  1. Pessoal, bom dia.
    Eu sou muito novato de mikrotik, eu gostaria de fazer algumas regras no firewall do mikrotik, começando travando todo tipo de entrada e saida.
    Meu MK está configurado apenas para rotear a internet.
    Eu quero permitir por hora apenas que tenha navegação HTTP (80) e HTTPS (443).
    Como faço isso?
    Obrigado.
    Abaixo segue as configurações de firewall que estão em funcionamento.
    Citação Postado originalmente por sabiazinho Ver Post
    /ip firewall connection trackingset enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \
    tcp-close-wait-timeout=10s tcp-established-timeout=1d \
    tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
    tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no \
    tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
    /ip firewall filter
    add action=accept chain=input disabled=no protocol=icmp
    add action=accept chain=input connection-state=established connection-type="" \
    disabled=no
    add action=accept chain=input connection-state=related disabled=no
    add action=drop chain=forward connection-type="" disabled=no p2p=bit-torrent
    add action=drop chain=input connection-state=new disabled=no in-interface=\
    LINK-01
    /ip firewall mangle
    add action=mark-connection chain=prerouting comment="Marca\E7\E3o de SMTP" \
    disabled=no dst-port=25 new-connection-mark=smtp_conn passthrough=yes \
    protocol=tcp
    add action=mark-packet chain=prerouting comment="Marca\E7\E3o de Pacote SMTP" \
    disabled=no new-packet-mark=smtp_pack passthrough=yes
    add action=mark-connection chain=prerouting comment="Marca\E7\E3o de HTTP" \
    disabled=no dst-port=80 new-connection-mark=http_conn passthrough=yes \
    protocol=tcp
    add action=mark-packet chain=prerouting comment="Marca\E7\E3o de Pacote HTTP" \
    disabled=no new-packet-mark=http_pack passthrough=yes
    /ip firewall nat
    add action=masquerade chain=srcnat disabled=no out-interface=LINK-01
    /ip firewall service-port
    set ftp disabled=no ports=21
    set tftp disabled=no ports=69
    set irc disabled=no ports=6667
    set h323 disabled=no
    set sip disabled=no ports=5060,5061
    set pptp disabled=no
    Última edição por sabiazinho; 04-07-2011 às 11:19. Razão: Complementando informações...
  2. Citação Postado originalmente por dimasters Ver Post
    Tenta criar 3 regras e colocar no topo com um mesmo comentário
    E cria um scheduler para fazer o controle com scripts que ativem e desativem a regra pelo comentário.
    Abraço
    E se eu simplesmente criar uma regra que dropa todo foward e depois fazer a liberação especifica das portas que eu quero, não funcionaria da mesma forma?
    Criar não vejo necessidade de criar várias regras de NAT.
  1. IPFW bloqueando todas as portas TCP e habilitando algumas
    Por haas no fórum Sistemas Operacionais
    Último Post: 10-04-2005, 05:43
  2. regra para bloquear todas as portas
    Por roggy no fórum Servidores de Rede
    Último Post: 24-05-2004, 11:41
  3. Redirecionamento de todas as portas!!
    Por Perdigao no fórum Servidores de Rede
    Último Post: 23-04-2004, 09:41
  4. Redirecionar todas as portas para o Squid com Iptables
    Por rdsat no fórum Servidores de Rede
    Respostas: 5
    Último Post: 28-11-2003, 15:39
  5. Liberando todas as portas no firewall pra um ip
    Último Post: 26-08-2003, 09:17
