    Padrão Preciso de Ajuda com Freeradius 2.x e Ubuntu 8.10 ou 9.04
    Este já é o 3º topico que coloco pois ninguem quer me ajudar...sei que tem gente muito mais capacitada do que eu neste forum...
    sei que algumas pessoas já passaram por esse problema, quero saber como resolver....
    o Processo é: freeradius 2.x.x e mikrotik hotspot??? como fazer ???
    pq mesmo instalando o freeradius do repositorio com um apt-get install freeradius-mysql, mas logo
    apos a instalação se der um "freeradius -X" da este erro:
    Failed binding to socket: Address already in use
    /etc/freeradius/radiusd.conf[235]: Error binding to port for 0.0.0.0 port 1812
    esse mesmo erro da no ubuntu 8.10 , 9.04 e debian 5...
    se vc ir no radiusd.conf e descomentar user e group e der novamente um "freeradius -X"
    ele da assim : Mas mesmo assim não funciona .
    root@provebuntu:~# freeradius -X
    FreeRADIUS Version 2.1.0, for host i486-pc-linux-gnu, built on Apr 30 2009 at 07:22:56
    Copyright (C) 1999-2008 The FreeRADIUS server project and contributors.
    There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
    PARTICULAR PURPOSE.
    You may redistribute copies of FreeRADIUS under the terms of the
    GNU General Public License v2.
    Starting - reading configuration files ...
    including configuration file /etc/freeradius/radiusd.conf
    including configuration file /etc/freeradius/proxy.conf
    including configuration file /etc/freeradius/clients.conf
    including files in directory /etc/freeradius/modules/
    including configuration file /etc/freeradius/modules/mschap
    including configuration file /etc/freeradius/modules/realm
    including configuration file /etc/freeradius/modules/pap
    including configuration file /etc/freeradius/modules/files
    including configuration file /etc/freeradius/modules/sradutmp
    including configuration file /etc/freeradius/modules/attr_rewrite
    including configuration file /etc/freeradius/modules/expr
    including configuration file /etc/freeradius/modules/preprocess
    including configuration file /etc/freeradius/modules/ippool
    including configuration file /etc/freeradius/modules/radutmp
    including configuration file /etc/freeradius/modules/mac2vlan
    including configuration file /etc/freeradius/modules/always
    including configuration file /etc/freeradius/modules/sql_log
    including configuration file /etc/freeradius/modules/inner-eap
    including configuration file /etc/freeradius/modules/smbpasswd
    including configuration file /etc/freeradius/modules/policy
    including configuration file /etc/freeradius/modules/digest
    including configuration file /etc/freeradius/modules/exec
    including configuration file /etc/freeradius/modules/passwd
    including configuration file /etc/freeradius/modules/acct_unique
    including configuration file /etc/freeradius/modules/attr_filter
    including configuration file /etc/freeradius/modules/pam
    including configuration file /etc/freeradius/modules/mac2ip
    including configuration file /etc/freeradius/modules/checkval
    including configuration file /etc/freeradius/modules/linelog
    including configuration file /etc/freeradius/modules/detail
    including configuration file /etc/freeradius/modules/etc_group
    including configuration file /etc/freeradius/modules/logintime
    including configuration file /etc/freeradius/modules/unix
    including configuration file /etc/freeradius/modules/counter
    including configuration file /etc/freeradius/modules/ldap
    including configuration file /etc/freeradius/modules/expiration
    including configuration file /etc/freeradius/modules/detail.example.com
    including configuration file /etc/freeradius/modules/krb5
    including configuration file /etc/freeradius/modules/echo
    including configuration file /etc/freeradius/modules/detail.log
    including configuration file /etc/freeradius/modules/chap
    including configuration file /etc/freeradius/modules/wimax
    including configuration file /etc/freeradius/eap.conf
    including configuration file /etc/freeradius/sql.conf
    including configuration file /etc/freeradius/sql/mysql/dialup.conf
    including configuration file /etc/freeradius/sql/mysql/counter.conf
    including configuration file /etc/freeradius/policy.conf
    including files in directory /etc/freeradius/sites-enabled/
    including configuration file /etc/freeradius/sites-enabled/default
    including configuration file /etc/freeradius/sites-enabled/inner-tunnel
    group = radius
    freeradius: Cannot get ID for group radius: Success
    root@provebuntu:~#
    por isso peço encarecidamente a ajuda de alguem, pois so falta isso pra eu poder tocar meu projetinho.." POR FAVOR ALGUEM, SERGIO, ALEXANDRE CORREA...ALGUEM..QUALQUER UM"
    Padrão radius
    Ola,
    Nao sei dizer se no Ubuntu 9.04 foi corrigido o script de inicializacao do freeradius, mas o problema no 8.10 era que o diretorio no /var/run aponta para um nome o no /etc/freeradius/radius.conf ou /etc/init.d/freeradius para outro. Tipo: /var/run/radius e no conf: /var/run/freeradius
    Tem um detalhe a mais, na versao 2.x o freeradius tem um formato de propriedade diferente da versao 1.x, isto pode trazer problemas. Na versao 1.x as propriedades comecam com a primeira letra maiscula o resto minuscula, na versao 2.x nao sei dizer se faz distincao de maiuscula para minuscula. Entao tem que ver como o mikrotik faz a chamada para ver qual melhor versao do freeradius se aplica.
    Tive algo parecido com meu hotspot, acabei compilando a versao 1.1.7 do freeradius uma vez, e outra vez usei o ubuntu 8.04 que nao tem este problema.
    amaia filho de deus....
    primeiramente muito obrigado...
    eu tbm uso o ubuntu 8.04 com freeradius 1.1.7 dos repositorio e esse funciona perfeitamente com o mk....
    mas queria usar uma versão mais nova do freeradius.. endende....outra coisa no ubuntu 8.10 ja esta ok ?????
    Padrão freeradius 2.x ubuntu 8.10
    ok esta, mas precisa verificar a correcao no radiusd.conf ou /etc/init.d/freeradius
    Citação Postado originalmente por amaia Ver Post
    vc poderia por gentileza me dizer oq devo olhar nesses dois arquivos ??? o que devo alterar
    lembrado q to com ubuntu 8.10 e freeradius dos respositorio usando sql
    Padrão radiusd.conf
    No /etc/freeradius/radiusd.conf tem que ter a seguinte opcao:
    run_dir = /var/run/freeradius
    Resolvi isso mudando as portas para 1919 e 1920
    e setei também o ip que responde pelo radius
    e deu certo, tenta fazer isso e depois poste aqui
    se seu certo, estou usando Ubuntu Server 9.04
    Michel vou colocar aki e te falo...muito obrigado..de coração mesmo..toda ajuda é bem vinda
    vc sabe se a mesma tabela que eu usava no freeradius 1.1.7 funciona no 2.0 ????
    Citação Postado originalmente por muriloc4 Ver Post
    Então Muriloc, essa informação eu já não sei lhe dizer, mas creio que funciona sim!
    Padrão não deu certo
    Caro amigo Michel
    Fiz o que mandou coloquei as portas 1919 no lugar de 1812 e (type=auth)e 1920 no lugar de 1813 (type=acct)...da o mesmo erro quando do um "freeradius -X , apos reiniciar o freeradius:
    radiusd: #### Opening IP addresses and Ports ####
    listen {
    type = "auth"
    ipaddr = 202.210.205.153
    port = 1919
    /etc/freeradius/radiusd.conf[235]: Error binding to port for 202.210.205.153 port 1919
    tem fui em user e group e descomentei... tava freerad.. coloquei até root e root..
    mas da a mesma coisa....
    to usando ubuntu 9.04 desktop..
    freeradius dos repositorios
    sei que é chato...mas me ajuda....
    Última edição por muriloc4; 02-06-2009 às 12:14. Razão: esqueci uma coisa
    Tenta instalar pelos fontes do freeradius, o pacote que está nos repositórios (pelo menos do debian 5 que eu testei) não fiz funcionar tb, o jeito foi ir no site e pegar o fonte e instalar na "unha seca" mesmo, a respeito da tabelas me parece nao ter diferenças não...
    Caro amigo Michel
    listen {
    type = "auth"
    port = 1919
    Olha só, para a minha surpresa, a mudança de portas resolve de forma parcial só fui perceber agora a pouco, porque o meu deu um problema ai fiz novamente a mudança de portas e novamente funcionou, porém depois de algum tempo parou novamente então tentei matar o radius e ele não aceitou, então depois de restartar o server com a porta mudada novamente acabou funcionando, isso é algum BUG na versão!
    Pode fazer o teste sem restartar o radius, logo depois que vc mudar dê um freeradius -X e observe
    Module: Checking preacct {...} for more modules to load
    Module: Linked to module rlm_acct_unique
    Module: Instantiating acct_unique
    acct_unique {
    key = "User-Name, Acct-Session-Id, NAS-IP-Address, Client-IP-Address, NAS-Port"
    Module: Checking accounting {...} for more modules to load
    Module: Linked to module rlm_detail
    Module: Instantiating detail
    detail {
    detailfile = "/var/log/freeradius/radacct/%{Client-IP-Address}/detail-%Y%m%d"
    header = "%t"
    detailperm = 384
    dirperm = 493
    locking = no
    log_packet_header = no
    Module: Instantiating attr_filter.accounting_response
    attr_filter attr_filter.accounting_response {
    attrsfile = "/etc/freeradius/attrs.accounting_response"
    key = "%{User-Name}"
    Module: Checking session {...} for more modules to load
    Module: Checking post-proxy {...} for more modules to load
    Module: Checking post-auth {...} for more modules to load
    listen {
    type = "auth"
    ipaddr = xxx.xxx.xxx.xx
    port = 18123
    listen {
    type = "acct"
    port = 18133
    Listening on authentication interface eth1 address xxx.xxx.xxx.xx port 18123
    Listening on accounting interface eth1 address xxx.xxx.xxx.xx port 18133
    Ready to process requests.
    Veja que ele está aguardando conexões, mas depois de algum tempo do nada ele para novamente fiz vários testes e cheguei a essa conclusão, vou instalar ele na mão pra ver no que vai dar!
    Última edição por Michael; 02-06-2009 às 14:58.
    Michel instalei , na unha como manda o FreeRADIUS: The world's most popular RADIUS Server com fakeroot ...
    é aquilo q falou se vc mudar as portas mas não reiniciar, ele funciona..mas se vc restarta o freeradius ele da o erro..
    sei que o sergio ou alexandre correa sabem (eles sabem de tudo) mas não sei oque fiz pra eles não responderem esse topico...
    "SERGIO MESTRE YODA DO LINUX ME AJUDA"
    Talking
    Este erro de conexão (Error binding to port for) ocorre quando o freeradius já foi startado, mesmo você dando um stop nele, a porta e o ip vai continuar em uso pelo freeradius, ai logico que o freeradius vai dizer que a porta está em uso... ,porém o freeradius mesmo com a msn de erro funciona normalmente, de uma olhada no seu log de acesso.
    Padrão freeradius
    Murilo, coloquei para funcionar usando o Ubuntu 9.04, com os pacotes freeradius e freeradius-mysql sem problemas. O bug de inicializacao que existia no 8.10 nao existe no 9.04, mas para conectar com o usuario para fazer teste, tem diferenca, enquanto no 1.x a propriedade eh Password, no 2.x eh User-Passowrd.
    Outra observacao, vc quer colocar para funcionar com o mysql ou a autenticacao eh via arquivo ????
    caro amaia
    quero usar mysql, pois tenho uns tres front-end em php aqui..
    agora esse lance do password eu não sabia
    posso te passar um front-end q uso aqui.
    e vc analiza..
    qualquer coisa me manda um e-mail
    [email protected]
    vou olhar aqui
    To colocando aqui numa maquina de teste tb 9.04 pelo apt-get, mas tah dificil de nasce
    se quise troca ideia
    MSN [email protected]
    já tá rodando o freeradius, mas ele tah pegando os login e senha do linux e não do sql
    Padrão FreeRadius versão 2.xx
    Pessoal finalmente depois de ler "quase" Todos os Forums atrás da solução deste problema, achei a solução
    lendo a documentação do proprio freeradius em /usr/share/doc/freeradius.
    Existem algums arquivos extras que a versão 2.xx nos traz,
    o arquivo que precisa ser editado para a resolução deste problema é o seguinte:
    Edite o mesmo como se estivesse editando o radius.conf, ( as opções sobre a escolha da base de autenticação ).
    Obtive Sucesso.
    Qualquer Duvida estou a disposição.
    Última edição por leandropds; 16-08-2009 às 23:56. Razão: ficou com informação errada
    Citação Postado originalmente por leandropds Ver Post
    Obtive Sucesso.
    vou testar aqui...e depois posto o resultado mas vc usou o sql ??
    Última edição por muriloc4; 17-08-2009 às 03:17.
