    Padrão MSN - Proxy - CentOS e Fedora
    Olá, não consigo instalar o MSN - Proxy
    Preciso fazer rodar no CentOS ou Fedora mas tenho problemas com lmysqlclient
    Provavelmente seja porque pacote libmysqlclient15-dev não existe nos repositórios YUM !
    Alguem tem um link do .rpm ou algo assim ?
    Procurei e não achei até no GOOOGLE !!!
    Testei no Debian e ele funcionou perfeitamente via apt-get !!!
    Mas minha necessidade é nos Red Hat
    Caso puder me ajudar ! Agradeço !
    Padrão Re: MSN - Proxy - CentOS e Fedora
    http://dev.mysql.com/get/Downloads/M...ftp.mysql.com/
    # rpm -ivh MySQL-shared-compat-5.1.51-1.rhel5.i386.rpm
    [[email protected] msn-proxy-0.7]$ uname -a
    Linux pandora.jotatec.pri.br 2.6.18-194.17.1.el5 #1 SMP Wed Sep 29 12:51:33 EDT 2010 i686 i686 i386 GNU/Linux
    $ [[email protected] msn-proxy-0.7]$ make all
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c msn-proxy.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c server.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c sb.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c command.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c config.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c net-io.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c client.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c syslog.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c ns.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c mysql.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c sql.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c protocol.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c check-cmd.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c contacts.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c msg.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c p2p.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c user.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c string.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c io.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c sig.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c fmt.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c xml.c
    cc -g -Wall -O2 -pipe -I/usr/local/include -I/usr/local/include -fno-builtin-log -c ctl.c
    cc -o msn-proxy msn-proxy.o server.o sb.o command.o config.o net-io.o client.o syslog.o ns.o mysql.o sql.o protocol.o check-cmd.o contacts.o msg.o p2p.o user.o string.o io.o sig.o fmt.o xml.o ctl.o -L/usr/local/lib -levent -L/usr/local/lib/mysql -lmysqlclient
    RESOLVIDO !!!
    Instalei o pacote mysql-devel e o libevent-devel.
    Alterei o Makefile de forma que fique assim:
    # FreeBSD
    #MYSQLINC=/usr/local/include
    #MYSQLLIB=/usr/local/lib/mysql
    # Linux (most)
    MYSQLINC=/usr/include/mysql
    MYSQLLIB=/usr/lib/mysql/
    Única coisa que deu zica no CentOS é na hora de iniciar o software ele não cria as tabelas no MySQL .... mas enfim, vou migrar para o Fedora por enquanto !
    Citação Postado originalmente por juniorphy Ver Post
    RESOLVIDO !!!
    # FreeBSD
    # Linux (most)
    Obrigado por compartilhar a solução !
    Alam Dias
    Padrão Aos amigos do MSN-PROXY
    Consegui Instalar o MSN Proxy por aqui ....
    LINK DE TUTORIAL MSN-PROXY
    Única coisa que mudei é que meu CentOS é 32 bits aí removi o 64 das libs nas linhas de comando.
    Mas veio a próxima dúvida:
    Digamos que tenho 3 Placas de Rede !
    eth0 - Link de Internet - 10.1.1.0/24
    eth1 - Rede 01 - Setor Financeiro da Empresa - 192.168.0.0/24
    eth2 - Rede 02 - Setor Vendas da Empresa - 172.143.0.0/24
    Existe a posibilidade de eu instalar o MSN-PROXY para que monitore Simultaneamente as duas Interfaces (eth1/eth2) ?
    Eu criaria duas tabelas ?
    Como faria ?
    Se alguem utilizar esse Software e puder ajudar ... fico grato !
    Valeus ....
    Última edição por juniorphy; 23-12-2010 às 11:04.
