    Moderador Avatar de Magal
    Mar 2007
    Rio de Janeiro
    Padrão Mikrotik 5.0 beta 2
    What's new in 5.0beta2 (2010-Apr-30 11:35):
    *) added wireless distance setting, removed ack-timeout;
    *) improved 802.11 operation for outdoor distances;
    What's new in 5.0beta2 (2010-Apr-29 12:10):
    *) fixed sstp on x86;
    *) console - removed 'delay' argument from '/system scheduler add' command;
    *) console - remove 'comment=""' values from export;
    *) console - updated '/system script job':
    - also show active login sessions here;
    - new read-only property 'type' with values "command", "login"
    or "api-login" for running commands and either kind of login sessions;
    - new optional read-only property 'parent' with id of the job that
    has spawned this one;
    *) console - changed "started" property of '/system script job' to use
    local time;
    *) console - new property 'type' in '/system script job'
    *) console - added '/port remote-access export' command;
    *) console - fixed bug that caused "cannot set ..." error when using
    some properties in 'find' commands;
    *) show old software id in export file header;
    *) api - can supply password to '/system/upgrade/upgrade-package-source/add';
    *) api - 'print' command was not showing values of some properties
    such as 'servers' in "/ip/dns";
    *) api - fixed api login sessions not dissapearing from '/user active' after
    termination;
    *) '/user active' now lists type of api connections as 'api';
    *) added support for hardware watchdog on RB1000 & RB800;
    *) added support for ASIX AX88xxx based USB Ethernet Adapters on RB4xx;
    *) fixed problem - ipv6 traffic was not bridged if ipv6 package was not enabled;
    *) fixed getting interface stats in dude;
    *) fixed metarouter stability problem on RB400s & RB750s;
    *) fixed metarouter - it didn't work on RB1000 with 2Gb;
    *) fixed metarouter - it locked up on RB800;
    *) fixed problem - SFQ queues did not work on interfaces (wireless) if none
    of simple or tree queues were added;
    *) fixed RB800 temperature;
    *) fixed problem - WinBox crashed while opening VAP interface;
    *) dhcp server - fixed possible inactive dhcp server in case of many
    dhcp leases with address-pool enabled;
    *) dhcp server - show non-printable option 82 agent-circuit-id and
    agent-remote-id values in hexadecimal notation
    (in the same way as client-id is shown);
    Padrão Re: Mikrotik 5.0 beta 2
    Alguem já está testando? quais suas conclusões?
    Principalmente sobre a ultima acima.
    Serios bloemas com minha rede...
    tô aguniado aqui.. 300 clientes numa lentidão dos infernos... tô tentando voltar a versão...
    na versão 5. beta 5 tive serios problemas, de instabilidade no sistema quando tinha clientes com ack auto ela ia a 100% de cpu diretão e pra piorar todas que estivem ligadas nela também sobia o processador na hora ai, os clientes caiam e os novos nem autenticavam mais... fiz um downgrade para 4.11 e fico show de bola de novo graças a Deus.
