    Moderador Avatar de Magal
    Mar 2007
    Rio de Janeiro
    Padrão Saiu a versão 3.24 do MK
    Saiu a versão 3.24 do Mikrotik
    http://www.mikrotik.com/download.html
    What's new in 3.24:
    *) added ability to run non RouterOS in MetaROUTER;
    *) improved address-list and layer7 firewall feature support for smp systems;
    *) special-login items can now be disabled;
    *) fixed special-login to update used-by property of port;
    *) fixed USB UPS monitoring on RB433UAH;
    *) console - 'print' command reuses assigned item numbers;
    *) fixed issue with Cisco BGP VPLS when used between 2 RouterOS devices;
    *) console - 'print' commands have new option 'follow-only' that continuously
    shows changes like the 'follow' option, but does not print all items
    at the beginning;
    *) api - 'follow' and 'follow-only' options of 'print' commands now work,
    '.dead' property is reported for deleted items;
    *) api - 'listen' command now is alias for 'print' with 'follow-only'
    opriont set;
    *) api - several commands running in parallel could produce intermixed
    output, fixed;
    *) console and api - fixed problem that caused property values sometimes to
    incorrectly have value '(unknown)', this could happen when running
    several console or api commands at once;
    *) fixed BGP VPLS crash when site-id > 15 used somewhere in network;
    *) changed BGP AS path number output format to ASPLAIN;
    *) console - new scheduler tasks use trimmed effective user permissions as the
    default value of policy, previously default value was "read,write,test";
    *) added ttl matcher to ipv4 firewall;
    *) improved dns cache not to allow other RRs in statically configured domains;
    *) fixed vlan on bonding;
    *) fixed bonding modes balance-alb and balance-tlb;
    *) added per-connection-classifier matcher to firewall;
    *) fixed wireless Hw. Fragmentation Threshold in WinBox;
    *) user manager - added option to specify custom Return URL
    for Authorize.Net payments;
    *) user manager - write logs to syslog topic manager,account;
    *) routing-test - support for per-VRF BGP instance redistribute settings;
    *) routing-test - speed up BGP route processing;
    *) routing-test - added routing-table configuration to RIP;
    E vamos ao teste pra ver o q ajeitarao...
    qual quer novidade deixo noticias a q vlw
    Eu so maniaco mesmo.. acabei de atualizar tudo uaeahea
    tudo normal..
    abraços
    Citação Postado originalmente por alamdias Ver Post
    tudo normal..
    abraços
    é 2 amigo entro todu dia na site da mikrotik.com pra ver se ja tem atualização..
    kkkkkkkk e saindo novidade ja baixo e atualizo os 2 MK kk...
    vc ja viu alguma diferença alguma melhora?????
    Eu atualizei o meu PC-AP, mais alguns scripts pararam de funcionar como o do Ack timeout e a navegação ficou mais lenta, talvez seja o web proxy, mais resolvi voltar.
