    Padrão CARGAS IGUAL NO LOAD BALANCE PCC
    galera tow tentando igualar as cargas no LB pcc tah complicado o mesmo esta rodando tudo certo unico problema é que tah consumindo 98% de um unico Link
Nome:	         LoadBalance.jpg
Visualizações:	289
Tamanho: 	158,8 KB
    Padrão Re: CARGAS IGUAL NO LOAD BALANCE PCC
    Boa noite Junior Carvalho olha cara pra gente te ajudar descreva as configurações e equipamentos usados pra pcc
    tamanho dos links se são ip fixo ou via ppoe qual a versão do mk pra gente poder te ajudar ok.
    1 Uso 4 Links Adsl de 16MB cada da mesma operadora
    2 Modens em Brindge
    Uma RB 750 para o LoadBalance
    minha configuraçao tah a seguinte
    MANGLE
    add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=
    pppoe-out1 new-connection-mark=conn_na passthrough=yes
    pppoe-out2 new-connection-mark=conn_nb passthrough=yes
    pppoe-out3 new-connection-mark=conn_nc passthrough=yes
    pppoe-out4 new-connection-mark=conn_nd passthrough=yes
    add action=mark-routing chain=output comment="" connection-mark=conn_na disabled=no new-routing-mark=to_ra passthrough=no
    add action=mark-routing chain=output comment="" connection-mark=conn_nb disabled=no new-routing-mark=to_rb passthrough=no
    add action=mark-routing chain=output comment="" connection-mark=conn_nc disabled=no new-routing-mark=to_rc passthrough=no
    add action=mark-routing chain=output comment="" connection-mark=conn_nd disabled=no new-routing-mark=to_rd passthrough=no
    add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=
    EthClientes new-connection-mark=conn_ma0 passthrough=yes per-connection-classifier=both-addresses:4/0
    EthClientes new-connection-mark=conn_mb1 passthrough=yes per-connection-classifier=both-addresses:4/1
    EthClientes new-connection-mark=conn_mc2 passthrough=yes per-connection-classifier=both-addresses:4/2
    EthClientes new-connection-mark=conn_mc3 passthrough=yes per-connection-classifier=both-addresses:4/3
    add action=mark-routing chain=prerouting comment="" connection-mark=conn_ma0 disabled=no in-interface=
    EthClientes new-routing-mark=to_nra passthrough=no
    add action=mark-routing chain=prerouting comment="" connection-mark=conn_mb1 disabled=no in-interface=
    EthClientesnew-routing-mark=to_nrb passthrough=no
    add action=mark-routing chain=prerouting comment="" connection-mark=conn_mc2 disabled=no in-interface=
    EthClientesnew-routing-mark=to_nrc passthrough=no
    add action=mark-routing chain=prerouting comment="" connection-mark=conn_mc3 disabled=no in-interface=
    EthClientesnew-routing-mark=to_nrd passthrough=no
    ROTA, Aqui em distance você especifica sua rota mais confiavel, creio que seja a do pppoe-out1, então damos distance 1 para ele.
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 scope=30 target-scope=10
    2 dst-address=0.0.0.0/0 gateway=pppoe-out2 scope=30 target-scope=10
    3 dst-address=0.0.0.0/0 gateway=pppoe-out3 scope=30 target-scope=10
    add comment="" disabled=no distance=4 dst-address=0.0.0.0/0 gateway=pppoe-out4 scope=30 target-scope=10
    pppoe-out1 routing-mark=to_nra
    pppoe-out2 routing-mark=to_nrb
    pppoe-out3 routing-mark=to_nrc
    add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out4 routing-mark=to_nrd
    NAT
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=
    pppoe-out1
    pppoe-out2
    pppoe-out3
    add action=masquerade chain=srcnat comment="" disabled=no out-interface=pppoe-out4
    Tentei ajudar o Junior ae, até refiz o load dele que tava cheio de negação ( ! ) nas regras, mas o trafego não se equilibrou, cheguei a conclusão que tem algo errado la com ele, questão de hardware.
    Ele chegou a conclusão que era a RB dele que tava com problemas em algumas portas, e disse ter feito pedido de uma outra RB.
    Esperando a outra chegar ..... dae ele posta os resultados aqui .
