  1. Prezados,
    Estou com uma duvida. Estou executando o script abaixo:
    Código bash:
    ! /bin/sh
    # [EMAIL="latigid010@yahoo.com"]latigid010@yahoo.com[/EMAIL]
    # 01/06/2000
    #  This Nagios plugin was created to check Oracle status
    PROGNAME=`basename $0`
    PROGPATH=`echo $0 | sed -e 's,[\\/][^\\/][^\\/]*$,,'`
    REVISION=`echo '$Revision: 1749 $' | sed -e 's/[^0-9.]//g'`
    . $PROGPATH/utils.sh
    print_usage() {
      echo "Usage:"
      echo "  $PROGNAME --tns <Oracle Sid or Hostname/IP address>"
      echo "  $PROGNAME --db <ORACLE_SID>"
      echo "  $PROGNAME --login <ORACLE_SID>"
      echo "  $PROGNAME --cache <ORACLE_SID> <USER> <PASS> <CRITICAL> <WARNING>"
      echo "  $PROGNAME --tablespace <ORACLE_SID> <USER> <PASS> <TABLESPACE> <CRITICAL> <WARNING>"
      echo "  $PROGNAME --oranames <Hostname>"
      echo "  $PROGNAME --help"
      echo "  $PROGNAME --version"
    print_help() {
      print_revision $PROGNAME $REVISION
      echo ""
      print_usage
      echo ""
      echo "Check Oracle status"
      echo ""
      echo "--tns SID/IP Address"
      echo "   Check remote TNS server"
      echo "--db SID"
      echo "   Check local database (search /bin/ps for PMON process) and check"
      echo "   filesystem for sgadefORACLE_SID.dbf"
      echo "--login SID"
      echo "   Attempt a dummy login and alert if not ORA-01017: invalid username/password"
      echo "--cache"
      echo "   Check local database for library and buffer cache hit ratios"
      echo "       --->  Requires Oracle user/password and SID specified."
      echo "               --->  Requires select on v_$sysstat and v_$librarycache"
      echo "--tablespace"
      echo "   Check local database for tablespace capacity in ORACLE_SID"
      echo "       --->  Requires Oracle user/password specified."
      echo "               --->  Requires select on dba_data_files and dba_free_space"
      echo "--oranames Hostname"
      echo "   Check remote Oracle Names server"
      echo "--help"
      echo "   Print this help screen"
      echo "--version"
      echo "   Print version and license information"
      echo ""
      echo "If the plugin doesn't work, check that the ORACLE_HOME environment"
      echo "variable is set, that ORACLE_HOME/bin is in your PATH, and the"
      echo "tnsnames.ora file is locatable and is properly configured."
      echo ""
      echo "When checking local database status your ORACLE_SID is case sensitive."
      echo ""
      echo "If you want to use a default Oracle home, add in your oratab file:"
      echo "*:/opt/app/oracle/product/7.3.4:N"
      echo ""
      support
    case "$1" in
    1)
        cmd='--tns'
    2)
        cmd='--db'
        cmd="$1"
    esac
    # Information options
    case "$cmd" in
    --help)
            print_help
        exit $STATE_OK
    -h)
            print_help
        exit $STATE_OK
    --version)
        exit $STATE_OK
    -V)
        exit $STATE_OK
    esac
    # Hunt down a reasonable ORACLE_HOME
    if [ -z "$ORACLE_HOME" ] ; then
        # Adjust to taste
        for oratab in /var/opt/oracle/oratab /etc/oratab
        do
        [ ! -f $oratab ] && continue
        ORACLE_HOME=`IFS=:
            while read SID ORACLE_HOME junk;
            do
                if [ "$SID" = "$2" -o "$SID" = "*" ] ; then
                    echo $ORACLE_HOME;
                    exit;
                fi;
            done < $oratab`
        [ -n "$ORACLE_HOME" ] && break
        done
    fi
    # Last resort
    [ -z "$ORACLE_HOME" -a -d $PROGPATH/oracle ] && ORACLE_HOME=$PROGPATH/oracle
    if [ "$cmd" != "--db" ]; then
        if [ -z "$ORACLE_HOME" -o ! -d "$ORACLE_HOME" ] ; then
            echo "Cannot determine ORACLE_HOME for sid $2"
            exit $STATE_UNKNOWN
        fi
    fi
    PATH=$PATH:$ORACLE_HOME/bin
    LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$ORACLE_HOME/lib
    export ORACLE_HOME PATH LD_LIBRARY_PATH
    case "$cmd" in
    --tns)
        tnschk=` tnsping $2`
        tnschk2=` echo  $tnschk | grep -c OK`
        if [ ${tnschk2} -eq 1 ] ; then
        tnschk3=` echo $tnschk | sed -e 's/.*(//' -e 's/).*//'`
        echo "OK - reply time ${tnschk3} from $2"
        exit $STATE_OK
        else
        echo "No TNS Listener on $2"
        exit $STATE_CRITICAL
        fi
    --oranames)
        namesctl status $2 | awk '
        /Server has been running for:/ {
        msg = "OK: Up"
        for (i = 6; i <= NF; i++) {
            msg = msg " " $i
        status = '$STATE_OK'
        /error/ {
        msg = "CRITICAL: " $0
        status = '$STATE_CRITICAL'
        END {
        print msg
        exit status
    --db)
        pmonchk=`ps -ef | grep -v grep | grep -c "ora_pmon_${2}$"`
        if [ ${pmonchk} -ge 1 ] ; then
        echo "${2} OK - ${pmonchk} PMON process(es) running"
        exit $STATE_OK
        #if [ -f $ORACLE_HOME/dbs/sga*${2}* ] ; then
        #if [ ${pmonchk} -eq 1 ] ; then
        #utime=`ls -la $ORACLE_HOME/dbs/sga*$2* | cut -c 43-55`
            #echo "${2} OK - running since ${utime}"
            #exit $STATE_OK
        #fi
        else
        echo "${2} Database is DOWN"
        fi
    --login)
        loginchk=`sqlplus dummy/user@$2 < /dev/null`
        loginchk2=` echo  $loginchk | grep -c ORA-01017`
        if [ ${loginchk2} -eq 1 ] ; then
        echo "OK - dummy login connected"
        exit $STATE_OK
        else
        loginchk3=` echo "$loginchk" | grep "ORA-" | head -1`
        echo "CRITICAL - $loginchk3"
        fi
    --cache)
        if [ ${5} -gt ${6} ] ; then
        echo "UNKNOWN - Warning level is less then Crit"
        exit $STATE_UNKNOWN
        fi
        result=`sqlplus -s ${3}/${4}@${2} << EOF
    set pagesize 0
    set numf '9999999.99'
    select (1-(pr.value/(dbg.value+cg.value)))*100
    from v\\$sysstat pr, v\\$sysstat dbg, v\\$sysstat cg
    where pr.name='physical reads'
    and dbg.name='db block gets'
    and cg.name='consistent gets';
    EOF`
        if [ -n "`echo $result | grep ORA-`" ] ; then
          error=` echo "$result" | grep "ORA-" | head -1`
          echo "CRITICAL - $error"
        fi
        buf_hr=`echo "$result" | awk '/^[0-9\. \t]+$/ {print int($1)}'`
        buf_hrx=`echo "$result" | awk '/^[0-9\. \t]+$/ {print $1}'`
    set pagesize 0
    select sum(lc.pins)/(sum(lc.pins)+sum(lc.reloads))*100
    from v\\$librarycache lc;
    EOF`
        fi
        lib_hr=`echo "$result" | awk '/^[0-9\. \t]+$/ {print int($1)}'`
        lib_hrx=`echo "$result" | awk '/^[0-9\. \t]+$/ {print $1}'`
        if [ $buf_hr -le ${5} -o $lib_hr -le ${5} ] ; then
          echo "${2} CRITICAL - Cache Hit Rates: $lib_hrx% Lib -- $buf_hrx% Buff|lib=$lib_hrx%;${6};${5};0;100 buffer=$buf_hrx%;${6};${5};0;100"
        fi
        if [ $buf_hr -le ${6} -o $lib_hr -le ${6} ] ; then
          echo "${2} WARNING  - Cache Hit Rates: $lib_hrx% Lib -- $buf_hrx% Buff|lib=$lib_hrx%;${6};${5};0;100 buffer=$buf_hrx%;${6};${5};0;100"
        exit $STATE_WARNING
        fi
        echo "${2} OK - Cache Hit Rates: $lib_hrx% Lib -- $buf_hrx% Buff|lib=$lib_hrx%;${6};${5};0;100 buffer=$buf_hrx%;${6};${5};0;100"
        exit $STATE_OK
    --tablespace)
        if [ ${6} -lt ${7} ] ; then
        echo "UNKNOWN - Warning level is more then Crit"
        exit $STATE_UNKNOWN
        fi
    set pagesize 0
    select NVL(b.free,0.0),a.total,100 - trunc(NVL(b.free,0.0)/a.total * 1000) / 10 prc
    from (
    select tablespace_name,sum(bytes)/1024/1024 total
    from dba_data_files group by tablespace_name) A
    LEFT OUTER JOIN
    ( select tablespace_name,sum(bytes)/1024/1024 free
    from dba_free_space group by tablespace_name) B
    ON a.tablespace_name=b.tablespace_name WHERE a.tablespace_name='${5}';
    EOF`
        fi
        ts_free=`echo $result | awk '/^[ 0-9\.\t ]+$/ {print int($1)}'`
        ts_total=`echo $result | awk '/^[ 0-9\.\t ]+$/ {print int($2)}'`
        ts_pct=`echo $result | awk '/^[ 0-9\.\t ]+$/ {print int($3)}'`
        ts_pctx=`echo $result | awk '/^[ 0-9\.\t ]+$/ {print $3}'`
        if [ "$ts_free" -eq "0" "$ts_total" -eq "0" "$ts_pct" -eq "0" ] ; then
            echo "No data returned by Oracle - tablespace $5 not found?"
            exit $STATE_UNKNOWN
        fi
        if [ "$ts_pct" -ge "${6}" ] ; then
          echo "${2} : ${5} CRITICAL - $ts_pctx% used [ $ts_free / $ts_total MB available ]|${5}=$ts_pctx%;${7};${6};0;100"
        fi
        if [ "$ts_pct" -ge "${7}" ] ; then
          echo "${2} : ${5} WARNING  - $ts_pctx% used [ $ts_free / $ts_total MB available ]|${5}=$ts_pctx%;${7};${6};0;100"
        exit $STATE_WARNING
        fi
        echo "${2} : ${5} OK - $ts_pctx% used [ $ts_free / $ts_total MB available ]|${5}=$ts_pctx%;${7};${6};0;100"
        exit $STATE_OK
        print_usage
            exit $STATE_UNKNOWN
    esac
    Ao executa-lo retorna o seguinte:
    Código :
    ./check_oracle_teste: line 269: [: : integer expression expected
    ./check_oracle_teste: line 273: [: : integer expression expected
    ./check_oracle_teste: line 277: [: : integer expression expected
    blah : blah_mh_tables01 OK - % used [  /  MB available ]|blah_mh_tables01=%;80;90;0;100
    Alguem tem alguma luz para me ajudar ?
    Última edição por osmano807; 20-10-2010 às 14:26.
  2. Essas linhas 269, 273 e 277 se referem à linhas que contem expressões condicionais com if.
    Copiei e executei aqui e não foi gerado esse erro.
  1. Dúvida - shell script.
    Por andunno no fórum Servidores de Rede
    Respostas: 6
    Último Post: 11-05-2006, 08:15
  2. Mais cores no Shell. Duvida
    Por Cyber_Punk no fórum Servidores de Rede
    Último Post: 22-07-2003, 16:03
  3. Dúvidas de Shell script
    Por intruder no fórum Servidores de Rede
    Último Post: 26-06-2003, 11:27
  4. Duvidas de shell scrips????????????
    Por intruder no fórum Linguagens de Programação
    Último Post: 25-06-2003, 16:40
  5. Duvida com imap + outlook express!
    Último Post: 18-03-2003, 12:32
