Pessoal,,
Dei uma olhada em um topico parecido, mas acho que nao é o meu problema.. Alguns emails nao estão chegando em suas devidas contas... Na hora do envio do email,, dei um tail -f no maillog e reportou essa mensagem...
Feb 18 10:48:10 mail postfix/qmgr[32634]: C0FF82AF62D: from=<[email protected]>, size=62433, nrcpt=1 (queue active)
Feb 18 10:48:10 mail amavis[11969]: (11969-18) (!!)WARN: all primary virus scanners failed, considering backups
Feb 18 10:48:21 mail postfix/qmgr[32634]: 6B0892AF563: from=<[email protected]>, size=62934, nrcpt=1 (queue active)
Feb 18 10:48:21 mail amavis[11969]: (11969-18) Passed CLEAN, [200.98.199.16] [201.80.209.221] <[email protected]> -> <[email protected]>, Message-ID: <002c01cab09a$3fd61f90$9300a8c0@escritorio2>, mail_id: ouuVIpZRWw7P, Hits: 2.675, size: 62433, queued_as: 6B0892AF563, 11216 ms
Feb 18 10:48:21 mail postfix/smtp[16511]: C0FF82AF62D: to=<[email protected]>, relay=127.0.0.1[127.0.0.1]:10024, delay=12, delays=0.47/0/0/11, dsn=2.0.0, status=sent (250 2.0.0 Ok: queued as 6B0892AF563)
Feb 18 10:48:21 mail spamd[1758]: spamd: connection from localhost.localdomain [127.0.0.1] at port 51814
Feb 18 10:48:21 mail postfix/qmgr[32634]: C0FF82AF62D: removed
Feb 18 10:48:21 mail spamd[1758]: spamd: setuid to dlm succeeded
Feb 18 10:48:21 mail spamd[1758]: bayes: bayes db version 0 is not able to be used, aborting! at /usr/lib/perl5/vendor_perl/5.8.8/Mail/SpamAssassin/BayesStore/DBM.pm line 196.
Feb 18 10:48:21 mail spamd[1758]: spamd: processing message <002c01cab09a$3fd61f90$9300a8c0@escritorio2> for dlm:579
Feb 18 10:48:21 mail spamd[1758]: bayes: bayes db version 0 is not able to be used, aborting! at /usr/lib/perl5/vendor_perl/5.8.8/Mail/SpamAssassin/BayesStore/DBM.pm line 196, <GEN306> line 883.
Feb 18 10:48:26 mail spamd[1758]: spamd: identified spam (5.9/5.0) for dlm:579 in 5.1 seconds, 62242 bytes.
Feb 18 10:48:26 mail spamd[1758]: spamd: result: Y 5 - FH_DATE_PAST_20XX,HTML_IMAGE_ONLY_16,HTML_MESSAGE,STOCK_IMG_CTYPE scantime=5.1,size=62242,user=dlm,uid=579,required_score=5.0,rhost=localhost.localdomain,raddr=127.0.0.1,rport=51814,mid=<002c01cab09a$3fd61f90$9300a8c0@escritorio2>,autolearn=no
Feb 18 10:48:26 mail spamd[12133]: prefork: child states: II
Feb 18 10:48:26 mail postfix/local[16551]: 6B0892AF563: to=<[email protected]>, relay=local, delay=5.2, delays=0.03/0/0/5.2, dsn=2.0.0, status=sent (delivered to command: /usr/bin/procmail)
