Foi lançada hoje dia 31/03/11 a versão estável do routerOS Mikrotik.
What's new in 5.0 (2011-Mar-31 11:33)
route - fixed cause of crashes when handling multipath routes; *)
route - fixed limit on maximum active IPv6 route count, was causing issues with more than 2000 active routes; *)
ipsec - added command kill-connections under remote-peers; *)
ipsec - fix responder side phase2 negotiation problem which prevented more than one Windows7 host to initiate SA; *)
fixed vrrp - interface was invalid after undoing remove; *)
winbox - added more detailed /interface ethernet stats; *)
winbox - added ability to send e-mail; *)
winbox - added missing 'set-metric' parameter in 'Routing/Prefix List'; *)
wireless - 802.11 dynamic distance fix; *)
fixed problem - packages could not be uninstalled if disk was full; *)
fixed problem - some of the RouterBOARDS did not reboot properly sometimes; *)
fixed problem - VLANs on bridge interface did not work; *)
ssh - client supports public key authentication;
Ja estava usando a versão 5.0 rc11 ja estava muito madura, agora com essas correções creio que esteja bem melhor.
Pessoal que ja usava tbm deve ter percebido o bug de vlans em bridge que foi corrigo.
Para quem faz acesso ssh com chave pública tbm deva ter notado alguns bus que foi corrigido nesta versão.
Link para download aqui:
versão x86 http://download.mikrotik.com/all_packages-x86-5.0.zip
- x86 does not currently support Nv2 (requires RouterBOARD hardware)
x86 may be supported in the future
versão mipsbe 400, 700 series e afins http://download.mikrotik.com/all_pac...mipsbe-5.0.zip
Citação
