Ola amigos estou com um problema com meu squid ele esta fazendo puco cache .
usando o Debian 6
Core i5 650
4 GB memoria ddr3
800 Gb disponivel pra cache 7200rpm
Aqui meu scripit do squid.
############## Scripit #####################
http_port 3128 transparent
visible_hostname fenix
# Configuraç do cache
cache_mem 3200 MB
maximum_object_size_in_memory 8 MB
maximum_object_size 1024 MB
minimum_object_size 0 KB
cache_swap_low 85
cache_swap_high 90
cache_dir ufs /var/spool/squid 125000 64 256
# Localizaç do log de acessos do Squid
dns_nameservers 200.225.197.37 200.225.197.17
refresh_pattern . 15 20% 2280
acl all src 0.0.0.0/0.0.0.0
acl SSL_ports port 443 563
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl purge method PURGE
acl CONNECT method CONNECT
http_access deny manager
http_access deny purge
http_access deny !Safe_ports
#Erros pagina
http_access allow localhost
http_access allow wifi
# Bloqueia acessos externos
http_access deny all
########### fim do scripit ##############
