    Padrão cache full tava fucionando e nao ta mais ?
    pessoal sempre montei cache com este script e roudou na boa, mas hoje tava montando um ser e seu a gota e nao fucionou a cache oq pode ser ?? MK versao 9.27
    / ip firewall mangle
    add chain=output protocol=tcp src-port=3128 content="X-Cache: HIT" action=mark-connection new-connection-mark=squid-connection-HIT passthrough=yes comment="Cache-squid" disabled=no
    add chain=output connection-mark=squid-connection-HIT action=mark-packet new-packet-mark=squid-packet-HIT passthrough=no comment="" disabled=no
    add chain=prerouting in-interface="Rede Local" src-address=10.10.10.0/24 action=mark-packet new-packet-mark=test-up passthrough=no comment="UP TRAFFIC" disabled=no
    add chain=forward src-address=10.10.10.0/24 action=mark-connection new-connection-mark=test-conn passthrough=yes comment="CONN-MARK" disabled=no
    add chain=forward in-interface=Internet connection-mark=test-conn action=mark-packet new-packet-mark=test-down passthrough=no comment="DOWN-DIRECT CONNECTION" disabled=no
    add chain=output out-interface="Rede Local" dst-address=10.10.10.0/24 action=mark-packet new-packet-mark=test-down passthrough=no comment="DOWN-VIA PROXY disabled=no
    / queue tree
    add name="downstream" parent="Rede Local" packet-mark=test-down limit-at=1024000 queue=default priority=1 max-limit=1024000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
    add name="upstream" parent=global-in packet-mark=test-up limit-at=512000 queue=default priority=1 max-limit=512000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
    add name="Cache-full" parent=global-out packet-mark=squid-packet-HIT limit-at=2000000 queue=default priority=8 max-limit=2000000 burst-limit=0 burst-threshold=0 burst-time=0s disabled=no
    aqui tive problemas no cache full quando troquei da versão 3.13 para 3.28. parou de funcionar. mais a 2.9.27 eu nunca usei cache full.
    essas regras era usadas em que versão??
    abraços.
    Avatar de Shaoroc
    Apr 2009
    Espírito Santo De Vitória, Espirito Santo, Brazil, Brazil
    Citação Postado originalmente por RobertoLima Ver Post
    abraços.
    Versão 3 num tem suporte a Cache.
    Citação Postado originalmente por Shaoroc Ver Post
    Amigo... será que estamos falando da mesma coisa?? aqui tenho cache full na 3.28..! veja o anexo abaixo... conexão de 200k. observe a versão do meu mk.
    abraços.
Nome:	         mk01.JPG
Visualizações:	231
Tamanho: 	161,8 KB
    Avatar de Shaoroc
    Apr 2009
    abraços.
    Boa noite Roberto, nunca utilizei esta versão so estou repassando a informação que o catybrasil posto aqui no forum
    segundo ele o cache somente pode ser feito com outra maquina
    ex
    mk>> debian como proxy >> clientes
    tipo isto
    Desculpas se passei a informação errado postei somente oque li aqui mesmo no forum
    ex
    tipo isto
    Que isso amigo não tem o que se desculpar pois isso tambem já li aqui, não sei se ainda vale nas versões atuais do mk, pois nunca usei o cache interno,.. aqui tá como você disse. Debian5 (squid+thunder3), MK (pppoe) --->>> Clientes.
    abraços.
    Avatar de Shaoroc
    Apr 2009
    abraços.
    trankilo amigo, so uma duvida
    usando como vc disse o squid e o thunder ele num fazeria cache de cada site ?
    exemplo vc abre o youtube ele vai fazer cache pelo squid e pelo thunder? ou vc criou uma regra para eles so fazerem testes de determinados links?
    quanto ah duvida do dmnetcatende
    amigo vc ja posto suas regras mais tenho uma duvida seu webproxy tinha algum erro?
    quando utilizava o mk sempre ficava com um erro e nunca fazia cache das paginas, mais apois colocar um outro hd somente para cache foi solucionado se num me engano ficava um tal de erro 6
    num lenbro direto
    mais tenta ver se ta aparecendo isto amigo
    outra dica que posso dar é vc tentar parar o cache limpar ele ou formatar e começar novamente mais repara se vai ter algum erro.
