boa noite pessoal do under a seguir posto o script para vcs darem uma olhada se tem alguma coisa errada com o load . Sendo que os 3 modems estão em bridge desde ja agradeço
/ip firewall mangle
add action=accept chain=prerouting comment="\"FORA DO LOADBALACED\"" disabled=no dst-address-list=!loopback in-interface=!ether4
add action=mark-connection chain=input comment="\"Make the packet leaves via same interface\"" connection-state=new disabled=no in-interface=!pppoe-out1 \
new-connection-mark=no-mark passthrough=yes
add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=!pppoe-out2 new-connection-mark=no-mark passthrough=yes
add action=mark-connection chain=input comment="" connection-state=new disabled=no in-interface=!pppoe-out3 new-connection-mark=no-mark passthrough=yes
add action=mark-routing chain=output comment="" connection-mark=conn_na disabled=no new-routing-mark=to_ra passthrough=no
add action=mark-routing chain=output comment="" connection-mark=conn_nb disabled=no new-routing-mark=to_rb passthrough=no
add action=mark-routing chain=output comment="" connection-mark=conn_nc disabled=no new-routing-mark=to_rc passthrough=no
add action=mark-connection chain=prerouting comment="\"PCC Balance\"" disabled=no dst-address-type=!local in-interface=ether4 new-connection-mark=conn_ma0 \
passthrough=yes per-connection-classifier=both-addresses-and-ports:3/0
add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=ether4 new-connection-mark=conn_mb1 passthrough=yes \
per-connection-classifier=both-addresses-and-ports:3/1
add action=mark-connection chain=prerouting comment="" disabled=no dst-address-type=!local in-interface=ether4 new-connection-mark=conn_mc2 passthrough=yes \
per-connection-classifier=both-addresses-and-ports:3/2
add action=mark-routing chain=prerouting comment="\"Marking all the packets\"" connection-mark=conn_ma0 disabled=no in-interface=ether4 new-routing-mark=\
to_nra passthrough=no
add action=mark-routing chain=prerouting comment="" connection-mark=conn_mb1 disabled=no in-interface=ether4 new-routing-mark=to_nrb passthrough=no
add action=mark-routing chain=prerouting comment="" connection-mark=conn_mc2 disabled=no in-interface=ether4 new-routing-mark=to_nrc passthrough=no
/ip route
add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 routing-mark=to_nra scope=30 target-scope=10
add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out2 routing-mark=to_nrb scope=30 target-scope=10
add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out3 routing-mark=to_nrc scope=30 target-scope=10
add check-gateway=ping comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 scope=30 target-scope=10
add check-gateway=ping comment="" disabled=no distance=2 dst-address=0.0.0.0/0 gateway=pppoe-out2 scope=30 target-scope=10
add check-gateway=ping comment="" disabled=no distance=3 dst-address=0.0.0.0/0 gateway=pppoe-out3 scope=30 target-scope=10
/ip firewall nat
add action=masquerade chain=srcnat comment="\"Masquerade Interfaces\"" disabled=no out-interface=!pppoe-out1
add action=masquerade chain=srcnat comment="" disabled=no out-interface=!pppoe-out2
add action=masquerade chain=srcnat comment="" disabled=no out-interface=!pppoe-out3
			 Ajuda LOAD BALANCE 3 LINKS ADSL
						 Citação
  Citação
