Boa tarde a todos, venho recorrer novamente aos amigos mais experientes sobre como solucionar a configuração do WCCPv2 em um Cisco 2801, segue os resultados que obtive, acredito que falta pouca coisa para funcionar:
Código :MegaRouter>sh ip wccp Global WCCP information: Router information: Router Identifier: 200.xxx.xxx.126 Protocol Version: 2.0 Service Identifier: web-cache Number of Cache Engines: 1 Number of routers: 1 Total Packets Redirected: 5731 Process: 2 Fast: 0 CEF: 5729 Redirect access-list: -none- Total Packets Denied Redirect: 0 Total Packets Unassigned: 4 Group access-list: -none- Total Messages Denied to Group: 0 Total Authentication failures: 0 Total Bypassed Packets Received: 0
Código :MegaRouter>sh ip wccp web-cache detail WCCP Cache-Engine information: Web Cache ID: 172.16.1.6 Protocol Version: 2.0 State: Usable Initial Hash Info: 00000000000000000000000000000000 00000000000000000000000000000000 Assigned Hash Info: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Hash Allotment: 256 (100.00%) Packets Redirected: 319 Connect Time: 01:04:06 Bypassed Packets Process: 0 Fast: 0 CEF: 0
Bom, pelo que entendo o 2801 está reconhecendo o cache, porém, não está havendo tráfego, os pacotes não estão sendo redirecionados, segue minha configuração no Cisco:
Código :Current configuration : 1485 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname MegaRouter ! boot-start-marker boot-end-marker ! enable secret 5 $1$1wLv$dgIgekFXlOyGhnuFlxLBf1 ! no aaa new-model ! resource policy ! mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ip subnet-zero ip wccp web-cache ip cef ! ! no ip dhcp use vrf connected ! ! ! ! ! ! interface FastEthernet0/0 ip address 189.xxx.xxx.97 255.255.255.240 ip wccp web-cache redirect out duplex auto speed auto ! interface FastEthernet0/1 ip address 172.16.1.5 255.255.255.252 duplex auto speed auto --More--
FastEthernet 0/1 é a interface ligada ao servidor squid por um cabo cat5 crossover.
Iptables:
Código :iptables -t nat -A PREROUTING -i wccp2 -p tcp -m tcp --dport 80 -j REDIRECT --to-port 3128
Interfaces configuradas no servidor squid:
Código :eth2 Link encap:Ethernet Endereço de HW 00:1F:D0:FE:A2:C4 inet end.: 172.16.1.6 Bcast:172.16.1.7 Masc:255.255.255.252 endereço inet6: fe80::21f:d0ff:fefe:a2c4/64 Escopo:Link UP BROADCASTRUNNING MULTICAST MTU:1500 Métrica:1 RX packets:1225 errors:0 dropped:0 overruns:0 frame:0 TX packets:1776 errors:0 dropped:0 overruns:0 carrier:0 colisões:0 txqueuelen:1000 RX bytes:153658 (150.0 KiB) TX bytes:200334 (195.6 KiB) IRQ:233 Endereço de E/S:0x8000 lo Link encap:Loopback Local inet end.: 127.0.0.1 Masc:255.0.0.0 endereço inet6: ::1/128 Escopo:Máquina UP LOOPBACKRUNNING MTU:16436 Métrica:1 RX packets:8 errors:0 dropped:0 overruns:0 frame:0 TX packets:8 errors:0 dropped:0 overruns:0 carrier:0 colisões:0 txqueuelen:0 RX bytes:560 (560.0 b) TX bytes:560 (560.0 b) wccp2 Link encap:Não Especificado Endereço de HW AC-10-01-06-8E-BF-F4-AF-00-00-00-00-00-00-00-00 inet end.: 172.16.1.6 P-a-P:172.16.1.6 Masc:255.255.255.255 UP POINTOPOINT RUNNING NOARP MTU:1476 Métrica:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 colisões:0 txqueuelen:0 RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
Tenho algumas dúvidas:
O servidor cache, aponta rota default? Estou apontando para 172.16.1.5 que é o Cisco, o servidor cache tem acesso a todas as faixas de ip no Cisco mais não sai para internet, isso está certo?
A marcação ZPH para cache full será reconhecida no firewall?
Grato a todos.
Citação
