    Question Como Melhorar o Desempenho ??
    Olá Amigos,
    será que vcs poderiam me dar uma ajudinha para melhora o desempenho(performace) de meu servidor de Proxy/Cache ??
    Estou começando com um provedor de internet aqui onde moro e estou precisando muito desse servidor!!
    ele tem:
    1GB de Memoria DDR2
    Processador AMD Sempron 1.6Ghz
    Hd de 160GB
    1 placa rede (trabalha em paralelo com o Mikrotik)
    o Squid.conf que eu uso é esse ai
    Código :
    http_port 3128 transparent
    #icp_port 0
    hierarchy_stoplist cgi-bin ?
    cache deny QUERY
    acl apache rep_header Server ^Apache
    broken_vary_encoding allow apache
    cache_mem 100 MB
    maximum_object_size_in_memory 256 KB
    maximum_object_size 512 MB
    minimum_object_size 0 KB
    cache_swap_low 80
    cache_swap_high 85
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 95
    fqdncache_size 1024
    cache_dir ufs /var/spool/squid 100000 16 256
    refresh_pattern . 15 20% 2280
    dns_nameservers 8.8.4.4
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 443 # https
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    http_access allow localhost
    http_access allow all
    http_reply_access allow all
    icp_access allow all
    refresh_pattern -i \.jpg$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.gif$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.png$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.jpeg$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.bmp$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.tif$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.tiff$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.swf$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.exe$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.php$ 0 20% 1440 reload-into-ims
    refresh_pattern -i \.html$ 0 20% 1440 reload-into-ims
    refresh_pattern -i \.htm$ 0 20% 1440 reload-into-ims
    refresh_pattern -i \.shtml$ 0 20% 1440 reload-into-ims
    refresh_pattern -i \.shtm$ 0 20% 1440 reload-into-ims
    refresh_pattern . 0 20% 4320
    #Cache windowsupdate ( Faz cache do Windows Update ) ##
    refresh_pattern windowsupdate.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern download.microsoft.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern [URL="http://www.download.microsoft.com/.*/.%28cab%7Cexe%7Cdll%7Cmsi%29"]www.download.microsoft.com/.*\.(cab|exe|dll|msi)[/URL] 10080 100% 43200 reload-into-ims
    refresh_pattern [URL="http://www.microsoft.com/.*/.%28cab%7Cexe%7Cdll%7Cmsi%29"]www.microsoft.com/.*\.(cab|exe|dll|msi)[/URL] 10080 100% 43200 reload-into-ims
    refresh_pattern au.download.windowsupdate.com/.*\.(cab|exe|dll|msi) 4320 100% 43200 reload-into-ims
    refresh_pattern download.windowsupdate.com/.*\.(cab|exe|dll|msi) 4320 100% 43200 reload-into-ims
    refresh_pattern [URL="http://www.download.windowsupdate.com/.*/.%28cab%7Cexe%7Cdll%7Cmsi%29"]www.download.windowsupdate.com/.*\.(cab|exe|dll|msi)[/URL] 4320 100% 43200 reload-into-ims
    #Cache atulizacao avira ( Faz cache do Avira ) ##
    refresh_pattern personal.avira-update.com/.*\.(cab|exe|dll|msi|gz) 10080 100% 43200 reload-into-ims
    #Cache atualizacao symantec
    refresh_pattern liveupdate.symantecliveupdate.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern symantecliveupdate.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    #Cache avast
    refresh_pattern avast.com/.*\.(vpu|cab|stamp|exe) 10080 100% 43200 reload-into-ims
    #zph_tos_local 0x30
    #zph_tos_peer 0
    #zph_tos_parent off
    #zph_preserve_miss_tos on
    #mime_table /etc/squid/mime.conf
    pid_filename /var/run/proxy.pid
    debug_options ALL,1
    log_fqdn off
    forwarded_for off
    coredump_dir /var/cache/squid
    detect_broken_pconn on
    pipeline_prefetch on
    des de já, muito obrigado !!
    Última edição por osmano807; 07-12-2010 às 13:22.
    Padrão Re: Como Melhorar o Desempenho ??
    Boas
    não sei o numero de clientes que v c têm
    mas acho que esse cpu Sempron para proxy fraquinho
    a proxy usa bastante memoria
    tenta arrumar uns 4 GB de ram
    seria bom vc ter um hd so para o sistema
    e um outro hd so para cache -- performance muito melhor
    e no cache_dir usa a opção diskd
    tenho por enquanto 30 clientes
    e no cache_dir ja mudei para aufs
    Não Registrado(s)
    Padrão LIBERAR AVIRA ANTIVIR NO IPTABLES
    Bom dia,
    Possuo um squid configurado no iptables, porem o Avira antivir nao faz update, ja liberei o PREROUTING e ainda não permite atualizar:
    $IPTABLES -t nat -A PREROUTING -i $IF_TEC -p tcp -d 62.146.66.0/24 --dport $HTTP -j ACCEPT
    $IPTABLES -t nat -A PREROUTING -i $IF_TEC -p tcp -d 80.190.143.0/24 --dport $HTTP -j ACCEPT
    Com o tcpdump:
    12:15:02.252562 IP 192.168.0.80.1121 > 62.146.66.188.www: Flags [.], ack 1, win 64240, length 0
    12:15:02.252799 IP 192.168.0.80.1121 > 62.146.66.188.www: Flags [P.], seq 1:374, ack 1, win 64240, length 373
    12:15:02.252819 IP 62.146.66.188.www > 192.168.0.80.1121: Flags [.], ack 374, win 6432, length 0
    12:15:02.283447 IP 80.190.143.243.www > 192.168.0.80.1120: Flags [.], ack 375, win 6432, length 0
    Se alguem souber como resolver, por favor poste.
    Vlw!
