  1. ai galera estou disponibilizando pra ver se o sistema rende.
    aqui ta funfando legal, mais ainda tem que revisar e dar uma tunada.
    proxy.pl
    Código :
    #!/usr/bin/perl
    #ALEXSANDRO alexsandro@altelecom.com.br
    #Raptor 1.0 Beta
    #path dir
    $homedir="/etc/raptor";
    $cachedir="/cache/raptor";
    $lockdir="/cache/raptor/locks";
    #files
    $logfile="/var/log/proxy.log";
    $logerro="/var/log/proxy.err";
    $begin=time;
    open FILE, "$homedir/plugins.lst";
    chomp( @plugins = <FILE> );
    close FILE;
    # Wait time in seconds for a lock to die.
    $deadlink=120; # two minutes
    ### Code!
    $ourver="1.0 beta - filtering/caching";
    $d=$hard=$help=$log=$v=0;  #debug
    foreach $j (@ARGV)
        $d++ if($j eq "-d");
        $v++ if($j eq "-v");
        $hard++ if($j eq "-a");
        $help++ if($j eq "-h");
        $log++ if($j eq "-l");
        $rand++ if($j eq "-f");
        $limit++ if($j eq "-r");
        $cflush++ if($j eq "-c");
    if($help)
        print STDERR <<EOF;
    $0 options:
        -d  debug
        -v  verbose
        -a  hard fail on banned URLs
        -l  log interaction
        -f  futz around with pulling images a bit
        -r  try to rate limit (not implemented)
        -c  Flush the TempCache and exit.
    EOF
        exit 1;
    # Requirements
    use Socket;
    $|=1;
    $log=1;
    # Error subroutine.  If we run into trouble, we do it here.
    sub err {
        my ($e,$r)=@_;
        # Quickly suck in some junk just in case...
        # BUG:  It just delays netscape somehow.
        # while(<>) {;}
        print STDERR "$$: $e -- $r\n" if($v);
        print "HTTP/1.0 $e\r\n";
        print "Content-Type: text/html\r\n";
        print "Connection: close\r\n\r\n";
        print "<html><head><title>$e</title></head><body>\r\n";
        print "<h1>$e</h1><BR><P>";
        print "Raptor cannot fulfill your request -- $r<P>$req<P>\n";
        print "<hr><br><i>Raptor version $ourver<br></I>\r\n";
        exit 0;
    sub nothing {
        print STDERR "$$: Sending nothing\n" if($v);
        print "HTTP/1.0 200 OK\r\n";
        print "// Nothing. \r\n";
        print "\r\n";
        exit 0;
    sub blank {
        print STDERR "$$: Sending blank\n" if($v);
        print "HTTP/1.0 200 OK\nConnection: close\n";
        print "Content-type: image/gif\n\n", pack "H*", "47494638396101000100800000ffffff"."00000021f90401000000002c00000000"."010001000002024401003b";
        exit 0;
    # Generic file send routine.
    sub sendthis {
        my ($file)=@_;
        while( -e "$lock" )
            unlink "$lock" if(-M "$lock" > $deadlink);
            sleep 3;
        $file_size = -s $file;
        open(IN,"<$file") || &err("500 Internal Server Error","Cannot open cached file ($!)");
        while(<IN>)
            print;
        $begin=time - $begin;
        $xfor="127.0.0.1" if (!$xfor);
        print LOG time.".000 $begin $xfor TCP_HIT/$codi $file_size $type http://$url - NONE/- $xtype\n" if($log);
        exit;
    # Open up a logfile.
    if($log)
        $log='' unless(open(LOG,">>$logfile"));
        $lerr='' unless(open(ERRO,">>$logerro"));
    # Read the first line of the request and pharze it.
    $_=$req=<STDIN>; tr/\n\r//d;
    exit if(/^$/);
    #print ERRO "$$: line: $_\n" if($log);
    m#^(GET|POST|HEAD) http://([^/]+)(/.*) (HTTP\S+)$#i;
    $type=$1; $site=$2; $page=$3; $ver=$4;
    $url=$site.$page;
    $line=$_;
    #search cached
    $cachethis=0;
    $domain=0;
    foreach $j (@plugins)
        if($site =~ /$j/)
            $domain = $j;
    if($site =~ /^([^:]+):(\d+)$/)
        $remote=$1; $port=$2;
    } else {
        $remote=$site; $port=80;
    $iaddr   = inet_aton($remote) ;
    # Call out and strangle someone
    &err("400 Bad Request","Site $remote can't be resolved ($!).") unless($iaddr);
    $paddr   = sockaddr_in($port, $iaddr);
    $proto   = getprotobyname('tcp');
    socket(SOCK, PF_INET, SOCK_STREAM, $proto)  || &err("500 Internal Server Error","Something went wrong trying to connect to $remote ($!).");
    connect(SOCK, $paddr) || &err("500 Internal Server Error","Cannot connect to $remote ($!)");
    $old=select(SOCK); $|=1; select($old);
    print SOCK "$type $page $ver\r\n"; # Xmission's webserver is funky
    $lo=0;
    while(<STDIN>)
        $ok=1;
        $l=$_;
        tr/\r\n//d;
        $lo=2 if(/^$/);
        $cont=$1 if(/^Content-[lL]ength: (\d+)$/);
        $nocache++ if(/^Pragma: no-cache/);
        $ok=0 if(/^Proxy-Connection:/);
        $ok=0 if(/^Range: bytes/);
        $xfor=$1 if(/X-Forwarded-For:\s(.*)/);
        print SOCK "Connection: close$l" if($lo);
        print SOCK "$l" if($ok);
        print STDERR "$$ >>> $l" if($ok && $d);
        last if($lo);
    if($cont)
        while($cont)
            $in=read STDIN, $buf, ($cont < 512 ? $cont : 512 );
            $cont -= $in;
             print SOCK $buf;
    $conn=0; $lc=0;
    while(<SOCK>)
        $l=$_; $lc++;
        tr/\r\n//d;
        last if(/^$/);
        $http=$1 if(/(^HTTP.*)\s([0-9])/);
        $codi=$1 if(/^HTTP.*\s([0-9]{3})\s/);
        $xtype=$1 if(/^Content-Type.*\s(.*)/);
        $conn++ if(/^Connection:/);
        print $l unless($conn);
    $rsize=$cont;
    print "Connection: close\r\n" if($codi =~ /304/);
    print $l if ($codi =~ /304/);;
    close SOCK if ($codi =~ /304/);
    exit 0 if ($codi =~ /304/);
    &err("500 Internal Server Error","Blank document returned.  ($!)")  unless($lc);
    unless($url =~ /\?/ && !$domain)
        $file=0;
        if($domain)
            #carrega plugin para tratar a $url
            $plugin = "$homedir/plugins/$domain.pl";
            if(-e $plugin)
                print ERRO "$$: LOADING $domain.pl.\n" unless($xfor); #if($log);
                do "$homedir/plugins/$domain.pl";
            } else {
                print ERRO "$$: plugin $domain.pl not found.\n" if($log);
        if($file)
            $file="$cachedir/$file";
            $lock=$1 if ($file =~ /^.*\/(.*$)/);
            $lock="$lockdir/$lock.LOCK";
            if(-e $file)
                if( -e $lock )
                unless( -e $lock )
                    $size = -s $file;
                    if($rsize > $size)
                        unlink "$file";
                        print ERRO "FILE ERROR: LSIZE: $size - RSIZE: $rsize arquivo corrompido ou incompleto $file.\n" if($log);
            unless(-e $lock)
                print "X-Cache: HIT from Raptor\r\n" if (-e $file && -s $file);
                print "Connection: close\r\n";
                print $l;
                &sendthis($file) if (-e $file && -s $file);
                $cachethis=$file;
            else
                print $l;
        } else {
    } else {
        print $l;
    if($cachethis)
        $file=$cachethis;
        $file=~m#^(.*/)[^/]+$#; $dir=$1;
        $lsize=$cont;
        if(! -e $dir)
            system "mkdir -p $dir";
        while(-e $lock)
            # Hmmm... already being pulled.
            sleep 3;
        if(open(OUT,">$lock"))
            print OUT "$$\n";
            print OUT "$url\n";
            print OUT "$file\n";
            close(OUT);
            $cachethis=0 unless( open(OUT,">$file") );
            unlink "$lock" unless($cachethis);
        $xaddr=inet_ntoa($iaddr);
        $lsize=0 if(!$lsize);
        print LOG time.".000 $begin $xfor TCP_MISS/$codi $lsize $type http://$url - DIRECT/$xaddr $xtype\n" if($log);
    if($cont)
        while($cont)
            $in=read SOCK, $buf, ($cont < 512 ? $cont : 512 );
            $cont -= $in;
            print $buf;
            print OUT $buf if($cachethis);
            last if($count < 0);
    } else {
        $loop=0;
        while(<SOCK>)
            print;
            print OUT if($cachethis);
            $loop++ if (/^$/);
            last if($loop == 100);
    close(SOCK);
    unlink "$lock" if($cachethis);
    close(OUT);
    exit;
    email/msn alexsandro@nerdz-x.com
    edit: segue arquivos em anexo. "comente"
  2. Este script roda junto ao Squid/Lusca, como implementa-lo.
  3. os arquivos de configuração estão no arquivo em anexo é só adicionar como no exemplo.
    qq coisa tamo aqui.
  4. pelo que pude ver nestes scripts o squid chama o script que roda em uma determinada porta?
    todos os downloads feitos por ele são gravados em apenas um diretório? ou para cada plugin será criado um diretório distinto?
    ele terá controle de idade do arquivo?
    aqui tenho 22GB de arquivos do windows update, no caso seria apenas ter ester arquivos no diretório que ele mandará para o cliente sem precisar baixar novamente?
    valeu
  5. seria interessante colocar algumas variáveis no script como por exemplo para especificar os caminhos de onde estão os arquivos, seria mais fácil para manutenção e implementação.
  1. alternativa ao rpmfind
    Por whinston no fórum Servidores de Rede
    Último Post: 18-05-2005, 18:16
  2. PostgreSQL desconecta ao chegar em 1982 registros
    Por ajsmit no fórum Servidores de Rede
    Respostas: 14
    Último Post: 13-05-2004, 09:04
  3. servidor identico ao outro em tempo real
    Respostas: 14
    Último Post: 27-02-2003, 17:35
  4. Aos gurus em seguranca (Melhorar firewall!)
    Último Post: 17-02-2003, 12:41
  5. Alternativa ao PHPNuke.
    Por HunTer no fórum Servidores de Rede
    Respostas: 5
    Último Post: 21-01-2003, 16:44
