    Question Problema meu proxy
    Gostaria ajuda por favor urgente seguinte eu tenho em torno 12 clientes de lanhouses acessando meu proxy quando eles estao acessando meu proxy simultaniamente da erro e trava meu squid:
    Message from [email protected] at Tue Oct 6 10:12:53 2009 ...
    proxy1 kernel: Oops: 0000 [#1]
    proxy1 kernel: SMP
    proxy1 kernel: CPU: 0
    proxy1 kernel: EIP: 0060:[<c05e6658>] Not tainted VLI
    proxy1 kernel: EFLAGS: 00010246 (2.6.22.14-72 #1)
    proxy1 kernel: EIP is at __ip_route_output_key+0x428/0x739
    proxy1 kernel: eax: 5d1484e0 ebx: 00000000 ecx: b33a5ac9 edx: 000000e0
    proxy1 kernel: esi: f6d08e54 edi: 00000000 ebp: f760d7c0 esp: f6d08d30
    proxy1 kernel: ds: 007b es: 007b fs: 00d8 gs: 0033 ss: 0068
    proxy1 kernel: Process squid (pid: 6847, ti=f6d08000 task=c2d43800 task.ti=f6d08000)
    proxy1 kernel: Stack: 0000005e f6d08e90 00000000 00000000 c05cbed0 c05c9b73 00000040 f7817000
    proxy1 kernel: f781706c c05cc2a8 00000000 00000000 00000001 00000000 5d1484e0 b33a5ac9
    proxy1 kernel: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    proxy1 kernel: Call Trace:
    proxy1 kernel: [<c05cbed0>] skb_copy_datagram_iovec+0x46/0x1d1
    proxy1 kernel: [<c05c9b73>] skb_dequeue+0x39/0x3f
    proxy1 kernel: [<c05cc2a8>] skb_recv_datagram+0x75/0x1a9
    proxy1 kernel: [<c05e697d>] ip_route_output_flow+0x14/0x1f9
    proxy1 kernel: [<c05c50f2>] sock_recvmsg+0xec/0x107
    proxy1 kernel: [<c06021b8>] tcp_v4_connect+0x199/0x5e3
    proxy1 kernel: [<c0438765>] autoremove_wake_function+0x0/0x35
    proxy1 kernel: [<c04edb18>] copy_to_user+0x34/0x48
    proxy1 kernel: [<c060d7db>] inet_stream_connect+0x7f/0x205
    proxy1 kernel: [<c04ed8d8>] copy_from_user+0x32/0x5e
    proxy1 kernel: [<c05c5c17>] sys_connect+0x82/0xad
    proxy1 kernel: [<c04301ff>] lock_timer_base+0x19/0x35
    proxy1 kernel: [<c043025f>] try_to_del_timer_sync+0x44/0x4a
    proxy1 kernel: [<c043026f>] del_timer_sync+0xa/0x14
    proxy1 kernel: [<c062f0a2>] schedule_timeout+0x79/0x8f
    proxy1 kernel: [<c05c6460>] sys_socketcall+0xac/0x261
    proxy1 kernel: [<c0404f5e>] syscall_call+0x7/0xb
    proxy1 kernel: =======================
    proxy1 kernel: Code: 89 c2 81 e2 f0 00 00 00 81 fa e0 00 00 00 75 07 c6 44 24 6a 05 eb 14 81 fa f0 00 00 00 0f 84 cb 02 00 00 84 c0 0f 84 c3 02 00 00 <f6> 83 b8 00 00 00 08 74 08 81 4c 24 08 00 00 00 80 8b ab 08 01
    proxy1 kernel: EIP: [<c05e6658>] __ip_route_output_key+0x428/0x739 SS:ESP 0068:f6d08d30
    ja troquei memoria HDD nada para problema esse erro
    por favor pessoal se alguem ja teve esse tipo de problema me der luz por favor ok
    Posta a conf do seu squid aii....
