    Angry reassociating, disconnected, ok, connected
    Não sei o que acontece depois que coloquei a RB 3.2 começou a dar essas msgs, porem a navegação dos clientes estao normais, já fixei o ack 50 62 91 deixei como dynamic indoor sinceramente nao sei o que fazer, alguem já passou por esta situação?
    https://under-linux.org/fotos/wagner...sconnected.jpg
    Desde já agradeço.
    Padrão Minhas Configs
    RouterOS 3.22
    /interface ethernet
    set 0 arp=enabled auto-negotiation=yes comment="" disabled=no full-duplex=yes mac-address=00:0C:42:43:04:8F \
    mtu=1500 name=Link speed=100Mbps
    set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes \
    mac-address=00:0C:42:43:04:90 master-port=none mtu=1500 name=Proxy speed=100Mbps
    set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes \
    mac-address=00:0C:42:43:04:91 master-port=none mtu=1500 name=ether3 speed=100Mbps
    /interface wireless security-profiles
    set default authentication-types="" eap-methods=passthrough group-ciphers="" group-key-update=5m \
    interim-update=0s mode=none name=default radius-eap-accounting=no radius-mac-accounting=no \
    radius-mac-authentication=no radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX \
    radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none \
    static-key-0="" static-key-1="" static-key-2="" static-key-3="" static-sta-private-algo=none \
    static-sta-private-key="" static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=none \
    tls-mode=no-certificates unicast-ciphers="" wpa-pre-shared-key="" wpa2-pre-shared-key=""
    /interface wireless
    set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 antenna-mode=ant-a \
    area="" arp=enabled band=2.4ghz-b basic-rates-a/g=12Mbps basic-rates-b=11Mbps burst-time=disabled comment=\
    "" compression=no country=no_country_set default-ap-tx-limit=0 default-authentication=yes \
    default-client-tx-limit=0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=no \
    disconnect-timeout=3s frame-lifetime=0 frequency=2447 frequency-mode=manual-txpower hide-ssid=no \
    hw-retries=4 mac-address=00:02:6F:61:96:C4 max-station-count=2007 mode=ap-bridge mtu=1500 name=clientes \
    noise-floor-threshold=default on-fail-retry-time=100ms periodic-calibration=default \
    periodic-calibration-interval=60 preamble-mode=long proprietary-extensions=post-2.9.25 radio-name=\
    "Spider Net" rate-set=configured scan-list=default security-profile=default ssid="Spider Net" \
    station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=12Mbps supported-rates-b=11Mbps tx-power=26 \
    tx-power-mode=card-rates update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=none \
    wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled wmm-support=disabled
    /interface wireless manual-tx-power-table
    set clientes comment="" manual-tx-powers="1Mbps:26,2Mbps:26,5.5Mbps:26,11Mbps:26,6Mbps:26,9Mbps:26,12Mbps:26,18\
    Mbps:26,24Mbps:26,36Mbps:26,48Mbps:26,54Mbps:26,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20-\
    7:0,HT20-8:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0,HT40-8:0"
    /interface wireless nstreme
    set clientes comment="" disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3200 framer-policy=\
    none
    /ip hotspot profile
    set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-proxy=0.0.0.0:0 login-by=http-chap \
    name=default nas-port-type=ethernet radius-accounting=yes radius-default-domain="" radius-interim-update=\
    received radius-location-id="" radius-location-name="" radius-mac-format=XX:XX:XX:XX:XX:XX rate-limit="" \
    smtp-server=0.0.0.0 split-user-domain=no use-radius=yes
    add dns-name=radio.spidernet hotspot-address=192.168.10.1 html-directory=hotspot http-proxy=0.0.0.0:0 \
    login-by=http-chap,http-pap name=profile nas-port-type=ethernet radius-accounting=yes \
    radius-default-domain="" radius-interim-update=received radius-location-id="" radius-location-name="" \
    radius-mac-format=XX:XX:XX:XX:XX:XX rate-limit="" smtp-server=0.0.0.0 split-user-domain=no use-radius=yes
    /ip hotspot user profile
    set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m \
    transparent-proxy=no
    add advertise=yes advertise-interval=30m advertise-timeout=immediately advertise-url=aviso.html idle-timeout=\
    none keepalive-timeout=2m name=aviso open-status-page=always shared-users=1 status-autorefresh=1m \
    transparent-proxy=yes
    add advertise=yes advertise-interval=1s advertise-timeout=immediately advertise-url=bloqueado.html \
    idle-timeout=none keepalive-timeout=2m name=bloqueado open-status-page=always shared-users=1 \
    status-autorefresh=1m transparent-proxy=yes
    add idle-timeout=none keepalive-timeout=2m name=300k rate-limit=200k/350k shared-users=1 status-autorefresh=1m \
    /ip ipsec proposal
    set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m name=default pfs-group=modp1024
    /ip pool
    add name=pool ranges=192.168.10.2-192.168.10.254
    add name=dhcp_pool1 ranges=10.5.50.2-10.5.50.254
    /ip dhcp-server
    add address-pool=pool authoritative=after-2sec-delay bootp-support=static disabled=no interface=clientes \
    lease-time=3d name=dhcp
    add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=static disabled=no interface=ether3 \
    lease-time=3d name=dhcp1
    /ip hotspot
    add address-pool=pool addresses-per-mac=3 disabled=no idle-timeout=10m interface=clientes keepalive-timeout=\
    none name=Hot1 profile=profile
    /port
    set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none stop-bits=1
    /ppp profile
    set default change-tcp-mss=yes comment="" name=default only-one=default use-compression=default \
    use-encryption=default use-vj-compression=default
    set default-encryption change-tcp-mss=yes comment="" name=default-encryption only-one=default use-compression=\
    default use-encryption=yes use-vj-compression=default
    /interface pppoe-client
    add ac-name="" add-default-route=yes allow=pap,chap,mschap1,mschap2 comment="" dial-on-demand=no disabled=no \
    interface=Link max-mru=1480 max-mtu=1480 mrru=disabled name=speedy password=e185 profile=default \
    service-name="" use-peer-dns=yes [email protected]
    /queue type
    set default kind=pfifo name=default pfifo-limit=50
    set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
    set wireless-default kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
    set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 \
    red-max-threshold=50 red-min-threshold=10
    set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
    add kind=pcq name=cache pcq-classifier=dst-address pcq-limit=50 pcq-rate=4800000 pcq-total-limit=2000
    set default-small kind=pfifo name=default-small pfifo-limit=10
    /queue tree
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=CACHE-FULL \
    packet-mark=Cache-Packet parent=global-out priority=8 queue=cache
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=1000000 max-limit=2000000 name=\
    ThunderCache packet-mark=thunder-packs parent=global-out priority=8 queue=default
    /routing bgp instance
    set default as=65530 client-to-client-reflection=yes comment="" disabled=no ignore-as-path-len=no name=default \
    out-filter="" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \
    redistribute-static=no router-id=0.0.0.0
    /routing ospf area
    add area-id=0.0.0.0 authentication=none disabled=no name=backbone type=default
    /snmp
    set contact="" enabled=no engine-boots=0 engine-id="" location="" time-window=15 trap-sink=0.0.0.0 \
    trap-version=1
    /snmp community
    set public address=0.0.0.0/0 authentication-password="" authentication-protocol=MD5 encryption-password="" \
    encryption-protocol=DES name=public read-access=yes security=none write-access=no
    /system logging action
    set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
    set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 disk-stop-on-full=no name=disk target=\
    disk
    set echo name=echo remember=yes target=echo
    set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0 syslog-facility=daemon \
    syslog-severity=auto target=remote
    /system routerboard settings
    set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=\
    300MHz enable-jumper-reset=yes enter-setup-on=any-key force-backup-booter=no
    /user group
    add name=read policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,!ftp,!write,!policy
    add name=write policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,!ftp,!policy
    add name=full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff
    /interface bridge settings
    set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
    /interface ethernet mirror
    set mirror-port=none source-port=none
    /interface l2tp-server server
    set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=no max-mru=1460 \
    max-mtu=1460 mrru=disabled
    /interface ovpn-server server
    set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=default enabled=no \
    keepalive-timeout=60 mac-address=FE:78:38:0A:C7:77 max-mtu=1500 mode=ip netmask=24 port=1194 \
    require-client-certificate=no
    /interface pptp-server server
    set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=\
    1460 max-mtu=1460 mrru=disabled
    /interface wireless align
    set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 \
    frame-size=300 frames-per-second=25 receive-all=no ssid-all=no
    /interface wireless sniffer
    set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no \
    receive-errors=no streaming-enabled=no streaming-max-rate=0 streaming-server=0.0.0.0
    /interface wireless snooper
    set channel-time=200ms multiple-channels=yes receive-errors=no
    /ip accounting
    set account-local-traffic=no enabled=no threshold=256
    /ip accounting web-access
    set accessible-via-web=no address=0.0.0.0/0
    /ip address
    add address=200.200.200.1/24 broadcast=200.200.200.255 comment="" disabled=no interface=Link network=\
    200.200.200.0
    add address=10.10.0.1/30 broadcast=10.10.0.3 comment="" disabled=no interface=Proxy network=10.10.0.0
    add address=192.168.10.1/24 broadcast=192.168.10.255 comment="" disabled=no interface=clientes network=\
    192.168.10.0
    add address=10.5.50.1/24 broadcast=10.5.50.255 comment="hotspot network" disabled=no interface=ether3 network=\
    10.5.50.0
    /ip dhcp-server config
    set store-leases-disk=5m
    /ip dhcp-server network
    add address=10.5.50.0/24 comment="" gateway=10.5.50.1
    add address=192.168.10.0/24 comment="hotspot network" gateway=192.168.10.1
    /ip dns
    set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=512 primary-dns=\
    200.204.0.10 secondary-dns=200.204.0.138
    /ip dns static
    add address=10.10.0.1 disabled=yes name=mk.provebuntu ttl=1d
    add address=10.10.0.2 disabled=yes name=provebuntu ttl=1d
    /ip firewall connection tracking
    set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s \
    tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
    tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
    /ip firewall mangle
    add action=mark-connection chain=postrouting comment="Marca o com sem TOS" disabled=no dscp=12 \
    new-connection-mark=n-cache passthrough=yes protocol=tcp src-port=3128
    add action=mark-connection chain=postrouting comment="" disabled=no dscp=!12 new-connection-mark=s-cache \
    add action=mark-packet chain=postrouting comment="Libera Cache Full" connection-mark=n-cache disabled=no \
    new-packet-mark=Cache-Packet passthrough=no
    add action=mark-connection chain=forward comment="THUNDER CACHE FULL" content="THUNDER: THUNDER" disabled=no \
    new-connection-mark=thunder-connection passthrough=yes protocol=tcp
    add action=mark-packet chain=forward comment="" connection-mark=thunder-connection disabled=no \
    new-packet-mark=thunder-packs passthrough=yes protocol=tcp
    /ip firewall nat
    add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
    add action=masquerade chain=srcnat comment="NAT PROXY" disabled=no src-address=10.10.0.0/30
    add action=dst-nat chain=pre-hotspot comment="REDIRECIONAMENTO PROXY" disabled=yes dst-address=!10.10.0.2 \
    dst-port=80 hotspot=auth in-interface=clientes protocol=tcp src-address=192.168.10.0/24 to-addresses=\
    10.10.0.2 to-ports=3128
    add action=dst-nat chain=dstnat comment="ACESSO EXTERNO PROVEBUNTU" disabled=no dst-port=8080 protocol=tcp \
    to-addresses=10.10.0.2 to-ports=80
    add action=masquerade chain=srcnat comment="masquerade hotspot network" disabled=no src-address=\
    192.168.10.0/24
    add action=masquerade chain=srcnat comment="placa ether 3" disabled=no src-address=10.5.50.0/24
    /ip firewall service-port
    set ftp disabled=no ports=21
    set tftp disabled=no ports=69
    set irc disabled=no ports=6667
    set h323 disabled=no
    set sip disabled=no ports=5060,5061
    set pptp disabled=no
    /ip hotspot service-port
    /ip hotspot user
    add comment="" disabled=no name=admin password=”” profile=default
    /ip hotspot walled-garden
    add action=allow comment="place hotspot rules here" disabled=yes
    /ip hotspot walled-garden ip
    add action=accept comment="" disabled=no dst-address=10.10.0.2
    /ip neighbor discovery
    set Link discover=yes
    set Proxy discover=yes
    set ether3 discover=yes
    set clientes discover=no
    set speedy discover=no
    /ip proxy
    set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no enabled=no \
    max-cache-size=unlimited max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
    parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0
    /ip service
    set telnet address=0.0.0.0/0 disabled=no port=23
    set ftp address=0.0.0.0/0 disabled=no port=21
    set www address=0.0.0.0/0 disabled=no port=80
    set ssh address=0.0.0.0/0 disabled=no port=22
    set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
    set api address=0.0.0.0/0 disabled=yes port=8728
    set winbox address=0.0.0.0/0 disabled=no port=8291
    /ip socks
    set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
    /ip traffic-flow
    set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=15s interfaces=all
    /ip upnp
    set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
    /ppp aaa
    set accounting=yes interim-update=0s use-radius=yes
    /queue interface
    set Link queue=ethernet-default
    set Proxy queue=ethernet-default
    set ether3 queue=ethernet-default
    set clientes queue=wireless-default
    set speedy queue=default
    /radius
    add accounting-backup=no accounting-port=1813 address=10.10.0.2 authentication-port=1812 called-id="" comment=\
    "" disabled=no domain="" realm="" secret=provebuntu service=hotspot timeout=300ms
    /radius incoming
    set accept=no port=3799
    /routing mme
    set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m gateway-selection=no-gateway \
    origination-interval=5s preferred-gateway=0.0.0.0 timeout=1m ttl=50
    /routing ospf
    set distribute-default=never metric-bgp=20 metric-connected=20 metric-default=1 metric-rip=20 metric-static=20 \
    mpls-te-area=unspecified mpls-te-router-id=unspecified redistribute-bgp=no redistribute-connected=no \
    redistribute-rip=no redistribute-static=no router-id=0.0.0.0
    /routing rip
    set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 \
    metric-static=1 redistribute-bgp=no redistribute-connected=no redistribute-ospf=no redistribute-static=no \
    timeout-timer=3m update-timer=30s
    /store
    add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
    /system clock manual
    set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start="jan/01/1970 00:00:00" time-zone=+00:00
    /system console
    add disabled=no port=serial0 term=vt102
    /system health
    set fan-mode=auto use-fan=main
    /system identity
    set name=Spider
    /system logging
    add action=memory disabled=no prefix="" topics=info
    add action=memory disabled=no prefix="" topics=error
    add action=memory disabled=no prefix="" topics=warning
    add action=echo disabled=no prefix="" topics=critical
    add action=memory disabled=yes prefix="" topics=script
    /system note
    set note="" show-at-login=yes
    /system ntp client
    set enabled=yes mode=unicast primary-ntp=200.19.119.69 secondary-ntp=200.132.0.132
    /system scheduler
    add comment="" disabled=no interval=30m name="atualiza IP" on-event="/ system script run ip" start-time=\
    startup
    /system upgrade mirror
    set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 user=""
    /system watchdog
    set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=none watchdog-timer=yes
    /tool bandwidth-server
    set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=10
    /tool e-mail
    set from=<> password="" server=0.0.0.0:25 username=""
    /tool graphing
    set store-every=5min
    /tool graphing interface
    add allow-address=0.0.0.0/0 disabled=no interface=all store-on-disk=yes
    /tool mac-server
    add disabled=no interface=all
    /tool mac-server ping
    set enabled=yes
    /tool sniffer
    set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 filter-address2=0.0.0.0/0:0-65535 \
    filter-protocol=ip-only filter-stream=yes interface=all memory-limit=10 only-headers=no streaming-enabled=\
    no streaming-server=0.0.0.0
    /user aaa
    set accounting=yes default-group=read interim-update=0s use-radius=no
    Padrão Bom essa ae sao minhas configs
    Bom galera desculpa ae pelo exagero.
    Espero que possam me ajudar
    Mais Uma vez Obrigado
    Parece estar tudo certo, oque poderia ser, que pelo geito vc já tentou, seria ter algum cliente precisando de mais ack que outro. Acontecia para mim a mesma coisa quando eu tinha um cliente a 500m e outro a 10km.
    Deixa as configurações avançadas da sua wireless default mesmo, não altere nenhuma delas, depois deixe o ack em modo dinamico, vai na tabela "registration" , e adicione uma coluna, o nome esta como "Ack. Timeout", depois em registration, vai aparecer o ack de cada estação conectada no AP.
    Acho que seria a melhor forma de descobrir quando o mikrotik está reconhecendo de ack para cada um. Tira uma média daquilo e seta na wireless, ou deixa um valor maior.
