    Angry Páginas do Google e Orkut com dificudade para autenticar.
    OLÁ PESSOAL,BOM DIA A TODOS DA UNDER,ESTOU COM UM PEQUENO PROBLEMA,USO AQUI A VERSÃO 2.9.27 MKT COM WEB PROXY+HOTSPOT AMARRO IP+MAC EM LEASES
    MAS FUNCIONAFA TUDO BLZ,MAS NA HORA DE LOGAR NA PAGINA DO GMAIL,OU NO ORKUT DEMORA MUITO PARA AUTENTICAR,AI TEM QUE FICAR ATUALIZANDO OU ATE MESMO VOLTAR E ATUALIZAR NOVAMENTE PARA ENTRAR NO ORKUT, VOU POSTAR AS REGRAS AQUI
    SE ALGUEM SOUBER A SOLUÇÃO POR GENTILEZA ME AJUDEM....
    aqui e do firewall
    add chain=prerouting p2p=all-p2p action=mark-connection \
    new-connection-mark=p2p passthrough=yes comment="P2P" disabled=no
    add chain=prerouting connection-mark=p2p action=mark-packet \
    new-packet-mark="p2p 2" passthrough=yes comment="" disabled=no
    add chain=output protocol=tcp src-port=3128 content="X-Cache: HIT" \
    action=mark-connection new-connection-mark="PROXY CONNECTION" \
    passthrough=yes comment="PRXY FULL" disabled=no
    add chain=output connection-mark="PROXY CONNECTION" action=mark-packet \
    new-packet-mark="PROXY PACKET" passthrough=yes comment="" disabled=no
    / ip firewall nat
    add chain=srcnat src-address=10.0.0.0/24 action=masquerade comment="masquerade \
    hotspot network" disabled=no
    add chain=pre-hotspot dst-address=200.221.0.0/16 action=accept comment="RADIO \
    UOL" disabled=no
    add chain=pre-hotspot dst-address=201.7.0.0/16 action=accept \
    comment="GLOBO.COM" disabled=no
    add chain=pre-hotspot dst-address=10.0.0.1 protocol=tcp dst-port=80 \
    hotspot=auth action=redirect to-ports=64873 comment="Paginas de status do \
    hotspot\"" disabled=no
    add chain=pre-hotspot in-interface=bridge1 protocol=tcp dst-port=80 \
    hotspot=auth action=redirect to-ports=3128 comment="REDIRECIONAMENTO DE \
    PROXY HOTSPOT" disabled=no
    / ip firewall connection tracking
    set enabled=yes tcp-syn-sent-timeout=5s tcp-syn-received-timeout=5s \
    tcp-established-timeout=1d tcp-fin-wait-timeout=10s \
    tcp-close-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-time-wait-timeout=10s tcp-close-timeout=10s udp-timeout=10s \
    udp-stream-timeout=3m icmp-timeout=10s generic-timeout=10m \
    tcp-syncookie=no
    / ip firewall filter
    add chain=forward dst-address=10.0.0.0 protocol=tcp connection-limit=30,24 \
    action=drop comment="limitar conex es por clientes" disabled=no
    add chain=input in-interface=modem protocol=tcp dst-port=3128 action=drop \
    comment="bloqueio de proxy externo" disabled=no
    add chain=input connection-state=established action=accept comment="Accept \
    established connections" disabled=no
    add chain=input connection-state=related action=accept comment="Accept related \
    add chain=input protocol=udp action=accept comment="UDP" disabled=no
    add chain=input protocol=icmp limit=50/5s,2 action=accept comment="Allow \
    limited pings" disabled=no
    add chain=input protocol=tcp dst-port=22 action=accept comment="SSH for secure \
    shell" disabled=no
    add chain=input protocol=tcp dst-port=8291 action=accept comment="winbox" \
    disabled=no
    add chain=input protocol=icmp icmp-options=8:0 limit=1,5 action=accept \
    comment="DOS ATTACK" disabled=no
    add chain=icmp protocol=icmp icmp-options=0:0 action=accept comment="drop \
    invalid connections" disabled=no
    add chain=icmp protocol=icmp icmp-options=3:0 action=accept comment="allow \
    / ip firewall service-port
    set ftp ports=21 disabled=no
    set tftp ports=69 disabled=yes
    set irc ports=6667 disabled=yes
    set h323 disabled=yes
    set quake3 disabled=yes
    set gre disabled=yes
    set pptp disabled=yes
    aqui e do cache full
    / ip web-proxy
    set enabled=yes src-address=0.0.0.0 port=3128 hostname="proxy" \
    transparent-proxy=yes parent-proxy=0.0.0.0:0 \
    cache-administrator="[email protected]" max-object-size=80000KiB \
    cache-drive=primary-master max-cache-size=74000000KiB \
    max-ram-cache-size=512000KiB
    / ip web-proxy access
    add dst-port=23-25 action=deny comment="block telnet & spam e-mail relaying" \
    disabled=no
    / ip web-proxy cache
    add url=":cgi-bin \\?" action=deny comment="no cache dynamic http pages" \
    disabled=no
    add url="https://" action=deny comment="no cache dynamic https pages" \
    disabled=no
    add url=":\\.mpeg\$" action=deny comment="" disabled=no
    add url=":\\.avi\$" action=deny comment="" disabled=no
    add url=":\\.pdf\$" action=deny comment="" disabled=no
    add url=":\\.css\$" action=deny comment="" disabled=no
    add url=":\\.mov\$" action=deny comment="" disabled=no
    add url=":\\.mpg\$" action=deny comment="" disabled=no
    add url=":\\.iso\$" action=deny comment="" disabled=no
    add url=":\\.bin\$" action=deny comment="" disabled=no
    add url=":\\.dat\$" action=deny comment="" disabled=no
    add url=":\\.swf\$" action=deny comment="" disabled=no
    Agradeço desde já
    desculpe e que eu tinha esquecido de desativar o caps loock
