-  Swat - Cups
 Swat - Cups
							Não consegui configurar o Samba pelo terminal, então apelei para o Swat, minha inteção é fazer ocm que o linux imprima em um pc na rede Winxp.
Add a impressora pelo cups, no Swat na sessão printers a impressora add aparece.
Na sessão "Printers" - Clicando no botão "choose"(no Swat), aparece algumas opções, tenho que modificar alguma?
[global]
	dos charset = CP850
	unix charset = UTF-8
	display charset = LOCALE
	workgroup = WORKGROUP
	realm =
	netbios name = 33038872LAB101
	netbios aliases =
	netbios scope =
	server string = %h server (Samba, Ubuntu)
	interfaces =
	bind interfaces only = No
	security = USER
	auth methods =
	encrypt passwords = Yes
	update encrypted = No
	client schannel = Auto
	server schannel = Auto
	allow trusted domains = Yes
	map to guest = Bad User
	null passwords = No
	obey pam restrictions = Yes
	password server = *
	smb passwd file = /etc/samba/smbpasswd
	private dir = /etc/samba
	passdb backend = tdbsam
	algorithmic rid base = 1000
	root directory =
	guest account = nobody
	enable privileges = Yes
	pam password change = Yes
	passwd program = /usr/bin/passwd %u
	passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
	passwd chat debug = No
	passwd chat timeout = 2
	check password script =
	username map =
	password level = 0
	username level = 0
	unix password sync = Yes
	restrict anonymous = 0
	lanman auth = No
	ntlm auth = Yes
	client NTLMv2 auth = No
	client lanman auth = Yes
	client plaintext auth = No
	preload modules =
	use kerberos keytab = No
	log level = 0
	syslog = 0
	syslog only = No
	log file = /var/log/samba/log.%m
	max log size = 1000
	debug timestamp = Yes
	debug prefix timestamp = No
	debug hires timestamp = No
	debug pid = No
	debug uid = No
	enable core files = Yes
	smb ports = 445 139
	large readwrite = Yes
	max protocol = NT1
	min protocol = CORE
	read bmpx = No
	read raw = Yes
	write raw = Yes
	disable netbios = No
	reset on zero vc = No
	acl compatibility = auto
	defer sharing violations = Yes
	nt pipe support = Yes
	nt status support = Yes
	announce version = 4.9
	announce as = NT
	max mux = 50
	max xmit = 16644
	name resolve order = lmhosts wins host bcast
	max ttl = 259200
	max wins ttl = 518400
	min wins ttl = 21600
	time server = No
	unix extensions = Yes
	use spnego = Yes
	client signing = auto
	server signing = No
	client use spnego = Yes
	enable asu support = No
	svcctl list =
	deadtime = 0
	getwd cache = Yes
	keepalive = 300
	lpq cache time = 30
	max smbd processes = 0
	paranoid server security = Yes
	max disk size = 0
	max open files = 10000
	open files database hash size = 10007
	socket options = TCP_NODELAY
	use mmap = Yes
	hostname lookups = No
	name cache timeout = 660
	load printers = Yes
	printcap cache time = 750
	printcap name =
	cups server =
	iprint server =
	disable spoolss = No
	addport command =
	enumports command =
	addprinter command =
	deleteprinter command =
	show add printer wizard = Yes
	os2 driver map =
	mangling method = hash2
	mangle prefix = 1
	max stat cache size = 1024
	stat cache = Yes
	machine password timeout = 604800
	add user script =
	rename user script =
	delete user script =
	add group script =
	delete group script =
	add user to group script =
	delete user from group script =
	set primary group script =
	add machine script =
	shutdown script =
	abort shutdown script =
	username map script =
	logon script =
	logon path = \\%N\%U\profile
	logon drive =
	logon home = \\%N\%U
	domain logons = No
	os level = 100
	lm announce = Auto
	lm interval = 60
	preferred master = Yes
	local master = Yes
	domain master = Auto
	browse list = Yes
	enhanced browsing = Yes
	dns proxy = No
	wins proxy = No
	wins server =
	wins support = No
	wins hook =
	kernel oplocks = Yes
	lock spin time = 200
	oplock break wait time = 0
	ldap admin dn =
	ldap delete dn = No
	ldap group suffix =
	ldap idmap suffix =
	ldap machine suffix =
	ldap passwd sync = no
	ldap replication sleep = 1000
	ldap suffix =
	ldap ssl =
	ldap timeout = 15
	ldap page size = 1024
	ldap user suffix =
	ldap debug level = 0
	ldap debug threshold = 10
	add share command =
	change share command =
	delete share command =
	eventlog list =
	config file =
	preload =
	lock directory =
	pid directory = /var/run/samba
	utmp directory =
	wtmp directory =
	utmp = No
	default service =
	message command =
	get quota command =
	set quota command =
	remote announce =
	remote browse sync =
	socket address = 0.0.0.0
	homedir map = auto.home
	afs username map =
	afs token lifetime = 604800
	log nt token command =
	time offset = 0
	NIS homedir = No
	usershare allow guests = Yes
	usershare max shares = 100
	usershare owner only = Yes
	usershare path = /var/lib/samba/usershares
	usershare prefix allow list =
	usershare prefix deny list =
	usershare template share =
	panic action = /usr/share/samba/panic-action %d
	host msdfs = Yes
	passdb expand explicit = No
	idmap domains =
	idmap backend =
	idmap alloc backend =
	idmap cache time = 900
	idmap negative cache time = 120
	idmap uid =
	idmap gid =
	template homedir = /home/%D/%U
	template shell = /bin/false
	winbind separator = \
	winbind cache time = 300
	winbind enum users = No
	winbind enum groups = No
	winbind use default domain = No
	winbind trusted domains only = No
	winbind nested groups = Yes
	winbind nss info = template
	winbind refresh tickets = No
	winbind offline logon = No
	winbind normalize names = No
	comment =
	path =
	username =
	invalid users = root
	valid users =
	admin users =
	read list =
	write list =
	printer admin =
	force user =
	force group =
	read only = Yes
	acl check permissions = Yes
	acl group control = No
	acl map full control = Yes
	create mask = 0744
	force create mode = 00
	security mask = 0777
	force security mode = 00
	directory mask = 0755
	force directory mode = 00
	directory security mask = 0777
	force directory security mode = 00
	force unknown acl user = No
	inherit permissions = No
	inherit acls = No
	inherit owner = No
	guest only = No
	administrative share = No
	guest ok = No
	only user = No
	hosts allow =
	hosts deny =
	allocation roundup size = 1048576
	aio read size = 0
	aio write size = 0
	aio write behind =
	ea support = No
	nt acl support = Yes
	profile acls = No
	map acl inherit = No
	afs share = No
	block size = 1024
	change notify = Yes
	directory name cache size = 100
	kernel change notify = Yes
	max connections = 0
	min print space = 0
	strict allocate = No
	strict sync = No
	sync always = No
	use sendfile = No
	write cache size = 0
	max reported print jobs = 0
	max print jobs = 1000
	printable = No
	printing = cups
	cups options =
	print command =
	lpq command = %p
	lprm command =
	lppause command =
	lpresume command =
	queuepause command =
	queueresume command =
	printer name =
	use client driver = No
	default devmode = Yes
	force printername = No
	printjob username = %U
	default case = lower
	case sensitive = Auto
	preserve case = Yes
	short preserve case = Yes
	mangling char = ~
	hide dot files = Yes
	hide special files = No
	hide unreadable = No
	hide unwriteable files = No
	delete veto files = No
	veto files =
	hide files =
	veto oplock files =
	map archive = Yes
	map hidden = No
	map system = No
	map readonly = yes
	mangled names = Yes
	mangled map =
	store dos attributes = No
	dmapi support = No
	browseable = Yes
	blocking locks = Yes
	csc policy = manual
	fake oplocks = No
	locking = Yes
	oplocks = Yes
	level2 oplocks = Yes
	oplock contention limit = 2
	posix locking = Yes
	strict locking = Auto
	share modes = Yes
	dfree cache time = 0
	dfree command =
	copy =
	include =
	preexec =
	preexec close = No
	postexec =
	root preexec =
	root preexec close = No
	root postexec =
	available = Yes
	volume =
	fstype = NTFS
	set directory = No
	wide links = Yes
	follow symlinks = Yes
	dont descend =
	magic script =
	magic output =
	delete readonly = No
	dos filemode = No
	dos filetimes = Yes
	dos filetime resolution = No
	fake directory create times = No
	vfs objects =
	msdfs root = No
	msdfs proxy =
[printers]
	comment = All Printers
	path = /var/spool/samba
	create mask = 0700
	printable = Yes
	browseable = No
[print$]
	comment = Printer Drivers
	path = /var/lib/samba/printers
