    Padrão Está certo marcação e rotas ?
    Tenho duvidas da marcação e rotas se estão corretas vejo que um link sai muita coisa e outro sai pouca:
    /ip firewall mangle
    add action=accept chain=prerouting comment="Fora Load Balance" disabled=no \
    dst-address-list=loopback in-interface=Local
    add action=mark-connection chain=input comment=\
    "Marca nova conexo de entrada wan1" connection-state=new disabled=no \
    in-interface=pppoe-out1 new-connection-mark=wan1 passthrough=yes
    "Marca nova conexo de entrada wan2" connection-state=new disabled=no \
    in-interface=pppoe-out2 new-connection-mark=wan2 passthrough=yes
    add action=mark-connection chain=prerouting comment=\
    "Marca conexo de entrada estabelecidas wan1" connection-state=established \
    disabled=no in-interface=pppoe-out1 new-connection-mark=wan1 passthrough=\
    yes
    "Marca conexo de entrada estabelecidas wan2" connection-state=established \
    disabled=no in-interface=pppoe-out2 new-connection-mark=wan2 passthrough=\
    yes
    "Marca conexo de entrada relacionadas wan1" connection-state=related \
    yes
    "Marca conexo de entrada relacionadas wan2" connection-state=related \
    yes
    add action=mark-routing chain=output comment=\
    "Marca nova rota de entrada wan1" connection-mark=wan1 disabled=no \
    new-routing-mark=static-wan1 passthrough=yes
    "Marca nova rota de entrada wan2" connection-mark=wan2 disabled=no \
    new-routing-mark=static-wan2 passthrough=no
    add action=mark-connection chain=prerouting comment="Marca trfego que no loca\
    l com rand marca PCC (3 possibilidades) - opo 1" connection-state=new \
    disabled=no dst-address-type=!local in-interface=Local \
    new-connection-mark=wan1_pcc_conn passthrough=yes \
    per-connection-classifier=both-addresses:2/0
    l com rand marca PCC (3 possibilidades) - opo 2" connection-state=new \
    new-connection-mark=wan2_pcc_conn passthrough=yes \
    per-connection-classifier=both-addresses:2/1
    add action=mark-connection chain=prerouting comment="Marca trfego estabelecido\
    \_que no local com rand marca PCC (3 possibilidades) - opo 1" \
    connection-state=established disabled=no dst-address-type=!local \
    in-interface=Local new-connection-mark=wan1_pcc_conn passthrough=yes \
    \_que no local com rand marca PCC (3 possibilidades) - opo 2" \
    in-interface=Local new-connection-mark=wan2_pcc_conn passthrough=yes \
    add action=mark-connection chain=prerouting comment="Marca trfego relacionado \
    connection-state=related disabled=no dst-address-type=!local \
    add action=mark-routing chain=prerouting comment=\
    "Marca encaminhamento para marcar PCC - opo 1" connection-mark=\
    wan1_pcc_conn disabled=no new-routing-mark=wan1 passthrough=yes
    "Marca encaminhamento para marcar PCC - opo 2" connection-mark=\
    wan2_pcc_conn disabled=no new-routing-mark=wan2 passthrough=yes
    /ip route
    add check-gateway=arp comment="Rota esttica - WAN1" disabled=no distance=1 \
    dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=static-wan1 scope=\
    30 target-scope=10
    add check-gateway=arp comment="Rota esttica - WAN2" disabled=no distance=2 \
    dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=static-wan2 scope=\
    30 target-scope=10
    add check-gateway=arp comment="WAN 1 - Distance 1" disabled=no distance=1 \
    dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=wan1 scope=30 \
    target-scope=10
    add check-gateway=arp comment="WAN 1 - Distance 2" disabled=no distance=2 \
    dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=wan1 scope=30 \
    target-scope=10
    add check-gateway=ping comment="" disabled=yes distance=1 dst-address=\
    0.0.0.0/0 gateway=pppoe-out1 routing-mark=wan1 scope=30 target-scope=10
    add check-gateway=arp comment="WAN 2 - Distance 1" disabled=no distance=1 \
    dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=wan2 scope=30 \
    target-scope=10
    add check-gateway=arp comment="WAN 2 - Distance 3" disabled=no distance=2 \
    dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=wan2 scope=30 \
    target-scope=10
    0.0.0.0/0 gateway=pppoe-out2 routing-mark=wan2 scope=30 target-scope=10
    add check-gateway=arp comment="Default Route - Distance 1" disabled=no \
    distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 scope=30 \
    target-scope=10
    add check-gateway=arp comment="Default Route - Distance 3" disabled=no \
    distance=2 dst-address=0.0.0.0/0 gateway=pppoe-out2 scope=30 \
    target-scope=10
    add comment="" disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=Local \
    0.0.0.0/0 gateway=pppoe-out1 scope=30 target-scope=10
    add check-gateway=ping comment="" disabled=yes distance=2 dst-address=\
    0.0.0.0/0 gateway=pppoe-out2 scope=30 target-scope=10
    esta correto minhas rotas e marcações , trabalho com 2 modens em brisge da mesma operadora , ate mais
    Padrão Re: esta certo marcação e rotas ?
    é normal ele usar sempre um mais que outro.
    OK valeu
    são iguais os links mesmo up e down?
    nao é certo um link ficar muito acima do outro não se forem de velocidades diferentes sim é normal pelo que vejo tem um erro não sei se vc quis assim
    se são 2 links para que 4 regras?
    pode usar somente 2
    Padrão Re: Está certo marcação e rotas ?
    to batendo cabeça com isso , que M , nao consigo deixar redondo .
    Links iguais
    Última edição por jmathayde; 09-11-2010 às 12:45.
