    Unhappy Squid totalmente lento
    fala galera....
    Blz??
    Estou tendo um problema com meu squid...
    Esta muito lento... e nenhuma das aclss esta funcionando...
    Alguma idéia do que pode ser???
    Estou postando meu squid.conf para facilitar...
    Código :
    http_port 172.16.4.250:3128 transparent
    visible_hostname PROXY
    dead_peer_timeout 60 seconds
    hierarchy_stoplist cgi-bin ?
    no_cache deny QUERY
    detect_broken_pconn on
    pipeline_prefetch on
    icon_directory /usr/share/squid/icons
    #Cache
    cache_mem 512 MB
    cache_swap_low 80
    cache_swap_high 85
    maximum_object_size 512 MB
    minimum_object_size 0 MB
    maximum_object_size_in_memory 256 KB
    cache_replacement_policy heap LFUDA
    memory_replacement_policy heap LFUDA
    cache_dir ufs /var/spool/squid 20480 16 256
    cache_log /var/log/squid/cache.log
    ipcache_size 3072
    ipcache_low 90
    ipcache_high 95
    refresh_pattern . 15 20% 2280
    refresh_stale_hit 3 seconds
    ### Tempo maximo de conexão de um cliente
    client_lifetime 1 day
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443 563    # https, snews
    acl SSL_ports port 873    # rsync
    acl Safe_ports port 80    # https
    acl Safe_ports port 21    # ftp
    acl Safe_ports port 443 563    # httpd, snews
    acl Safe_ports port 70    #gopher
    acl Safe_ports port 210    # wais
    acl Safe_ports port 1025-65535    #portas nao registradas
    acl Safe_ports port 280    #http-mgmt
    acl Safe_ports port 488    # qss-http
    acl Safe_ports port 591    # filemaker
    acl Safe_ports port 777    # mulhhttp
    acl Safe_ports port 631    # cups
    acl Safe_ports port 873    # rsync
    acl Safe_ports port 901    # swat
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access allow !Safe_ports
    http_access allow CONNECT !SSL_ports
    ######### Criando as ACLS  #################
    #Sites que nao passam por proxy
    acl site dstdomain -i "/etc/squid/confs/sitesemproxy"
    always_direct allow site
    # Computadores sem limite de trafego de banda
    acl geral src 172.16.4.100 172.16.4.101 172.16.4.102
    http_access allow geral
    # PCs com acesso total
    acl acesso_total src "/etc/squid/confs/acesso_total"
    http_access allow acesso_total
    # Sites Liberados
    acl liberados dstdomain -i "/etc/squid/confs/sitesliberados"
    http_access allow liberados
    # Banner anuncio do msn
    acl ADSAdClien url_regex ADSAdClien
    http_access deny ADSAdClien
    deny_info [URL]http://acservinformatica.com.br/msn.html[/URL] ADSAdClien
    #Sites Bloqueados
    acl bloqueados url_regex -i "/etc/squid/confs/bloqueado"
    http_access deny bloqueados
    # Bloqueia MSn
    acl msn dstdomain loginnet.passport.com
    http_access deny msn
    acl msnmessenger url_regex -i gateway.dll
    acl MSN1 req_mime_type -i ^application/x-msn-messenger$
    http_access deny msnmessenger
    http_access deny MSN1
    # Web Messenger Bloqueio
    acl webmsn dstdomain webmessenger.msn.com
    http_access deny webmsn
    #Bloqueando download de programas
    acl extban url_regex -i "/etc/squid/confs/extban"
    http_access deny extban
    #Bloquando arquivos de musicas
    acl proibir_musica urlpath_regex -i "/etc/squid/confs/bloqmusicas"
    http_access deny proibir_musica
    acl redelocal src 172.16.4.0/32
    http_access allow localhost
    http_access allow redelocal
    http_access deny all
    Apr 2007
    Caruaru - Pernambuco
    Amigo,
    Boa tarde. Informe qual a sua máquina (configuração do servidor), e qual a quantidade de máquinas que o servidor irá disponibilizar a internet.
    Atenciosamente,
