    Padrão [Problema] CBQ Não esta limitando
    Olá, já pesquisei bastante, fiz alterações, mudei a interface....
    Segui este tutorial https://under-linux.org/f134/servido...cional-132192/
    Fiz algumas alterações, mas no mais é isso.
    Criei 2 arquivos:
    /etc/sysconfig/cbq/cbq-0002.cristian.in
    /etc/sysconfig/cbq/cbq-0003.cristian.out
    Código :
    DEVICE=eth0,10Mbit,1Mbit
    RATE=50K
    WEIGHT=5Kbit
    PRIO=5
    RULE=192.168.0.181
    BOUNDED=yes
    ISOLATED=no
    Código :
    DEVICE=eth1,10Mbit,1Mbit
    RATE=50K
    WEIGHT=5Kbit
    PRIO=5
    RULE=192.168.0.181,
    BOUNDED=yes
    ISOLATED=no
    Código :
    [[email protected] ~]# cbq compile
    find: warning: you have specified the -maxdepth option after a non-option argument (, but options are not positional (-maxdepth affects tests specified before it as well as those specified after it).  Please specify options before other arguments.
    /sbin/tc qdisc del dev eth0 root
    /sbin/tc qdisc add dev eth0 root handle 1 cbq bandwidth 10Mbit avpkt 3000 cell 8
    /sbin/tc class change dev eth0 root cbq weight 1Mbit allot 1514
    /sbin/tc qdisc del dev eth1 root
    /sbin/tc qdisc add dev eth1 root handle 1 cbq bandwidth 10Mbit avpkt 3000 cell 8
    /sbin/tc class change dev eth1 root cbq weight 1Mbit allot 1514
    /sbin/tc class add dev eth0 parent 1: classid 1:2 cbq bandwidth 10Mbit rate 50K weight 5Kbit prio 5 allot 1514 cell 8 maxburst 20 avpkt 3000 bounded
    /sbin/tc qdisc add dev eth0 parent 1:2 handle 2 tbf rate 50K buffer 10Kb/8 limit 15Kb mtu 1500
    /sbin/tc filter add dev eth0 parent 1:0 protocol ip prio 100 u32 match ip dst 192.168.0.181 classid 1:2
    /sbin/tc class add dev eth1 parent 1: classid 1:3 cbq bandwidth 10Mbit rate 50K weight 5Kbit prio 5 allot 1514 cell 8 maxburst 20 avpkt 3000 bounded
    /sbin/tc qdisc add dev eth1 parent 1:3 handle 3 tbf rate 50K buffer 10Kb/8 limit 15Kb mtu 1500
    /sbin/tc filter add dev eth1 parent 1:0 protocol ip prio 100 u32 match ip src 192.168.0.181 classid 1:3
    Código :
    [[email protected] ~]# cbq start
    Abraços.
    Padrão Re: [Problema] CBQ Não esta limitando
    Bom Dia...
    Primeiramente nas suas Confs, adicione Kbit ao lado do RATE e não só K....
    Depois nas linhas RULE, vc precisa dizer a mascara também, no caso se é para apenas um PC a limitação vc pode colocar IP/32...
    no seu caso RULE=192.168.0.181/32
    Faz este teste.... não tenho certeza se isso já resolve... mas ....
    Qualquer coisa poste aqui...
    Att
    Tiago Iahn
    Olá,
    Fiz as alterações:
    Código :
    RATE=50Kbit
    WEIGHT=5K[COLOR=Red]bit[/COLOR]
    PRIO=5
    RULE=192.168.0.181/[COLOR=Red]32[/COLOR]
    BOUNDED=yes
    ISOLATED=no
    Código :
    RATE=50K[COLOR=Red]bit[/COLOR]
    WEIGHT=5Kbit
    PRIO=5
    RULE=192.168.0.181/[COLOR=Red]32[/COLOR],
    BOUNDED=yes
    ISOLATED=no
    O Download ficou limitado de acordo, já o upload ficou sem limite.
    Tentei fuçando mesmo fazer alterações, até p/ eth0 mudei, sempre testando a velocidade, dando stop|compile|start.
    O Upload continuou sem limite.
    Obrigado pela ajuda.
    Na verdade não havia repara nas placas, mas ja que você falou.... utilize em ambas configurações IN e OUT a mesma interface... no caso a Interna....
    Ja limite na entrada do servidor e não na saida.... teste isto que deve funcionar....
    Entendeu o que eu quis dizer (talvez falei meio enrolado)? Coloca a ETHx (interna) nas duas cofigs...
    Valew...
    Att
    Tiago Iahn
    Olá, entendi, alterei para eth0 como já havia testado.
    eth0 é a interna.
    Continuou na mesma.
    Segunda pesquiso sobre este problema, agora ta meio corrido.
    Abraço.
