Pessoal preciso aplicar este código que é um patch para o kernel só que não sei como transformar este código em um arquivo "patch" para o kernel.
Alguem tem noção de como aplico isso ao kernel ?
diff --git a/drivers/parport/parport_pc.c b/drivers/parport/parport_pc.c
index 2597145..85204f0 100644
--- a/drivers/parport/parport_pc.c
+++ b/drivers/parport/parport_pc.c
@@ -2908,6 +2908,7 @@ enum parport_pc_pci_cards {
netmos_9805,
netmos_9815,
netmos_9901,
+ netmos_9865,
quatech_sppxp100,
@@ -2989,6 +2990,7 @@ static struct parport_pc_pci {
/* netmos_9805 */ { 1, { { 0, -1 }, } },
/* netmos_9815 */ { 2, { { 0, -1 }, { 2, -1 }, } },
/* netmos_9901 */ { 1, { { 0, -1 }, } },
+ /* netmos_9865 */ { 1, { { 0, -1 }, } },
/* quatech_sppxp100 */ { 1, { { 0, 1 }, } },
@@ -3092,6 +3094,10 @@ static const struct pci_device_id parport_pc_pci_tbl[] = {
PCI_ANY_ID, PCI_ANY_ID, 0, 0, netmos_9815 },
{ PCI_VENDOR_ID_NETMOS, PCI_DEVICE_ID_NETMOS_9901,
0xA000, 0x2000, 0, 0, netmos_9901 },
+ { PCI_VENDOR_ID_NETMOS, PCI_DEVICE_ID_NETMOS_9865,
+ 0xA000, 0x1000, 0, 0, netmos_9865 },
+ 0xA000, 0x2000, 0, 0, netmos_9865 },
/* Quatech SPPXP-100 Parallel port PCI ExpressCard */
{ PCI_VENDOR_ID_QUATECH, PCI_DEVICE_ID_QUATECH_SPPXP_100,
PCI_ANY_ID, PCI_ANY_ID, 0, 0, quatech_sppxp100 },
diff --git a/drivers/serial/8250_pci.c b/drivers/serial/8250_pci.c
index b28af13..8b18c3c 100644
--- a/drivers/serial/8250_pci.c
+++ b/drivers/serial/8250_pci.c
@@ -760,7 +760,8 @@ static int pci_netmos_init(struct pci_dev *dev)
/* subdevice 0x00PS means <P> parallel, <S> serial */
unsigned int num_serial = dev->subsystem_device & 0xf;
- if (dev->device == PCI_DEVICE_ID_NETMOS_9901)
+ if ((dev->device == PCI_DEVICE_ID_NETMOS_9901) ||
+ (dev->device == PCI_DEVICE_ID_NETMOS_9865))
return 0;
if (dev->subsystem_vendor == PCI_VENDOR_ID_IBM &&
dev->subsystem_device == 0x0299)
@@ -1479,6 +1480,7 @@ enum pci_board_num_t {
pbn_b0_bt_1_115200,
pbn_b0_bt_2_115200,
+ pbn_b0_bt_4_115200,
pbn_b0_bt_8_115200,
pbn_b0_bt_1_460800,
@@ -1703,6 +1705,12 @@ static struct pciserial_board pci_boards[] __devinitdata = {
.base_baud = 115200,
.uart_offset = 8,
+ [pbn_b0_bt_4_115200] = {
+ .flags = FL_BASE0|FL_BASE_BARS,
+ .num_ports = 4,
+ .base_baud = 115200,
+ .uart_offset = 8,
[pbn_b0_bt_8_115200] = {
.num_ports = 8,
@@ -3649,6 +3657,18 @@ static struct pci_device_id serial_pci_tbl[] = {
0, 0, pbn_b0_1_115200 },
+ * Best Connectivity PCI Multi I/O cards
+ 0xA000, 0x1000,
+ 0, 0, pbn_b0_1_115200 },
+ 0xA000, 0x3004,
+ 0, 0, pbn_b0_bt_4_115200 },
* These entries match devices with class COMMUNICATION_SERIAL,
* COMMUNICATION_MODEM or COMMUNICATION_MULTISERIAL
diff --git a/include/linux/pci_ids.h b/include/linux/pci_ids.h
index 84cf1f3..b2c0bf3 100644
--- a/include/linux/pci_ids.h
+++ b/include/linux/pci_ids.h
@@ -2675,6 +2675,7 @@
#define PCI_DEVICE_ID_NETMOS_9835 0x9835
#define PCI_DEVICE_ID_NETMOS_9845 0x9845
#define PCI_DEVICE_ID_NETMOS_9855 0x9855
+#define PCI_DEVICE_ID_NETMOS_9865 0x9865
#define PCI_DEVICE_ID_NETMOS_9901 0x9901
#define PCI_VENDOR_ID_3COM_2 0xa727
Citação
