    Padrão Load Balance não funciona
    galera naum to conseguino balancear 2 links um adsl de 2.5 e um dedicado de 1mb, tentei balancear usando o nth naum funcionou naum sei pq vou postar minhas confs mas se alguem tiver uma ideia ou tiver um tutorial pra mim dar uma olhada eu agradeço... ouvi falar tb de um balanceamento por pcc alguem tem algum material ai pra mim dar uma olhada e tentar configurar aki se naum der o nth... valeu
    Ai vao as confs
    Firewall mangle
    0 chain=prerouting action=mark-routing new-routing-mark=primeira_rota passthrough=no in-interface=Bridge Enlaces connection-mark=primeira
    1 chain=prerouting action=mark-connection new-connection-mark=segunda passthrough=yes connection-state=new in-interface=Bridge Enlaces nth=1,1
    2 chain=prerouting action=mark-routing new-routing-mark=segunda_rota passthrough=no in-interface=Bridge Enlaces connection-mark=segunda
    3 ;;; Usuarios Lista 1 (Address List)
    chain=prerouting action=mark-connection new-connection-mark=primeira passthrough=yes connection-state=new src-address-list=Lista1
    4 chain=prerouting action=mark-routing new-routing-mark=primeira_rota passthrough=no in-interface=Bridge Enlaces connection-mark=primeira
    5 ;;; Usuarios Lista 2 (Address List)
    chain=prerouting action=mark-connection new-connection-mark=segunda passthrough=yes connection-state=new src-address-list=Lista2
    6 chain=prerouting action=mark-routing new-routing-mark=segunda_rota passthrough=no in-interface=Bridge Enlaces connection-mark=segunda
    7 chain=prerouting action=add-src-to-address-list address-list=Lista1 address-list-timeout=1d in-interface=Bridge Enlaces connection-mark=primeira
    8 chain=prerouting action=mark-routing new-routing-mark=primeira_rota passthrough=no in-interface=Bridge Enlaces connection-mark=primeira
    9 ;;; Usuarios Lista 2 com Nth
    10 chain=prerouting action=add-src-to-address-list address-list=Lista2 address-list-timeout=1d in-interface=Bridge Enlaces connection-mark=segunda
    11 chain=prerouting action=mark-routing new-routing-mark=segunda_rota passthrough=no in-interface=Bridge Enlaces connection-mark=segunda
    Firewall Nat
    0 X ;;; place hotspot rules here
    chain=unused-hs-chain action=passthrough
    1 ;;; masquerade hotspot network
    chain=srcnat action=masquerade src-address=10.0.0.0/8
    2 chain=srcnat action=masquerade src-address=172.51.1.0/24
    3 ;;; Balanceamento de Carga
    chain=srcnat action=src-nat to-addresses=172.50.1.2 to-ports=0-65535 protocol=tcp connection-mark=primeira
    4 chain=srcnat action=src-nat to-addresses=172.50.1.2 to-ports=0-65535 protocol=udp connection-mark=primeira
    5 chain=srcnat action=src-nat to-addresses="ip link dedicado" to-ports=0-65535 protocol=tcp connection-mark=segunda
    6 chain=srcnat action=src-nat to-addresses="ip link dedicado" to-ports=0-65535 protocol=udp connection-mark=segunda
    7 ;;; Balanceamento de Carga (List_Wan1)
    8 chain=srcnat action=src-nat to-addresses=172.50.1.2 to-ports=0-65535 protocol=udp connection-mark=primeira
    9 ;;; Balanceamento de Carga (List_Wan2)
    10 chain=srcnat action=src-nat to-addresses="ip link dedicado" to-ports=0-65535 protocol=udp connection-mark=segunda
    Ip Route
    0 A S 0.0.0.0/0 reachable 172.50.1.1 1 Link 1
    1 A S 0.0.0.0/0 reachable "ip link dedicado" 1 Link 2
    2 A S 0.0.0.0/0 reachable 172.50.1.1 1 Link 1
    com isso ele sempre sai pela rota default.
    se alguem puder ajudar valeu.
    Amigo...tem muito material no forum sobre isso.....use a ferramente pesquisar que vai encontrar alguma dica que lhe ajudara....aqui tem um balance de links
    https://under-linux.org/f132956-load...os-e-msn-100-a
    Voce está no caminho mas suas regras estão desordenadas e as marcações incorretas. De preferencia a trabalhar como ADSL em modo Bridge, terá melhor aproveitamento deste link.
    João Paulo Saldanha
    Microwave | Gerente de Suporte/Engenharia
    http://www.microwavetec.com.br - Distribuidor Oficial Mikrotik
    Tel.: (31)3267-9500
    Problemas com sua rede ou provedor? Conheça o Suporte e Consultoria da Microwave, todas as respostas num só lugar.
