    Smile Problema de autenticação Cisco6500 via freeradius + mysql
    Amigos do U-Linux,
    Não estou conseguindo me autenticar em um Cisco 6500 via freeradius + mysql.
    Meu cenário:
    - Freeradius+MySQL server: Debian GNU/Linux lenny x86_64 kernel 2.6.26-2-amd64
    - Freeradius 2.0.4
    - MySQL 5.0.51a
    - Calling Station: Windows XP Professional 32 bits SP3
    - Client: Cisco6500 Catalyst - IOS versão 12.2(17r)S4
    Rodando o freeradius -X (modo debug), tive o seguinte resultado (apenas omiti informações como IP, user e senha):
    Ready to process requests.
    rad_recv: Access-Request packet from host IP_Client port 21645, id=55, length=82
    NAS-IP-Address = IP_Client
    NAS-Port = 1
    NAS-Port-Type = Virtual
    User-Name = "user"
    Calling-Station-Id = "Calling_Station"
    User-Password = "pass_user"
    +- entering group authorize
    ++[preprocess] returns ok
    ++[chap] returns noop
    ++[mschap] returns noop
    rlm_realm: No '@' in User-Name = "user", looking up realm NULL
    rlm_realm: Found realm "NULL"
    rlm_realm: Adding Stripped-User-Name = "user"
    rlm_realm: Adding Realm = "NULL"
    rlm_realm: Authentication realm is LOCAL.
    ++[suffix] returns noop
    rlm_eap: No EAP-Message, not doing EAP
    ++[eap] returns noop
    ++[files] returns noop
    expand: %{User-Name} -> user
    rlm_sql (sql): sql_set_user escaped user --> 'user'
    rlm_sql (sql): Reserving sql socket id: 1
    expand: SELECT id, username, attribute, value, op FROM radcheck WHERE username = '%{SQL-User-Name}' ORDER BY id -> SELECT id, username, attribute, value, op FROM radcheck WHERE username = 'user' ORDER BY id
    rlm_sql (sql): User found in radcheck table
    expand: SELECT id, username, attribute, value, op FROM radreply WHERE username = '%{SQL-User-Name}' ORDER BY id -> SELECT id, username, attribute, value, op FROM radreply WHERE username = 'user' ORDER BY id
    expand: SELECT groupname FROM radusergroup WHERE username = '%{SQL-User-Name}' ORDER BY priority -> SELECT groupname FROM radusergroup WHERE username = 'user' ORDER BY priority
    expand: SELECT id, groupname, attribute, Value, op FROM radgroupcheck WHERE groupname = '%{Sql-Group}' ORDER BY id -> SELECT id, groupname, attribute, Value, op FROM radgroupcheck WHERE groupname = 'pop-sp' ORDER BY id
    rlm_sql (sql): User found in group pop-sp
    expand: SELECT id, groupname, attribute, value, op FROM radgroupreply WHERE groupname = '%{Sql-Group}' ORDER BY id -> SELECT id, groupname, attribute, value, op FROM radgroupreply WHERE groupname = 'pop-sp' ORDER BY id
    rlm_sql (sql): Released sql socket id: 1
    ++[sql] returns ok
    ++[expiration] returns noop
    ++[logintime] returns noop
    ++[pap] returns updated
    rad_check_password: Found Auth-Type
    auth: type "PAP"
    +- entering group PAP
    rlm_pap: login attempt with password "pass_user"
    rlm_pap: Using CRYPT encryption.
    rlm_pap: User authenticated successfully
    ++[pap] returns ok
    Login OK: [user/pass_user] (from client cisco6500 port 1 cli Calling_Station)
    +- entering group post-auth
    ++[exec] returns noop
    Sending Access-Accept of id 55 to IP_Client port 21645
    Framed-Compression := Van-Jacobson-TCP-IP
    Framed-Protocol := PPP
    Service-Type := Login-User
    Framed-MTU := 1500
    Finished request 8.
    Encontrei em um fórum da Cisco uma discussão sobre isso e um cara precisou alterar o valor do attribute Service-Type para 'Login' (antes era Framed-User), mas no meu caso isso não resolveu o problema.
    Agradeço se alguém puder ajudar.
    Wagner Pereira
    twitter: @wpereiratecno
    desculpe a ignorancia! o 6500 é apenas um concentrador ou é um DSLAM ?
    Padrão resposta
    jaos_caxias,
    O 6500 é um router da Cisco.
