Eu tenho um pendrive da Alcor de 4GB, ele ainda dá sinais de vida mas não consigo mais acessá-lo, quando o coloco no Linux, na porta traseira, a luz acende, o sistema reconhece, mas ele não monta, nem se for manual, no windows a unidade aparece, mas fica com a mensagem "Insira um dispositivo na unidade G:", eis o que o Linux me informa sobre ele.
lsusb
Bus 001 Device 006: ID 058f:1234 Alcor Micro Corp. Flash Drive
lsusb -v
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x058f Alcor Micro Corp.
idProduct 0x1234 Flash Drive
bcdDevice 0.01
iManufacturer 1 Alcor Micro
iProduct 2 Mass Storage Device
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk (Zip)
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered)
lshw
*-usb:0
description: USB Controller
product: N10/ICH 7 Family USB UHCI Controller #1
vendor: Intel Corporation
physical id: 1d
bus info: [email protected]:00:1d.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: uhci bus_master
configuration: driver=uhci_hcd latency=0
resources: irq:23 ioport:bc00(size=32)
*-usb:1
product: N10/ICH 7 Family USB UHCI Controller #2
physical id: 1d.1
bus info: [email protected]:00:1d.1
version: 01
width: 32 bits
clock: 33MHz
resources: irq:19 ioport:b000(size=32)
*-usb:2
product: N10/ICH 7 Family USB UHCI Controller #3
physical id: 1d.2
bus info: [email protected]:00:1d.2
version: 01
width: 32 bits
clock: 33MHz
resources: irq:18 ioport:b400(size=32)
*-usb:3
product: N10/ICH 7 Family USB UHCI Controller #4
physical id: 1d.3
bus info: [email protected]:00:1d.3
version: 01
width: 32 bits
clock: 33MHz
resources: irq:16 ioport:b800(size=32)
*-usb:4
product: N10/ICH 7 Family USB2 EHCI Controller
physical id: 1d.7
bus info: [email protected]:00:1d.7
version: 01
width: 32 bits
clock: 33MHz
capabilities: pm ehci bus_master cap_list
configuration: driver=ehci_hcd latency=0
resources: irq:23 memory:e6104000-e61043ff
Eu tenho outros dispositivos usb funcionando normalmente na máquina, meu mouse por exemplo é usb, tenho outros pendrives que funcionam normalmente, se alguém puder dar uma dica, sobre formatação, não tem como no windows pois ele não é reconhecido, só montado como unidade vazia.
valeu!
