    Padrão Squid debian 5 leny
    Ola pessoal e o seguinte eu tenho um server debian em paralelo ao mikrotik so que eu tou achando que as requisiçoes estao mais lentas do que a do proprio web proxy do mikrotik vou postar minhas configs pra vcs verem se a algo errado eu ja instalei o debian justamente por ouvir dizer ser bem melhor que o web prxy podem palpitar a vontade
    http_port 1106 transparent
    #icp_port 3130
    visible_hostname Satellite and Terrestrial RF Spectrum Monitoring, Interference Detection Systems
    cache_mgr sat.com
    cache_mem 16 MB
    maximum_object_size_in_memory 32 KB
    maximum_object_size 25 MB
    minimum_object_size 0 KB
    cache_swap_low 90
    cache_swap_high 95
    dns_nameservers 200.223.0.84 200.223.23.159
    cache_dir diskd /var/spool/squid/01 5000 1 1 Q1=64 Q2=72
    cache_dir diskd /var/spool/squid/02 5000 1 1 Q1=64 Q2=72
    cache_dir diskd /var/spool/squid/03 5000 1 1 Q1=64 Q2=72
    cache_dir diskd /var/spool/squid/04 5000 1 1 Q1=64 Q2=72
    cache_dir diskd /var/spool/squid/05 5000 1 1 Q1=64 Q2=72
    access_log /var/log/squid/access.log
    hierarchy_stoplist cgi-bin ?
    refresh_pattern -i (/cgi-bin/|\?) 0 0% 0
    #refresh_pattern (Release|Package(.gz)*)$ 0 20% 2880
    refresh_pattern . 0 20% 4320
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    # SEM CACHE
    acl NOCACHE url_regex localhost 192.0.0.0/8
    no_cache deny NOCACHE
    #Mantendo objetos recentes e pequenos na memoria
    memory_replacement_policy heap GDSF
    cache_replacement_policy heap LFUDA
    # Encerrando requisiçoes dos clientes
    half_closed_clients off
    #Publicidade Orkut
    acl ork.users url_regex ork.users
    http_access deny ork.users
    deny_info http://www.portalvelhochico.com/bann...up_250x250.gif ork.users
    acl ADSAdClient url_regex ADSAdClient31.dll
    http_access deny ADSAdClient
    deny_info http://www.portalvelhochico.com/banner/bottom2.gif ADSAdClient
    # MARCAR PACOTES TOS
    zph_mode tos
    zph_local 0x30
    zph_parent 0
    zph_option 136
    #http_access allow all
    # CLASSE DOS CLIENTES
    acl mikrotik src 192.168.10.0/24 192.168.83.0/24 192.168.80.0/24 192.168.61.0/24 192.168.70.0/24 192.168.60.0/24 192.168.50.0/24 192.168.40.0/24 192.168.30.0/24 192.168.20.0/24
    http_access allow mikrotik
    http_access allow localhost
    # BLOQUEIA O RESTO
    http_access deny all
    [QUOTE=gigagere;417129]
    Caro colega, notei isso aqui tambem, usando a mesma versão do debian que você, Usnado proxy paralelo com web proxy do mikrotik,
    O webproxy realmente notamos que fica mais rápido.
    Esta lentidão, acredito estar ocorrendo por causa do dns.
    Eu usei o dns bind9 no debian e os dns da operadora no mikrotik.
    Agora tambem fiquei na duvida que:
    Router dns Operadora: debian, bind9 + dns da operadoras+mikrotik pppoe dns da operadora.
    Agora vem a questão:
    Usar o dns do debian no mikrotik ou usar o dns da operadora. Aqui ficou legal até os 100gb de cache em hd, depois disso notei uma certa lentidão também.
    Não Registrado
    [quote=wimigasltda;417336]
    Citação Postado originalmente por gigagere Ver Post
    so um detalhe eu nao uso em parent proxy eu uso em paralelo mais com marcaçao tos no mikrotik quando usei em parent ficou pior que discada atualmente o problema e que o web proxy tem alguns milesimos de segundo de tenpo a menos que o squid do debian
    amigo 1 obs vc usar a range mikrotik 192.168.x.x notei q sua mak esta 24..
    pq nao usa 192.168.0.0/16
    estou usando aki o squid fiz com thunder .. zph.. estamos gostando dos resultados..
    logico q nao jogamos tada por 80.. direcionamos somente alguns servicos como orkut.. terra uol etc site mais visitados..
    colega so um ajudinha altere seu squid.conf
    cache_mem 16 MB para
    cache_mem 256MB
    maximum_object_size_in_memory 32 KB para
    maximum_object_size_in_memory 1024 KB
    maximum_object_size 25 MB para
    maximum_object_size 680 MB
    depois altere a marcao de pacotes
    zph_local 0x30
    para
    zph_local 0x10 e nao esqueção de altrar em seu MK
    a marcação com TOS 0x30 nao funciona dirreito e squid em paralelo
    dai vai ficar 100%
