  1. Olá PessoALL,
    Gostaria de uma dica/correção caso seja necessário nestas configurações baseadas no tópico https://under-linux.org/f226/qos-no-...mpleto-126657/ eu fiz minhas próprias acompanhando o desempenho da minha rede. Hoje estar tranquilo sem problemas, mas seria interressante saber o seguinte:
    Para um LINK dedicado FULL de 4MB as configurações abaixo são boas em termo de só analisando os calculos?
    [edilsonlsouza@GANTZ-AP1] > /queue tree export
    # jun/01/2010 12:44:02 by RouterOS 4.6
    # software id = L83V-VHHL
    /queue tree
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=2M name=\
    ServicosDaRede packet-mark=servicosdarede parent=global-total priority=1 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Ssl \
    packet-mark=ssl parent=global-total priority=2 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=300k name=P2P \
    packet-mark=p2p parent=global-total priority=8 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=3M name=\
    BatePapo packet-mark=batepapo parent=global-total priority=2 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Udp \
    parent=global-total priority=3
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Udp-100 \
    packet-mark=udp-100 parent=Udp priority=1 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Udp-500 \
    packet-mark=upd-500 parent=Udp priority=2 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=\
    Udp-Other packet-mark=upd-other parent=Udp priority=3 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Email \
    parent=global-total priority=4
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Pop3 \
    packet-mark=pop3 parent=Email priority=1 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Imap \
    packet-mark=imap parent=Email priority=3 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Http \
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=7M name=\
    Http-Navegacao packet-mark=http-navegacao parent=global-total priority=1 queue=default
    Http-1Mbyte packet-mark=http-1Mbyte parent=Http priority=2 queue=default
    Http-3Mbyte packet-mark=http-3Mbyte parent=Http priority=3 queue=default
    Http-6Mbyte packet-mark=http-6Mbyte parent=Http priority=4 queue=default
    Http-30Mbyte packet-mark=http-30Mbyte parent=Http priority=5 queue=default
    Http-60Mbytes packet-mark=http-60Mbytes parent=Http priority=6 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=1M name=\
    Http-Infinite packet-mark=http-Infinite parent=Http priority=7 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Youtube \
    packet-mark=Youtube parent=Http priority=4 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Outros \
    parent=global-total priority=7
    Outros-0bytes packet-mark=0bytes parent=Outros priority=1 queue=default
    Outros-1Mbyte packet-mark=1Mbyte parent=Outros priority=2 queue=default
    Outros-3Mbyte packet-mark=3Mbyte parent=Outros priority=3 queue=default
    Outros-6Mbyte packet-mark=6Mbyte parent=Outros priority=4 queue=default
    Outros-30Mbyte packet-mark=30Mbyte parent=Outros priority=5 queue=default
    Outros-60Mbytes packet-mark=60Mbytes parent=Outros priority=6 queue=default
    Outros-Infinite packet-mark=Infinite parent=Outros priority=7 queue=default
    Outros-Desconhecidos packet-mark=Outros parent=Outros priority=8 queue=default
    AcessoRemoto packet-mark=acessoremoto parent=global-total priority=3 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Voip \
    packet-mark=voip parent=global-total priority=6 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=5M name=Hotspot \
    packet-mark=hotspot parent=global-total priority=1 queue=default
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Smtp \
    packet-mark=smtp parent=Email priority=2 queue=default
    Desde já agradeço qualquer dica.
    Última edição por EdilsonLSouza; 01-06-2010 às 11:45.
  2. Citação Postado originalmente por EdilsonLSouza Ver Post
    Olá PessoALL,
    /queue tree
    Voce esta com isso em produção? porque não tem limites em nenhuma das linhas
  3. Sim estar em produção... sem limites? não entendi!
  4. no script voce não esta fazendo QoS, pois esta todas as regras de liberação estão zeradas, voce define quem tem prioridade
  5. Genis, então essas minhas marcações tambem estão incorretas pois eu usei o mesmo Qos postado pelo Edilson.
    Segue abaixo:
    # jun/03/2010 09:07:32 by RouterOS 3.28
    /queue tree
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=2M \
    max-limit=3M name=SquidCache-Down packet-mark=proxy-squid parent=\
    global-out priority=8 queue=cache
    max-limit=3M name=SquidCache-Up packet-mark=proxy-squid parent=global-in \
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=yes limit-at=2M \
    max-limit=3M name=ThunderCache-Down packet-mark=thunder-packs parent=\
    max-limit=3M name=ThunderCache-Up packet-mark=thunder-packs parent=\
    global-in priority=8 queue=cache
    add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 \
    max-limit=1M name=ServicosDaRede packet-mark=servicosdarede parent=\
    max-limit=0 name=Ssl packet-mark=ssl parent=global-total priority=2 \
    queue=default
    max-limit=200k name=P2P packet-mark=p2p parent=global-total priority=8 \
    queue=default
    max-limit=1M name=BatePapo packet-mark=batepapo parent=global-total \
    max-limit=0 name=Udp packet-mark="" parent=global-total priority=3 queue=\
    default
    max-limit=0 name=Udp-100 packet-mark=udp-100 parent=Udp priority=1 queue=\
    default
    max-limit=0 name=Udp-500 packet-mark=upd-500 parent=Udp priority=2 queue=\
    default
    max-limit=0 name=Udp-Other packet-mark=upd-other parent=Udp priority=3 \
    queue=default
    max-limit=0 name=Email packet-mark="" parent=global-total priority=4 \
    queue=default
    max-limit=0 name=Pop3 packet-mark=pop3 parent=Email priority=1 queue=\
    default
    max-limit=0 name=Imap packet-mark=imap parent=Email priority=3 queue=\
    default
    max-limit=0 name=Http packet-mark="" parent=global-total priority=2 \
    queue=default
    max-limit=12M name=Http-Navegacao packet-mark=http-navegacao parent=\
    max-limit=0 name=Http-1Mbyte packet-mark=http-1Mbyte parent=Http \
    max-limit=0 name=Http-3Mbyte packet-mark=http-3Mbyte parent=Http \
    max-limit=0 name=Http-6Mbyte packet-mark=http-6Mbyte parent=Http \
    max-limit=0 name=Http-30Mbyte packet-mark=http-30Mbyte parent=Http \
    max-limit=0 name=Http-60Mbytes packet-mark=http-60Mbytes parent=Http \
    max-limit=600k name=Http-Infinite packet-mark=http-Infinite parent=Http \
    max-limit=0 name=Youtube packet-mark=Youtube parent=Http priority=4 \
    queue=default
    max-limit=0 name=Outros packet-mark="" parent=global-total priority=7 \
    queue=default
    max-limit=0 name=Outros-0bytes packet-mark=0bytes parent=Outros priority=\
    1 queue=default
    max-limit=0 name=Outros-1Mbyte packet-mark=1Mbyte parent=Outros priority=\
    2 queue=default
    max-limit=0 name=Outros-3Mbyte packet-mark=3Mbyte parent=Outros priority=\
    3 queue=default
    max-limit=0 name=Outros-6Mbyte packet-mark=6Mbyte parent=Outros priority=\
    4 queue=default
    max-limit=0 name=Outros-30Mbyte packet-mark=30Mbyte parent=Outros \
    max-limit=0 name=Outros-60Mbytes packet-mark=60Mbytes parent=Outros \
    max-limit=0 name=Outros-Infinite packet-mark=Infinite parent=Outros \
    max-limit=0 name=Outros-Desconhecidos packet-mark=Outros parent=Outros \
    max-limit=0 name=AcessoRemoto packet-mark=acessoremoto parent=\
    max-limit=0 name=Voip packet-mark=voip parent=global-total priority=6 \
    queue=default
    max-limit=0 name=Smtp packet-mark=smtp parent=Email priority=2 queue=\
    default
    max-limit=1M name="Colheita Feliz" packet-mark=pacote_colheitafeliz \
    parent=global-out priority=2 queue=default
    max-limit=1M name="Mini Colheita Feliz" packet-mark=pacote_minifazenda \
    max-limit=0 name=Globo.com packet-mark=Globo parent=Http priority=4 \
    queue=default
    max-limit=0 name=Terra packet-mark=Terra parent=Http priority=4 queue=\
    default
  1. Respostas: 21
    Último Post: 18-03-2014, 09:44
  2. Respostas: 11
    Último Post: 03-09-2012, 22:56
  3. Respostas: 8
    Último Post: 18-12-2010, 09:39
  4. Respostas: 7
    Último Post: 09-10-2010, 10:15
  5. roteador para link de 1 MB
    Por alisson no fórum Servidores de Rede
    Respostas: 5
    Último Post: 06-08-2004, 16:41
