
    Este funciona como meu link principal
    Então pessoal é isto se esqueci de algo pode cobrar e espero que ajude vcs, por que batalhei bastante pra chegar a este cenário e quero deixar claro que não é o balanceamento difinitivo e tem seus pros e contras mas acredito que é um excelente começo pra quem quer balancear links sem ter problemas com bancos e msn, pra aqueles que utilizam hotspot como eu e utiliza o conectividade social tem outras regras complementares pra resolver o problema se alguem tiver duvida pode perguntar... e se ajudou alguem este post por favor agradeça... Pois é o meu salario rs rs rs rs rs....
    Abraços e até a proxima.
    Felicidades pra todos!!!!!!!!!!!!
    esse comando no meu nao rolou uso mk 3.x
  5. Citação Postado originalmente por lucianogf Ver Post
    vocẽ usou uma interface ethernet para cada link, por que não usou apenas uma para todos os links e um switch?
    O que voces dizem desta sujestão? Não parece mais simples? Funcionaria?
  1. Balanceamento Links Mesmo gateway
    Por felipezatta no fórum Redes
    Respostas: 5
    Último Post: 27-08-2011, 10:45
  2. Balanceamento link dedicado e adsl
    Por MaxAdriano no fórum Redes
    Respostas: 31
    Último Post: 01-09-2009, 22:30
  3. Load balance 2 links perfeito
    Por itnet no fórum Redes
    Respostas: 7
    Último Post: 07-09-2008, 23:06
  4. Respostas: 24
    Último Post: 23-10-2007, 14:04
  5. Balanceamento - Link dedicado e Adsl da BrT
    Por rfm no fórum Servidores de Rede
    Último Post: 23-10-2005, 21:58
