  1. Pessoal não cbq ou htb para limitar a banda dos clientes ., utilizo o delay pools do próprio squid gostaria de saber se posso fazer cache full? abaixo segue o squid.conf ., como ficaram as regras no ipatbles nesse caso?
    Existem linhas a serem acrescentadas para otimizar o uso squid?
    O módulo zph ja foi aplicado.
    # NETWORK OPTIONS
    http_port 3128 transparent
    error_directory /usr/share/squid/errors/pt-br/
    # OPTIONS WHICH AFFECT THE NEIGHBOR SELECTION ALGORITHM
    # TAG: hierarchy_stoplist
    #hierarchy_stoplist cgi-bin ?
    # TAG: no_cache
    no_cache deny QUERY
    # OPTIONS WHICH AFFECT THE CACHE SIZE
    # TAG: cache_mem (bytes)
    cache_mem 1000 MB
    maximum_object_size_in_memory 32 kb
    # TAG: cache_swap_low (percent, 0-100)
    # TAG: cache_swap_high (percent, 0-100)
    cache_swap_low 90
    cache_swap_high 95
    # TAG: maximum_object_size (bytes)
    maximum_object_size 150 mb
    maximum_object_size_in_memory 2048 kb
    minimum_object_size 0 KB
    # LOGFILE PATHNAMES AND CACHE DIRECTORIES
    # TAG: cache_dir
    cache_dir ufs /var/spool/squid 10048 16 256
    # TAG: cache_access_log
    # TAG: cache_log
    cache_log /var/log/squid/cache.log
    #Intervalos de tempos que o proxy verificara os arquivos dos site acessado
    #conferem com o do cache, o valor 10080 significa aproximadamente 09 dias
    refresh_pattern -i (/cgi-bin/|\?) 0 0% 0
    refresh_pattern . 0 20% 4320
    #Mantendo objetos recentes e pequenos na memoria
    memory_replacement_policy heap GDSF
    acl shoutcast rep_header X-HTTP09-First-Line ^ICY\s[0-9]
    acl apache rep_header Server ^Apache
    broken_vary_encoding allow apache
    # ACCESS CONTROLS
    # TAG: acl
    icp_port 0
    acl all src 10.0.0.0/255.255.0.0
    acl SSL_ports port 443 563
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl CONNECT method CONNECT
    acl extensoes urlpath_regex -i "/etc/squid/extensoes.reg"
    # ACL´s para Portal CAPES
    acl portal_capes url_regex -i "/etc/squid/portalcapes.txt"
    acl bandabaixa src "/etc/squid/bandabaixa"
    acl bandamedia src "/etc/squid/bandamedia"
    acl bandaalta src "/etc/squid/bandaalta"
    # Delay Pools
    delay_pools 3
    delay_class 1 2
    delay_class 2 2
    delay_class 3 2
    delay_access 1 allow bandabaixa
    delay_access 2 allow bandamedia
    delay_access 3 allow bandaalta
    delay_parameters 1 -1/-1 8000/8000
    delay_parameters 2 -1/-1 18000/18000
    delay_parameters 3 -1/-1 52000/52000
    # TAG: http_access
    http_access deny manager
    http_access deny extensoes
    http_access allow all
    http_reply_access allow all
    # Redirecionamento para o MCT
    cache_peer prx.mct.gov.br parent 80 0 no-query
    cache_peer_access prx.mct.gov.br allow portal_capes
    always_direct allow !portal_capes
    http_reply_access allow all portal_capes
    # TAG: icp_access
    icp_access allow all portal_capes
    visible_hostname aruana
    # MARCAR PACOTES TOS
    zph_mode tos
    zph_local 0x30
    zph_parent 0
    zph_option 136
  2. estou tentando compilar squid p fazer controle de mac, e full cache.
    uso Amndriva 2010 free e soh da erro na hora de compilar o squid, ja consegui aplicar o patch e fazer o configure.... mas na hora do make e make install da erro: 1, antes estava com erro ssl, quais depencias estao faltando?
    logfile.cc:105: error: invalid conversion from ‘const char*’ to ‘char*’
    logfile.cc:108: error: invalid conversion from ‘const char*’ to ‘char*’
    make[3]: ** [logfile.o] Erro 1
    make[3]: Saindo do diretório `/home/leandro/squid-3.0.STABLE8/src'
    make[2]: ** [install-recursive] Erro 1
    make[2]: Saindo do diretório `/home/leandro/squid-3.0.STABLE8/src'
    make[1]: ** [install] Erro 2
    make[1]: Saindo do diretório `/home/leandro/squid-3.0.STABLE8/src'
    make: ** [install-recursive] Erro 1
  1. Respostas: 7
    Último Post: 30-06-2007, 12:20
  2. Ajuda com Delay Pools
    Por TheHawk no fórum Servidores de Rede
    Último Post: 01-04-2006, 06:49
  3. Squid com delay pools
    Por Lestat1 no fórum Servidores de Rede
    Último Post: 10-03-2006, 16:45
  4. Respostas: 2
    Último Post: 25-07-2005, 08:40
  5. squid com delay pools nao funciona
    Por dispatcher no fórum Servidores de Rede
    Último Post: 01-04-2005, 10:57
