    Moderador Avatar de Magal
    Mar 2007
    Rio de Janeiro
    Padrão Mikrotik 4.9 Lançado
    What's new in 4.9:
    *) fixed problem - some of the bridge ports stayed invalid after reboot;
    *) console - added '/port remote-access export' command;
    What's new in 4.8:
    *) added support for second serial port on RB800/RB1100;
    *) fixed problem - WinBox crashed while opening VAP interface;
    *) dhcp server - fixed possible inactive dhcp server in case of many
    dhcp leases with address-pool enabled (broken in v4.7);
    *) dhcp server - show non-printable option 82 agent-circuit-id and
    agent-remote-id values in hexadecimal notation
    (in the same way as client-id is shown);
    *) api - can supply password to '/system/upgrade/upgrade-package-source/add';
    *) console - fixed bug that caused "cannot set ..." error when using
    some properties in 'find' commands;
    *) api - 'print' command was not showing values of some properties
    such as 'servers' in "/ip/dns";
    *) show old software id in export file header;
    Última edição por Magal; 30-04-2010 às 13:16.
