    Padrão Bloquear o msn e liberar o email do hotmail
    E o seguinte aqui na empresa nao tenho o firewall rodando ainda, estou apenas com o squid, estou bloqueando tudo pelo squid, estou bloqueando o msn (messenger) mas quando eu bloqueio ele o hotmail e automaticamente bloqueado tambem, descobri que o que estava bloqueando e a login.live.com, preciso bloquear o msn e liberar o email hotmail?
    grato
    o script do squid esta ai:
    # WELCOME TO SQUID 3.0.STABLE10
    ################# Autenticação de Usuários ##########################
    #auth_param basic program <uncomment and complete this line>
    #auth_param basic children 5
    #auth_param basic realm Squid proxy-caching web server
    #auth_param basic credentialsttl 2 hours
    #acl password proxy_auth REQUIRED//Qdo for usar a autent. descomentar
    acl localhost src 127.0.0.1/32
    #acl localnet src 10.0.0.0/8 # RFC1918 possible internal network
    #acl localnet src 172.16.0.0/12 # RFC1918 possible internal network
    acl redetoctao src 192.168.0.0/24 # RFC1918 possible internal network
    ##################### Regras ########################################
    acl Safe_ports port 20 # programa oi
    acl SSL_ports port 443 563 # https
    acl Safe_ports port 553 # Autenticacao do outlook
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 89 # juridico 2ccago
    acl IPliberados src "/etc/squid/regras/IPliberado.txt"
    acl libera-msn src "/etc/squid/regras/libera-msn.txt"
    acl bloqueados url_regex -i "/etc/squid/regras/bloqueados.txt"
    acl ultrasurf dstdom_regex -i ([0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}($|:.+|/))
    acl msn url_regex -i gateway.dll
    acl msn_bloq dstdomain "/etc/squid/regras/msn_bloq.txt"
    acl msn1 url_regex passport.com confi.messenger.msn.com
    acl msn2 req_mime_type ^application/x-msn-messenger$
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny !Safe_ports
    ####################### Permisões das Regras ########################
    http_access allow IPliberados
    http_access deny bloqueados
    http_access deny CONNECT ultrasurf
    http_access allow libera-msn
    http_access deny msn !libera-msn
    http_access deny msn_bloq !libera-msn
    http_access deny msn1 !libera-msn
    http_access deny msn2 !libera-msn
    http_access allow redetoctao
    http_access allow localhost
    http_access deny all
    icp_access allow redetoctao
    icp_access deny all
    htcp_access allow redetoctao
    htcp_access deny all
    ############### Endereço do Servidor e Porta para Acesso############
    http_port 192.168.0.204:3128
    hierarchy_stoplist cgi-bin ?
    ######################## Tamanhos das Cache ########################
    cache_dir ufs /var/cache/squid 500 16 256
    cache_swap_low 90
    cache_swap_high 95
    ########################### Caminhos dos Logs ######################
    access_log /var/log/squid/access.log squid
    cache_log /var/log/squid/cache.log
    cache_store_log /var/log/squid/store.log
    #######################Controle de Acessos #########################
    refresh_pattern (cgi-bin|\?) 0 0% 0
    refresh_pattern . 0 20% 4320
    icp_port 3230
    coredump_dir /var/cache/squid
    Amigo usa o msn-proxy excelente para essa solução
    Nunca usei o msn-Proxy. Alguem poderia me ajudar com a configuraçao do msn-proxy e o me explicar para que server este serviço em detalhes?
    Citação Postado originalmente por andrecharamos Ver Post
    Procura no meu blog
