    Padrão Openvpn server linux ... cliente windows NÂO CONECTA
    Tenho um servidor Slackware13 com Openvpn 2.0.9 com a seguinte configuração:
    cat /etc/openvpn/servervpn.conf
    # /etc/openvpn/server.conf
    proto udp
    port 1194
    dev tun
    comp-lzo
    server 10.0.0.0 255.255.255.0
    push "route 192.168.1.0 255.255.255.0"
    push "dhcp-option DNS 192.168.1.0"
    persist-tun
    persist-key
    float
    keepalive 10 120
    ifconfig-pool-persist /etc/openvpn/ipp.txt
    max-clients 3
    tls-server
    dh /etc/openvpn/dh/dh1024.pem
    ca /etc/openvpn/certs/ca.crt
    cert /etc/openvpn/certs/server.crt
    key /etc/openvpn/keys/server.key
    tls-auth /etc/openvpn/keys/static.key
    log-append /var/log/openvpn.log
    status /var/log/openvpn-status.log
    verb 6
    Starto o serviço usando :
    #openvpn --config /etc/openvpn/servervpn.conf --daemon
    porem o serviço parece não subir pois a saida do comando netstat -nlpt não mostra o mesmo:
    # netstat -nlpt
    Active Internet connections (only servers)
    Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 2743/sshd
    tcp6 0 0 :::22 :::* LISTEN 2743/sshd
    e tbem não aparece nada no nmap:
    # nmap localhost
    Starting Nmap 5.00 ( Nmap - Free Security Scanner For Network Exploration & Security Audits. ) at 2010-02-01 14:45 BRST
    Interesting ports on localhost (127.0.0.1):
    Not shown: 999 closed ports
    PORT STATE SERVICE
    22/tcp open ssh
    Nmap done: 1 IP address (1 host up) scanned in 0.28 seconds
    mas aparece no ps aux:
    # ps aux | grep openvpn
    root 4343 0.0 0.3 3880 924 ? Ss 14:26 0:00 openvpn --config /etc/openvpn/servervpn.conf --daemon
    já no log do openvpn as linhas finais o serviço parece estar funcionando:
    # cat /var/log/openvpn.log
    TLS-Auth MTU parms [ L:1542 D:166 EF:66 EB:0 ET:0 EL:0 ]
    TUN/TAP device tun0 opened
    TUN/TAP TX queue length set to 100
    /sbin/ifconfig tun0 10.0.0.1 pointopoint 10.0.0.2 mtu 1500
    /sbin/route add -net 10.0.0.0 netmask 255.255.255.0 gw 10.0.0.2
    Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:135 ET:0 EL:0 AF:3/1 ]
    Socket Buffers: R=[111616->131072] S=[111616->131072]
    UDPv4 link local (bound): [undef]:1194
    UDPv4 link remote: [undef]
    MULTI: multi_init called, r=256 v=256
    IFCONFIG POOL: base=10.0.0.4 size=62
    IFCONFIG POOL LIST
    Initialization Sequence Completed
    tento conectar usando GUI openvpn for windows mas sem sucesso com a seguinte config:
    # cat client.ovpn
    # /etc/openvpn/client.conf
    remote teste.homelinux.net
    proto udp
    port 1194
    client
    pull
    dev tun
    comp-lzo
    keepalive 10 120
    float
    tls-client
    dh dh1024.pem
    ca ca.crt
    cert cliente.crt
    key cliente.key
    alguem poderia dar uma luz? Parece estar tudo normal mas não conecta
    Buenas,
    Primeiramente, falando do seu teste de Netstat para saber se a VPN esta de pé.... vc especificou para o netstat filtrar por protocolos TCP, Sua VPN esta usando protocolo UDP, então mesmo que ela estivesse de pé... não apareceria...
    Use #netstat -avnu
    Agora vou dar um toque com relação a VPN que tenho aqui.
    Seguinte... notei algumas linhas a mais nesta sua conf, não que elas não devam estar ai, mas realmente funciona sem elas....
    Nas confs do server tls-auth /etc/openvpn/keys/static.key não precisa necessáriamente estar lá... e eu prefiro usar dev tap0
    nas confs do client:
    dh dh1024.pem
    Não sei exatamente do que se trata o parâmetro Float.
    Vc tem uma interface criada no modo TUN, com o nome tun (apenas)? não falta algum numero tipo tun0, tun1 por aew.
    vc levantou o modulo tun? (modeprobe tun)
    O DEV tun foi criado corretamente no Windows? A parte de certificação digital esta ok?
    Primeiro veja se levanta o server e em seguida poste os resultados, da falha ou não da conexão do client....
    Exemplo do meu client.conf
    # openvpn-client.conf
    # Set tunnel mode
    client
    dev tap
    proto udp
    # Hostname for the VPN server
    remote nome.com.br 1194
    # This end takes the client role for
    # certificate exchange
    tls-client
    # Certificate Authority file
    ca cacert.pem
    # Our certificate/public key
    cert tiago.crt
    # Our private key
    key tiagokey.crt
    comp-lzo
    # Get the rest of our configuration
    # from the server.
    pull
    #eof
    aguardo
    Att
    Tiago Iahn
    Citação Postado originalmente por Lynx Ver Post
    Buenas,
    Use #netstat -avnu
    Active Internet connections (servers and established)
    udp 0 0 0.0.0.0:1194 0.0.0.0:*
    udp 0 0 0.0.0.0:67 0.0.0.0:*
    Mudei a config conforme me disse porem ainda continua não conectando com a config
    o modulo tun esta carregado sim
    # lsmod | grep tun
    tun 10560 1
    todos os tutoriais que li o dev tun estava somente dev tun e não dev tun0 .
    O dev tun sobe com uma config mais basica que fiz para testes
    #ifconfig tun
    tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
    inet addr:10.0.0.1 P-t-P:10.0.0.2 Mask:255.255.255.255
    Tue Feb 02 16:45:09 2010 OpenVPN 2.0.9 Win32-MinGW [SSL] [LZO] built on Oct 1 2006
    Tue Feb 02 16:45:09 2010 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
    Tue Feb 02 16:45:09 2010 Cannot load certificate file server.crt: error:02001002:system library:fopen:No such file or directory: error:20074002:BIO routines:FILE_CTRL:system lib: error:140AD002:SSL routines:SSL_CTX_use_certificate_file:system lib
    Tue Feb 02 16:45:09 2010 Exiting
    Lynx consegui conectar usando essa conf no server:
    #config server OpenVPN
    dev tun
    ifconfig 10.0.0.1 10.0.0.2
    secret /etc/openvpn/keys/secret.key
    e no cliente Windows:
    #config Client OpenVPN
    remote teste.dyndns.net 1194
    dev tun
    secret secret.key
    porem apos conectado o cliente não conseguiu pingar a rede interna do servidor (motivo pelo qual desejo montar um a vpn ...acessar um programa da rede interna da empresa com uma conexão segura.... a rede interna esta 192.168.x.x)mas pinga normalmente 10.0.0.1
    O desafio é apenas dois clientes com Windows conectar e usar um programa da rede da empresa estado em outra rede porem com segurança
    Obrigado por enquanto Lynx
    poderia me enviar a config do teu server vpn e regras do firewall referentes as vpn que vc usa e conecta com a config que vc enviou anteriormente?
    Daew cara, reparei que o erro apresentado na conexão, parece ser de certificados, deve ter algum coisa errada com sua cadeia de certificados, quem assina quem e etc.
    mas de qualquer forma vou te mandar minhas confs.
    Matriz:
    port 1194
    proto udp
    dev tap0
    ;dev-node MyTap
    tls-server
    ca CA-DB/cacert.pem
    cert vpncert.pem
    key vpnkey.pem # This file should be kept secret
    dh dh1024.pem
    ifconfig-pool-persist ipp.txt
    server-bridge 169.254.1.1 255.255.0.0 169.254.1.220 169.254.1.230
    push "dhcp-option DNS 169.254.1.1"
    client-to-client
    keepalive 10 120
    comp-lzo
    persist-key
    persist-tun
    status openvpn-status.log
    verb 3
    mute 20
    Cliente:
    client
    dev tap
    proto udp
    remote IPVALIDO 1194
    tls-client
    ca cacert.pem
    cert tiago.crt
    key tiagokey.crt
    comp-lzo
    pull
    Para esta estrutura utilizo uma interface em modo Bridge
    usando o seguinte Script:
    #!/bin/bash
    # Set up Ethernet bridge on Linux
    # Requires: bridge-utils
    # Define Bridge Interface
    br="br0"
    # Define list of TAP interfaces to be bridged,
    # for example tap="tap0 tap1 tap2".
    tap="tap0"
    # Define physical ethernet interface to be bridged
    # with TAP interface(s) above.
    eth="eth0"
    eth_ip="169.254.1.1"
    eth_netmask="255.255.0.0"
    eth_broadcast="169.254.255.255"
    for t in $tap;
    do
    openvpn --mktun --dev $t
    done
    brctl addbr $br
    brctl addif $br $eth
    for t in $tap;
    do
    brctl addif $br $t
    done
    for t in $tap;
    do
    ifconfig $t 0.0.0.0 promisc up
    done
    ifconfig $eth 0.0.0.0 promisc up
    ifconfig $br $eth_ip netmask $eth_netmask broadcast $eth_broadcast
    Essa Bridge é importante para que vc possa acessar sua rede com a transparência que quer, sem precisar de NAT e tals.
    Mas vc precisa rever sua cadeia de certificados, talvez refaze-la....
    Assim esta funcionando perfeito aqui na empresa, Utilizo como cliente o OpenVPN Client for Windows.
    Vai postando ai...
    Att
    Tiago Sell Iahn
    Bom Dia,
    Era bom deixar uma recado avisando se as coisas deram certo, ou não.... se foi válido ou ainda não resolveu.
    Att
    Tiago Iahn
