Boa noite a todos,
Estou testando algumas regras de balanceamento retiradas do WiKi do CATVBrasil e, ate o momento esta funcionando, só que tenho algumas duvidas. Se alguem puder me ajudar agradeço.
1 - Com esse balanceamento terei problemas com MSN e sites de bancos?
2 - La no tuto do catvbrasil uma regra de route esta desabilitada, por que? vejam:
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.254.254 scope=255 target-scope=10 routing-mark=Link1
comment="Gateway adsl1" disabled=no
add dst-address=0.0.0.0/0 gateway=192.168.253.253 scope=255 target-scope=10 routing-mark=Link2
comment="Gateway adsl2" disabled=no
add dst-address=0.0.0.0/0 gateway=192.168.254.254 scope=255 target-scope=10 comment="principal" disabled=yes
Veja minhas configurações e opinem:
/ ip firewall mangle
add chain=prerouting in-interface= Link1 connection-state=new nth=1,1,0 action=mark-connection
new-connection-mark=Link1 passthrough=yes comment="Balanceamento de carga" disabled=no
add chain=prerouting in-interface= Link1 connection-mark=Link1 action=mark-routing
new-routing-mark=Link1 passthrough=no comment="" disabled=no
add chain=prerouting in-interface= Link2 connection-state=new nth=1,1,1 action=mark-connection
new-connection-mark=Link2 passthrough=yes comment="" disabled=no
add chain=prerouting in-interface= Link2 connection-mark=Link2 action=mark-routing
new-routing-mark=Link2 passthrough=no comment="" disabled=no
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.254.254 scope=255 target-scope=10 routing-mark=Link2
comment="Gateway 2" disabled=no
add dst-address=0.0.0.0/0 gateway=192.168.2.1 scope=255 target-scope=10 routing-mark=Link1
comment="Gateway 1" disabled=no
add dst-address=0.0.0.0/0 gateway=192.168.254.254 scope=255 target-scope=10 comment="principal" disabled=no
/ ip firewall nat
add chain=srcnat out.interface= Link1 Actoin=masquerad comment="Nat Link1" disabled=no
add chain=srcnat out.interface= Link2 Actoin=masquerad comment="Nat Link2" disabled=no
add chain=prerouting protocol=tcp dst-port=80 action=mark-routing new-routing-mark=Link2 passthrough=yes comment="HTTP no Link2" disabled=no
add chain=prerouting routing-mark=Link2 action=mark-packet new-packet-mark=Link2 passthrough=yes comment="Pacotes marcados do Link2" disabled=no
add chain=prerouting protocol=tcp dst-port=443 action=mark-routing new-routing-mark=Link2 passthrough=yes comment="HTTPS no Link2" disabled=no
add chain=prerouting protocol=tcp dst-port=1863 action=mark-routing new-routing-mark=Link2 passthrough=yes comment="MSN no Link2" disabled=no
add chain=prerouting protocol=tcp dst-port=21 action=mark-routing new-routing-mark=Link1 passthrough=yes comment="FTP no Link1" disabled=no
add chain=prerouting routing-mark=Link1 action=mark-packet new-packet-mark=Link1 passthrough=yes comment="Pacotes marcados do Link1" disabled=no
add chain=prerouting protocol=tcp dst-port=22 action=mark-routing new-routing-mark=Link1 passthrough=yes comment="SSH no Link1" disabled=no
add chain=prerouting protocol=tcp dst-port=23 action=mark-routing new-routing-mark=Link1 passthrough=yes comment="TELNET" disabled=no
add chain=prerouting protocol=tcp dst-port=25 action=mark-routing new-routing-mark=Link1 passthrough=yes comment="SMPTP" disabled=no
add chain=prerouting protocol=tcp dst-port=53 action=mark-routing new-routing-mark=Link1 passthrough=yes comment="DNS" disabled=no
add chain=prerouting protocol=tcp dst-port=110 action=mark-routing new-routing-mark=Link1 passthrough=yes comment="POP3" disabled=no
add chain=prerouting protocol=tcp dst-port=1080 action=mark-routing new-routing-mark=Link1 passthrough=yes comment="" disabled=no
add chain=prerouting protocol=tcp p2p=all-p2p action=mark-routing new-routing-mark=Link1 passthrough=yes comment="p2p no Link1" disabled=no
No meu caso uso duas ADSL:
Link 1 de 1MB
Link 2 de 1.5MB
Qual o link que será mais usado?
Obrigado pela ajuda de que se dispor.
Denys Lemes
Citação
