WINDOWS UPDATE NAO FUNCIONA
OLA GALERINHA SOU INICIANTE NA AREA MAS ESTOU ME ACOSTUMANDO COM O LINUX
MAS O MEU PROBLEMA E O SEGUINTE
NAO SEI SE E REGRA DE SQUID OU DE IPTABLES
MAS TENHO UM SERVIDOR LINUX COM ALGUMAS REGRINHAS BASICAS SOH PRA APRENDER MSMO
MAS MEU PROBLEMA E O SEGUINTE
OS MICROS DA MINHA REDE NAO ESTAO ATUALIZANDO O UPDATE PELO SITE
E NTRA NA TELA E TUDO MAS SOH FICA VERIFICANDO AS ULTIMAS ATUALIZAÇOES E NAO SAI DESSA VERIFICAÇAO JA LI ALGUNS TUTORIAIS MAS TA DIFICIL INTENDER ALGUEM PODE ME DIZER OQ EU POSSO INCREMENTAR AS MINHAS REGRAS PARA QUE ISSO FUNCIONE ??
##### minhas regras abaixo ( squid )
# gedit /etc/squid3/squid.conf
# Autor: Pablo Fernando <f0mezero@hotmail.com>
# Licença: GPL - http://www.gnu.org/licenses/gpl.html
# Descrição: Arquivo de configuração do squid p/ autenticação em AD
http_port 192.168.50.1:3128
visible_hostname debian.informatica.local
hierarchy_stoplist cgi-bin ?
no_cache deny QUERY
cache_mem 128 MB
maximum_object_size_in_memory 512 KB
maximum_object_size 64 MB
minimum_object_size 0 KB
cache_swap_low 90
cache_swap_high 95
cache_dir ufs /var/spool/squid3 2048 16 256
error_directory /usr/share/squid3/errors/Portuguese/
dns_nameservers 192.168.50.3
cache_mgr f0mezero
@hotmail.com
coredump_dir /var/spool/squid3
external_acl_type nt_group %LOGIN /usr/lib/squid3/wbinfo_group.pl
##### LOGS
#logformat combined %>a %ui %un [%tl] "%rm %ru HTTP/%rv" %Hs %<st "%{Referer}>h" "%{User-Agent}>h" %Ss:%Sh
#access_log /var/log/squid3/access.log combined
cache_log /var/log/squid3/cache.log
logfile_rotate 4
##### LOG DETALHADO SÓ HABILITEI PARA SOLUCIONAR PROBLEMAS
#logformat squid %ts.%03tu %6tr %>a %Ss/%03Hs %<st %rm %ru %un %Sh/%<A %mt
#logformat squidmime %ts.%03tu %6tr %>a %Ss/%03Hs %<st %rm %ru %un %Sh/%<A %mt [%>h] [%<h]
#logformat common %>a %ui %un [%tl] "%rm %ru HTTP/%rv" %Hs %<st %Ss:%Sh
##### Inicio - Autenticacao no NTLM
auth_param ntlm program /usr/bin/ntlm_auth --helper-protocol=squid-2.5-ntlmssp
auth_param ntlm children 30
auth_param basic program /usr/bin/ntlm_auth --helper-protocol=squid-2.5-basic
auth_param basic children 5
auth_param basic realm Squid proxy-caching web server
auth_param basic credentialsttl 2 hours
acl AuthorizedUsers proxy_auth REQUIRED
##### ACLs Basicas
acl all src 0.0.0.0/0.0.0.0
acl localhost src 127.0.0.1/32
acl redelocal src 192.168.50.0/24
acl SSL_ports port 443 563 2083 begin_of_the_skype_highlighting 443 563 2083 end_of_the_skype_highlighting
acl Safe_ports port 21 80 443 563 70 210 280 488 59 777 901 1025-65535
acl purge method PURGE
acl CONNECT method CONNECT
http_access deny manager
http_access deny purge
http_access deny !Safe_ports
##### ACLs
##### Não faz cache das urls dentro do arquivo "/etc/squid3/acls/semcache"
# acl semcache dstdomain "/etc/squid3/acls/semcache"
# cache deny semcache
##### ACL usuarios sem autenticacao por IP
#acl noauth src "/etc/squid3/acls/noauth"
# acls de grupos do ad
acl administradores external nt_group administradores
acl administracao external nt_group administracao
acl siteusuarios external nt_group siteusuarios
acl seminternet external nt_group seminternet
acl commsn external nt_group commsn
# acl controlar sites
acl sites_deny dstdomain -i "/etc/squid3/acls/sites-proibidos"
acl sites_allow dstdomain -i "/etc/squid3/acls/sites-permitidos"
acl semmsn_deny dstdomain -i "/etc/squid3/acls/semmsn"
acl sitespadrao_allow dstdomain -i "/etc/squid3/acls/sitespadrao"
#acl
#acl
#acl
#acl
#acl
acl caixa dstdomain -i .caixa.gov.br
# acl controlar palavras de sexo, baixo calão, etc
acl palavras_deny url_regex -i "/etc/squid3/acls/palavras_deny"
acl palavras_allow url_regex -i "/etc/squid3/acls/palavras_allow"
# acl liberacao Windowsupdate
acl update dstdomain -i Windowsupdate.microsoft.com au.download.Windowsupdate.com
# acls de sites locais
acl sites_locais dst 192.168.50.0/24
#### HTTP ACCESS
# Libera acesso geral sem autenticação (controlados por ip)
#http_access allow noauth
# Libera acesso geral a diretoria
http_access allow administradores redelocal
# controle de acessos especiais(Windows Update, Caixa)
http_access allow update redelocal
http_access allow caixa redelocal
always_direct allow caixa redelocal
# Libera acesso a sites locais para a rede local
http_access allow sites_locais redelocal
# controle de acesso de sites proibidos
http_access deny sites_deny !sites_allow
# controle de acesso da acl de palavras de sexo, baixo calão, etc
http_access deny palavras_deny !palavras_allow
# controle por grupos ad
http_access allow administracao redelocal
http_access deny siteusuarios all !sitespadrao_allow
http_access deny seminternet all redelocal
# Libera acesso aos usuarios autenticados na rede local
http_access allow AuthorizedUsers redelocal
# Nega o restante
http_access deny all
####### IPTABLES REGRAS BEM BESICAS SOH DE REPASSE MSMO
# Limpa e inicializa os modulos
iptables -F
iptables -t nat -F
iptables -t mangle -F
modprobe iptable_nat
# Proxy transparente (Redireciona para o squid) - eth0 -> Placa de rede da intranet
iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 80 -j REDIRECT --to-port 3128
# Compartilha Internet - eth0 -> Placa de rede da internet
iptables -t nat -A POSTROUTING -o eth2 -j MASQUERADE
LEMBRANDO QUE EU ENTRO NOS SITES PELO ADMINISTRADOR
E TODOS OS SITES ESTAO FUNCIONANDO CORRETAMENTE NAO COLOQUEI BLOQUEIO NENHUM A ELE
NENHUMA REGRA DE DENY
E GOSTARIA TB SE ALGUEM PUDESSE COLOCAR REGRA DE CACHE DO WINDOWS UPDATE TB SERIA BOM
OBRIGADO
