    Padrão AJUDA POSTFIX denied access relay...
    Bem o meu postfix ta rodando internamente blz. Mais o problema e quando configura o outlook ou thunderbird em uma rede externa da erro de denied access relay. A ate que conseguir fazer uma gambiarra no main.cf e acrescentar o ip externo no meu mynetworks e funcionou.
    Oque devo fazer? tem como eu liberar a mynetowrks para todo mundo ex:
    mynetwork: *.*.*.*./*
    Segue abaixo meu main.cf
    queue_directory = /var/spool/postfix
    daemon_directory = /usr/lib/postfix
    mail_owner = postfix
    mydomain = vitapan.com.br
    myorigin = $mydomain
    local_recipient_maps =
    unknown_local_recipient_reject_code = 550
    mynetworks_style = host
    mynetworks = 127.0.0.0/24, 192.168.0.0/24, 192.168.1.0/24, 201.3.21.162, 201.2.51.147
    relay_domains = $mydestination
    alias_database = hash:/etc/aliases
    header_checks = regexp:/etc/postfix/header_checks
    smtpd_banner = $myhostname - Vitapan
    debug_peer_level = 2
    debugger_command =
    PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin
    xxgdb $daemon_directory/$process_name $process_id & sleep 5
    sendmail_path = /usr/sbin/sendmail
    newaliases_path = /usr/bin/newaliases
    mailq_path = /usr/bin/mailq
    setgid_group = maildrop
    html_directory = /usr/share/doc/packages/postfix/html
    manpage_directory = /usr/share/man
    sample_directory = /usr/share/doc/packages/postfix/samples
    readme_directory = /usr/share/doc/packages/postfix/README_FILES
    inet_protocols = all
    biff = no
    mail_spool_directory = /var/mail
    canonical_maps = hash:/etc/postfix/canonical
    virtual_alias_maps = hash:/etc/postfix/virtual
    virtual_alias_domains = hash:/etc/postfix/virtual
    relocated_maps = hash:/etc/postfix/relocated
    transport_maps = hash:/etc/postfix/transport
    sender_canonical_maps = hash:/etc/postfix/sender_canonical
    masquerade_exceptions = root
    masquerade_classes = envelope_sender, header_sender, header_recipient
    myhostname = mail.vitapan.com.br
    program_directory = /usr/lib/postfix
    inet_interfaces = all
    masquerade_domains =
    mydestination = $mydomain, $myhostname, localhost.$mydomain
    defer_transports =
    mynetworks_style = subnet
    disable_dns_lookups = no
    relayhost =
    mailbox_command =
    mailbox_transport = lmtp:unix:/var/lib/imap/socket/lmtp
    strict_8bitmime = no
    disable_mime_output_conversion = no
    smtpd_sender_restrictions = hash:/etc/postfix/access
    smtpd_client_restrictions = permit_mynetworks, reject_non_fqdn_sender, reject_non_fqdn_recipient, reject_unknown_sender_domain, reject_unknown_recipient_domain, permit_mynetworks, reject_unauth_destination, hash:/etc/postfix/access, reject_invalid_hostname, reject_unknown_client, permit_sasl_authenticated
    smtpd_helo_required = yes
    smtpd_helo_restrictions = reject_invalid_hostname, permit
    strict_rfc821_envelopes = yes
    smtpd_recipient_restrictions = reject_invalid_hostname, reject_non_fqdn_sender, reject_non_fqdn_recipient, reject_unknown_sender_domain, reject_unknown_recipient_domain, permit_mynetworks, reject_unauth_destination, reject_rbl_client cbl.abuseat.org, reject_rbl_client sbl-xbl.spamhaus.org, reject_rbl_client bl.spamcop.net, reject_rhsbl_sender dsn.rfc-ignorant.org, permit
    smtp_sasl_auth_enable = no
    smtpd_sasl_auth_enable = yes
    smtpd_use_tls = no
    smtp_use_tls = no
    alias_maps = hash:/etc/aliases
    mailbox_size_limit = 0
    message_size_limit = 120000000
    default_process_limit = 200
    smtpd_recipient_limit = 100
    disable_vrfy_command = yes
    unknown_address_reject_code = 554
    unknown_hostname_reject_code = 554
    unknown_client_reject_code = 554
    maps_rbl_domains = sbl.spamhaus.org, spammers.v6net.org, dun.dnsrbl.net, vox.schpider.com, whois.rfc-ignorant.org
    Padrão Re: AJUDA POSTFIX denied access relay...
    Olá.
    Configure o SMTP Autenticado. Para isto, instale esses pacotes:
    sasl2-plug-plain
    sasl2-plug-digestmd5
    sasl2-programs
    sasl2-plug-anonymous
    sasl2-plug-crammd5
    sasl2
    sasl2-plug-login
    #Editar o arquivo:
    /usr/lib/sasl2/smtpd.conf
    #Inserir as seguintes linhas.
    pwcheck_method: saslauthd
    mech_list: PLAIN LOGIN
    log_level: 3
    #No main.cf:
    smtpd_recipient_restrictions = permit_sasl_authenticated, permit_mynetworks .....
    Possa ser que tenha esquecido de algum detalhe ....
    Tutorial Postfix - Introduo
    receitinha de bolo de como fazer um server.
    ali tem como implemetar a autenticação kra. facinho facinho...
