    Padrão Problema com CUPS
    Olá, estou montando um servidor de impressão e tenho que colocar a permissões para usuarios, usuarios comuns só podem imprimir e usuario admins e suporte pode gerenciar e cancelar os jobs. Na hora de autenticação do CUPS eu só consigo acessar com o usuario root, mas preciso fazer a autenticação com o admin e o suporte. Já tentei adicionar os usuarios ao grupo lpadmin e não du certo.
    Aque está a minha configuração.
    # Administrator user group...
    SystemGroup lpadmin, admin,suporte
    #SystemGroup lpadmin
    AuthType Basic
    #Require user @Sytem
    #AuthClass Group
    #Group admins
    #User admin
    #DefaultEncryption Never
    # Only listen for connections from the local machine.
    Port 631
    Listen 192.168.6.2:631
    Listen localhost:631
    Listen /var/run/cups/cups.sock
    # Show shared printers on the local network.
    Browsing On
    BrowseOrder allow,deny
    BrowseAllow all
    # Default authentication type, when authentication is required...
    #DefaultAuthType Basic
    AuthClass Group
    #AuthGroupName admins
    # Restrict access to the server...
    < Location />
    # Group admins
    AuthType Basic
    Allow from all
    Order allow,deny
    < /Location>
    # Restrict access to the admin pages...
    < Location /admin>
    AuthType Basic
    AuthClass Group
    Allow from all
    Order allow,deny
    < /Location>
    # Restrict access to configuration files...
    < Location /admin/conf>
    Allow from all
    AuthType Default
    Require user @SYSTEM
    Order allow,deny
    < /Location>
    # Set the default printer/job policies...
    < Policy default>
    # Job-related operations must be done by the owner or an administrator...
    <Limit Send-Document Send-URI Hold-Job Release-Job Restart-Job Purge-Jobs Set-Job-Attributes Create-Job-Subscription Renew-Subscription Cancel-Subscription Get-Notifications Reprocess-Job Cancel-Current-Job Suspend-Current-Job Resume-Job CUPS-Move-Job>
    Require user @OWNER @SYSTEM
    Order deny,allow
    </Limit>
    # All administration operations require an administrator to authenticate...
    <Limit CUPS-Add-Modify-Printer CUPS-Delete-Printer CUPS-Add-Modify-Class CUPS-Delete-Class CUPS-Set-Default>
    AuthType Default
    Order deny,allow
    </Limit>
    # All printer operations require a printer operator to authenticate...
    <Limit Pause-Printer Resume-Printer Enable-Printer Disable-Printer Pause-Printer-After-Current-Job Hold-New-Jobs Release-Held-New-Jobs Deactivate-Printer Activate-Printer Restart-Printer Shutdown-Printer Startup-Printer Promote-Job Schedule-Job-After CUPS-Accept-Jobs CUPS-Reject-Jobs>
    AuthType Default
    Order deny,allow
    </Limit>
    # Only the owner or an administrator can cancel or authenticate a job...
    <Limit Cancel-Job CUPS-Authenticate-Job>
    Order deny,allow
    </Limit>
    <Limit All>
    Order deny,allow
    </Limit>
    < /Policy>
    # End of "$Id: cupsd.conf.in 7199 2008-01-08 00:16:30Z mike $".
    Padrão Re: Problema com CUPS
    Citação Postado originalmente por EduTacara Ver Post
    AuthType Basic
    #AuthClass Group
    #Group admins
    #User admin
    Port 631
    Browsing On
    BrowseAllow all
    AuthClass Group
    < Location />
    # Group admins
    AuthType Basic
    Allow from all
    Order allow,deny
    < /Location>
    < Location /admin>
    AuthType Basic
    AuthClass Group
    Allow from all
    Order allow,deny
    < /Location>
    Allow from all
    AuthType Default
    Order allow,deny
    < /Location>
    < Policy default>
    Order deny,allow
    </Limit>
    AuthType Default
    Order deny,allow
    </Limit>
    AuthType Default
    Order deny,allow
    </Limit>
    Order deny,allow
    </Limit>
    <Limit All>
    Order deny,allow
    </Limit>
    < /Policy>
    Por que você não consegue? Dá algum tipo de erro é isso?
