Bom dia, gosaria que os sabios amigos me auxiliasse na explicação de como resolver o problem que causa esse erro abaixo no Slackware quando tento autenticar nele em modo radius pelo mikrotik.
Sat May 16 23:35:27 2009 : Error: rlm_sql_mysql: MYSQL error:
Sat May 16 23:35:27 2009 : Info: rlm_sql_mysql: Starting connect to MySQL server for #1
Sat May 16 23:35:27 2009 : Error: rlm_sql (sql_logauth): failed after re-connect
Sat May 16 23:35:27 2009 : Info: rlm_sql (sql_default): No matching entry in the database for request from user [loja]
Sat May 16 23:35:27 2009 : Auth: Login incorrect (rlm_chap: Clear text password not available): [loja/<CHAP-Password>] (from client Global port 67 cli 00:163:F6:BB:BC)
Sat May 16 23:35:30 2009 : Error: rlm_sql_mysql: MYSQL Error: No Fields
Sat May 16 23:35:30 2009 : Error: rlm_sql_mysql: MYSQL error:
Sat May 16 23:35:30 2009 : Info: rlm_sql_mysql: Starting connect to MySQL server for #0
Sat May 16 23:35:30 2009 : Error: rlm_sql (sql_logauth): failed after re-connect
Sat May 16 23:35:30 2009 : Info: rlm_sql (sql_default): No matching entry in the database for request from user [loja]
Sat May 16 23:35:30 2009 : Auth: Login incorrect (rlm_chap: Clear text password not available): [loja/<CHAP-Password>] (from client Global port 68 cli 00:163:F6:BB:BC)
un May 17 11:12:57 2009 : Error: rlm_sql_mysql: MYSQL Error: No Fields
Sun May 17 11:12:57 2009 : Error: rlm_sql_mysql: MYSQL error:
Sun May 17 11:12:57 2009 : Info: rlm_sql_mysql: Starting connect to MySQL server for #0
Sun May 17 11:12:57 2009 : Error: rlm_sql (sql_logauth): failed after re-connect
Sun May 17 11:12:57 2009 : Auth: Login OK: [thiago/<CHAP-Password>] (from client 200.141.204.246 port 0)
Sun May 17 11:13:09 2009 : Error: Ignoring request from unknown client 200.141.204.245:33328
Sun May 17 11:13:21 2009 : Error: Ignoring request from unknown client 200.141.204.245:33366
De já muito grato pelas ajudas
3:F6:BB:BC)
Citação
