## Squid normally listens to port 3128
http_port 8080
hierarchy_stoplist cgi-bin ?
error_directory /usr/share/squid/errors/pt-br/
#We recommend you to use the following two lines.
cache deny QUERY
# Apache to signal ETag correctly on such responses
acl apache rep_header Server ^Apache
###broken_vary_encoding allow apache
#Default:
cache_mem 512 MB
#Default:
maximum_object_size_in_memory 128 KB
maximum_object_size 512 MB
minimum_object_size 0 KB
cache_swap_low 90
cache_swap_high 95
cache_dir diskd /cache 8192 32 256 Q1=64 Q2=72
cache_replacement_policy heap LFUDA
memory_replacement_policy heap GDSF
access_log /var/log/squid/access.log squid
cache_log /var/log/squid/cache.log
cache_store_log /var/log/squid/store.log
pid_filename /var/run/squid.pid
auth_param basic program /usr/lib64/squid/squid_ldap_auth -R -b "ou=Usuarios,o=cmc" -f "uid=%s" -d one -h 127.0.0.1
auth_param basic children 5
auth_param basic realm (cmc Solucoes): "Entre com seu usuario e senha."
auth_param basic credentialsttl 2 hours
auth_param basic casesensitive off
external_acl_type ldap_group %LOGIN /usr/lib64/squid/squid_ldap_group -d -b "ou=Grupos,o=cmc" -B "ou=Usuarios,o=cmc" -f "(&(memberuid=%u)(cn=%g))" -h 172.16.1.1
#Suggested default:
refresh_pattern . 0 20% 4320
#Recommended minimum configuration:
acl all src all
acl SSL_ports port 443 563
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 443 563 # https
acl Safe_ports port 901 # swat
acl purge method PURGE
acl CONNECT method CONNECT
acl rede_local src 172.16.1.0/255.255.255.0
acl sites_proibidos url_regex "/root/gerencia/sites_proibidos.txt"
acl sites_permitidos url_regex "/root/gerencia/sites_permitidos.txt"
acl extban url_regex -i "/root/gerencia/extban"
acl libera_msn url_regex -i "/root/gerencia/sites_msn.txt"
acl autenticacao proxy_auth REQUIRED
#acl conectivadesocial dstdomain
acl grupo_livre external ldap_group grp-internet-livre
acl grupo_restrito external ldap_group grp-internet-restrita
acl grupo_bloqueado external ldap_group grp-internet-bloqueado
acl grupo_restrito_horario external ldap_group grp-internet-horario
acl grupo_msn external ldap_group grp-internet-msn
acl horario_permitido time SMTWHFA 12:00-14:00 18:00-23:59 00:01-07:59
# Only allow cachemgr access from localhost
http_access deny manager
http_access deny purge
# Deny requests to unknown ports
http_access deny !Safe_ports
# Deny CONNECT to other than SSL ports
# INSERT YOUR OWN RULE(S) HERE TO ALLOW ACCESS FROM YOUR CLIENTS
## ACL PARA O GRUPO LIVRE
http_access allow grupo_livre
## ACL PARA LIBERAR O MSN
http_access deny libera_msn !grupo_msn
## ACL PARA O GRUPO HORARIO
http_access deny sites_proibidos !sites_permitidos !horario_permitido
http_access deny extban !horario_permitido
http_access allow grupo_restrito_horario
## ACL PARA O GRUPO RESTRITO
## ACL PARA O GRUPO BLOQUEADO
http_access deny all !sites_permitidos
http_access allow grupo_bloqueado
##http_access allow autenticacao
http_access allow rede_local
# And finally deny all other access to this proxy
http_access allow localhost
# Insert your own rules here.
http_reply_access allow all
#Allow ICP queries from everyone
icp_access allow all
visible_hostname lx-cmc-01
# Leave coredumps in the first cache dir
##coredump_dir /var/spool/squid
coredump_dir /cache
