  1. Senhores.
    Estou tendo um erro no envio de e-mail pelo sendmail. Segue abaixo o log do meu erro.
    May 20 12:03:01 LvsCedro sendmail[3859]: n4KF31NW003859: to=root, delay=00:00:00, xdelay=00:00:00, mailer=local, pri=30000, dsn=2.0.0, stat=Sent
    May 20 12:03:02 LvsCedro sendmail[3855]: n4KF2DSO003853: to=<ulissesneto@gmail.com>, ctladdr=<apache@LvsCedro> (48/48), delay=00:00:44, xdelay=00:00:33, mailer=esmtp, pri=229422, relay=gmail-smtp-in.l.google.com. [72.14.247.27], dsn=5.0.0, stat=Service unavailable
    May 20 12:03:02 LvsCedro sendmail[3855]: n4KF2DSO003853: n4KF32SO003855: DSN: Service unavailable
    May 20 12:03:02 LvsCedro sendmail[3855]: n4KF32SO003855: to=root, delay=00:00:00, xdelay=00:00:00, mailer=local, pri=30000, dsn=2.0.0, stat=Sent
    Oque eu tenho que fazer para resolver esse problema.
    Obrigado
  2. você? nada.. o serviço está indisponível no destino. O usuário (ulissesneto@gmail.com) existe no destino?
    pode ser também algo momentâneo (serviço indisponivel), o google ultimamente anda meio atrapalhado.
  3. Citação Postado originalmente por irado Ver Post
    Segue abaixo o erro de log que estou tendo agora amigo
    May 20 15:41:06 LvsCedro sendmail[6450]: n4KIf60V006450: cedrofinances.com.br [127.0.0.1] did not issue MAIL/EXPN/VRFY/ETRN during connection to MTA
    May 20 15:41:06 LvsCedro sendmail[6451]: n4KIf6LU006451: from=apache, size=1332, class=-60, nrcpts=1, msgid=<rt-3.8.2-6337-1242844865-1591.47-3-0@cedrofinances.com.br>, relay=apache@localhost
    May 20 15:41:06 LvsCedro sendmail[6452]: n4KIf6xZ006452: from=<apache@cedrofinances.com.br>, size=1477, class=-60, nrcpts=1, msgid=<rt-3.8.2-6337-1242844865-1591.47-3-0@cedrofinances.com.br>, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 15:41:06 LvsCedro sendmail[6451]: n4KIf6LU006451: to=root@localhost, ctladdr=apache (48/48), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=139332, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n4KIf6xZ006452 Message accepted for delivery)
    May 20 15:41:06 LvsCedro sendmail[6453]: n4KIf6xZ006452: to=<root@cedrofinances.com.br>, ctladdr=<apache@cedrofinances.com.br> (48/48), delay=00:00:00, xdelay=00:00:00, mailer=local, pri=139697, dsn=2.0.0, stat=Sent
    May 20 15:41:06 LvsCedro sendmail[6455]: n4KIf6PZ006455: from=apache, size=989, class=-60, nrcpts=1, msgid=<rt-3.8.2-6337-1242844865-434.47-4-0@cedrofinances.com.br>, relay=apache@localhost
    May 20 15:41:06 LvsCedro sendmail[6456]: n4KIf6vx006456: <ulisses.neto@cedrofinances.com.br>... User unknown
    May 20 15:41:06 LvsCedro sendmail[6455]: n4KIf6PZ006455: to=ulisses.neto@cedrofinances.com.br, ctladdr=apache (48/48), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=138989, relay=[127.0.0.1] [127.0.0.1], dsn=5.1.1, stat=User unknown
    May 20 15:41:06 LvsCedro sendmail[6456]: n4KIf6vx006456: from=<apache@cedrofinances.com.br>, size=989, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 15:41:06 LvsCedro sendmail[6455]: n4KIf6PZ006455: n4KIf6Pa006455: DSN: User unknown
    May 20 15:41:06 LvsCedro sendmail[6456]: n4KIf6w1006456: from=<>, size=2634, class=0, nrcpts=1, msgid=<200905201841.n4KIf6Pa006455@cedrofinances.com.br>, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 15:41:07 LvsCedro sendmail[6455]: n4KIf6Pa006455: to=apache, delay=00:00:01, xdelay=00:00:01, mailer=relay, pri=30000, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n4KIf6w1006456 Message accepted for delivery)
    May 20 15:41:07 LvsCedro sendmail[6457]: n4KIf6w1006456: to=root, delay=00:00:01, xdelay=00:00:00, mailer=local, pri=32850, dsn=2.0.0, stat=Sent
    You have new mail in /var/spool/mail/root
    Não sei como resolver isso
    Obrigado pela ajuda
  4. bem.. eu já não uso o sendmail há uns 5 anos, mas enfim..
    vamos à miuda:
    <ulisses.neto@cedrofinances.com.br> ... User unknown
    diz que o tal ulisses neto não existe aí na cedrofinances.com.br; nada demais, se o cara realmente não existe
    apache@cedrofinances.com.br está tentando envia essa msg --> talvez vc tenha algum aplicativo no seu apache enviando algo para o tal de ulisses, que (tudo indica) não existe.
    /intervalinho
    se quiser, eventualmente vc cria um aliases pra essa criatura, apontando pra seu próprio zémail (o mais simples, mas ERRADO).
    /end intervalinho
    após isso o MTA desiste de entregar a msg e manda msg de êrro pro root:
    agora ficou mais simples: vc usa o mutt, simplesmente:
    # mutt
    ou vc pode (se quiser) usar o less:
    # less /var/spool/mail/root
    mas é chato pra kct.
    como (acho) vc nunca o usou, devem haver uns trilhões de mensagens lá dentro.
  5. Ainda continuo tendo erro
    Eu não sei oque fazer mais para isso dar certo
    May 20 18:46:58 LvsCedro sendmail[7302]: n4KLkwjs007302: from=apache, size=1332, class=-60, nrcpts=1, msgid=<rt-3.8.2-7217-1242856018-1100.59-3-0@cedrofinances.com.br>, relay=apache@localhost
    May 20 18:46:58 LvsCedro sendmail[7303]: n4KLkwZt007303: SYSERR(root): rewrite: excessive recursion (max 50), ruleset canonify
    May 20 18:46:58 LvsCedro sendmail[7302]: n4KLkwjs007302: to=root@localhost, ctladdr=apache (48/48), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=139332, relay=[127.0.0.1] [127.0.0.1], dsn=5.0.0, stat=Service unavailable
    May 20 18:46:58 LvsCedro sendmail[7302]: n4KLkwjs007302: n4KLkwjt007302: DSN: Service unavailable
    May 20 18:46:58 LvsCedro sendmail[7303]: n4KLkwZu007303: SYSERR(root): rewrite: excessive recursion (max 50), ruleset canonify
    May 20 18:46:58 LvsCedro sendmail[7302]: n4KLkwjt007302: to=apache, delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30000, relay=[127.0.0.1], dsn=5.0.0, stat=Service unavailable
    May 20 18:46:58 LvsCedro sendmail[7303]: n4KLkwZu007303: from=<>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 18:46:58 LvsCedro sendmail[7302]: n4KLkwjt007302: n4KLkwju007302: return to sender: Service unavailable
    May 20 18:46:58 LvsCedro sendmail[7303]: n4KLkwZw007303: from=<>, size=2313, class=0, nrcpts=1, msgid=<200905202146.n4KLkwju007302@cedrofinances.com.br>, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 18:46:59 LvsCedro sendmail[7302]: n4KLkwju007302: to=postmaster, delay=00:00:01, xdelay=00:00:01, mailer=relay, pri=30000, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n4KLkwZw007303 Message accepted for delivery)
    May 20 18:46:59 LvsCedro sendmail[7304]: n4KLkwZw007303: to=root, delay=00:00:01, xdelay=00:00:00, mailer=local, pri=32533, dsn=2.0.0, stat=Sent
    May 20 18:46:59 LvsCedro sendmail[7305]: n4KLkxb4007305: from=apache, size=990, class=-60, nrcpts=1, msgid=<rt-3.8.2-7217-1242856018-1552.59-4-0@cedrofinances.com.br>, relay=apache@localhost
    May 20 18:46:59 LvsCedro sendmail[7307]: n4KLkxC2007307: SYSERR(root): rewrite: excessive recursion (max 50), ruleset canonify
    May 20 18:46:59 LvsCedro sendmail[7305]: n4KLkxb4007305: to=ulisses.neto@cedrofinances.com.br, ctladdr=apache (48/48), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=138990, relay=[127.0.0.1] [127.0.0.1], dsn=5.0.0, stat=Service unavailable
    May 20 18:46:59 LvsCedro sendmail[7305]: n4KLkxb4007305: n4KLkxb5007305: DSN: Service unavailable
    May 20 18:46:59 LvsCedro sendmail[7307]: n4KLkxC3007307: SYSERR(root): rewrite: excessive recursion (max 50), ruleset canonify
    May 20 18:46:59 LvsCedro sendmail[7305]: n4KLkxb5007305: to=apache, delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30000, relay=[127.0.0.1], dsn=5.0.0, stat=Service unavailable
    May 20 18:46:59 LvsCedro sendmail[7307]: n4KLkxC3007307: from=<>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 18:46:59 LvsCedro sendmail[7305]: n4KLkxb5007305: n4KLkxb6007305: return to sender: Service unavailable
    May 20 18:46:59 LvsCedro sendmail[7307]: n4KLkxC5007307: from=<>, size=2313, class=0, nrcpts=1, msgid=<200905202146.n4KLkxb6007305@cedrofinances.com.br>, proto=ESMTP, daemon=MTA, relay=cedrofinances.com.br [127.0.0.1]
    May 20 18:46:59 LvsCedro sendmail[7305]: n4KLkxb6007305: to=postmaster, delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30000, relay=[127.0.0.1] [127.0.0.1], dsn=2.0.0, stat=Sent (n4KLkxC5007307 Message accepted for delivery)
    May 20 18:46:59 LvsCedro sendmail[7308]: n4KLkxC5007307: to=root, delay=00:00:00, xdelay=00:00:00, mailer=local, pri=32533, dsn=2.0.0, stat=Sent
  1. Sendmail + Pine
    Último Post: 05-08-2002, 07:32
  2. migração do exchange para o sendmail
    Por fabiopodium no fórum Servidores de Rede
    Último Post: 02-08-2002, 09:21
  3. Sendmail X Spam como fazer para não entrar
    Último Post: 10-06-2002, 09:08
  4. Spam no sendmail tem como?
    Último Post: 10-06-2002, 09:07
  5. Sendmail - Eviar e-mail para dominio local e remoto com mesm
    Por jrmami no fórum Servidores de Rede
    Último Post: 31-05-2002, 21:40
