- Ajuda com PCC MK
Ajuda com PCC MK
Olá... Bom Dia a todos...
Estou com o seguinte problema no meu balanceamento e gostaria da ajuda de voces.
Tenho uma Rb 450 fazendo o balanceamento PCC de 2 link
Link 1 ether1 2048 kbps ( Provedor local )
Link 2 ether2 600 kbps ( velox )
O que esta acontecendo é o seguinte, se eu estiver consumindo os 2048 k do meu link 1, ele nao balancea nada para o link 2, o link 2 fica parado.
Mas se qualquer um dos links cair o outro assumi normal.
aqui estao as minhas regras de mangle.
Grato a todos que contrinuirem comigo.
/ip firewall mangle
add action=mark-connection chain=input comment=EthLinkA_conn \
connection-state=new disabled=no in-interface=ether1 new-connection-mark=\
EthLinkA_conn passthrough=yes
add action=mark-connection chain=input comment=EthLinkB_conn \
connection-state=new disabled=no in-interface=ether2 new-connection-mark=\
EthLinkB_conn passthrough=yes
add action=mark-routing chain=output comment=to_EthLinkA connection-mark=\
EthLinkA_conn connection-state=new disabled=no new-routing-mark=\
to_EthLinkA passthrough=no
add action=mark-routing chain=output comment=to_EthLinkB connection-mark=\
EthLinkB_conn connection-state=new disabled=no new-routing-mark=\
to_EthLinkB passthrough=no
add action=accept chain=prerouting comment="out load DST" disabled=no \
dst-address-list=loopback in-interface=ether4
add action=mark-connection chain=prerouting comment=EthLinkA_conn disabled=no \
dst-address-type=!local in-interface=ether1 new-connection-mark=\
EthLinkA_conn passthrough=yes per-connection-classifier=\
both-addresses:4/0
both-addresses:4/1
both-addresses:4/2
both-addresses:4/3
add action=mark-connection chain=prerouting comment=EthLinkB_conn disabled=no \
dst-address-type=!local in-interface=ether2 new-connection-mark=\
EthLinkB_conn passthrough=yes per-connection-classifier=\
both-addresses:4/4
add action=mark-routing chain=prerouting comment=to_EthLinkA connection-mark=\
EthLinkA_conn disabled=no in-interface=ether1 new-routing-mark=\
add action=mark-routing chain=prerouting comment=to_EthLinkB connection-mark=\
EthLinkB_conn disabled=no in-interface=ether2 new-routing-mark=\
Re: Ajuda com PCC MK
bom dia colega
me passe o seu cenario
ether1 (funcao e ip)
ether2 (funcao e ip)
ether3 (funcao e ip)
ether4 (funcao e ip)
ether5 (funcao e ip)
eth1 = recebe o link de 2mb ip 192.168.5.149 gatway 192.168.5.1
eth2 = recebe o link de 600k ip 192.168.1.150 gatway 192.168.1.1
eth3 = links balanceados.
eth4 e 5 em bridge com a eth3
as interfaces que tu recebe o link não devem estar em bridge
