    Padrão problema no envio de email para o postfix
    Galera,
    quando dou um echo "Teste..." | mail -s "Testando o POSTFIX" usuario@local.com.br aparece o seguinte no /var/log/mail.log:
    server:~# tail -f /var/log/mail.log
    Jan 8 10:02:54 debian postfix/local[3160]: warning: connect #7 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:03:04 debian postfix/local[3160]: warning: connect #8 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:03:14 debian postfix/local[3160]: warning: connect #9 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:03:24 debian postfix/local[3160]: warning: connect #10 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:03:34 debian postfix/local[3160]: fatal: connect #11 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:03:35 debian postfix/qmgr[3138]: warning: private/local socket: malformed response
    Jan 8 10:03:35 debian postfix/qmgr[3138]: warning: transport local failure -- see a previous warning/fatal/panic logfile record for the problem description
    Jan 8 10:03:35 debian postfix/master[3134]: warning: process /usr/lib/postfix/local pid 3160 exit status 1
    Jan 8 10:03:35 debian postfix/master[3134]: warning: /usr/lib/postfix/local: bad command startup -- throttling
    Jan 8 10:03:35 debian postfix/error[3161]: 14B8833E6F: to=<usuario@local.com.br>, relay=none, delay=613, delays=511/101/0/0.07, dsn=4.3.0, status=deferred (unknown mail transport error)
    Jan 8 10:06:54 debian postfix/qmgr[3138]: 3588633E6D: from=<root@local.com.br>, size=329, nrcpt=1 (queue active)
    Jan 8 10:06:54 debian postfix/local[3167]: warning: connect #1 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:07:04 debian postfix/local[3167]: warning: connect #2 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:07:14 debian postfix/local[3167]: warning: connect #3 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:07:24 debian postfix/local[3167]: warning: connect #4 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:07:34 debian postfix/local[3167]: warning: connect #5 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:07:44 debian postfix/local[3167]: warning: connect #6 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:07:54 debian postfix/local[3167]: warning: connect #7 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:08:04 debian postfix/local[3167]: warning: connect #8 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:08:14 debian postfix/local[3167]: warning: connect #9 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:08:24 debian postfix/local[3167]: warning: connect #10 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:08:34 debian postfix/local[3167]: fatal: connect #11 to subsystem private//usr/bin/maildrop: No such file or directory
    Jan 8 10:08:35 debian postfix/qmgr[3138]: warning: private/local socket: malformed response
    Jan 8 10:08:35 debian postfix/qmgr[3138]: warning: transport local failure -- see a previous warning/fatal/panic logfile record for the problem description
    Jan 8 10:08:35 debian postfix/master[3134]: warning: process /usr/lib/postfix/local pid 3167 exit status 1
    Jan 8 10:08:35 debian postfix/master[3134]: warning: /usr/lib/postfix/local: bad command startup -- throttling
    Jan 8 10:08:36 debian postfix/error[3168]: 3588633E6D: to=<usuario@local.com.br>, relay=none, delay=1464, delays=1363/101/0/0.11, dsn=4.3.0, status=deferred (unknown mail transport error)
    Alguem ja passou por isso??
    Resolvido:
    no maildrop tem uma opção que estava
    fallback_transport = /usr/bin/maildrop e mudei para
    fallback_transport = maildrop
