-  Problema com o apt
 Problema com o apt
							Bom dia, apos realizar um apt-get update, estou tendo o seguinte problema:
Use of uninitialized value $text in concatenation (.) or string at /usr/share/perl5/Text/WrapI18N.pm line 101, <GEN1> line 5.
substr outside of string at /usr/share/perl5/Text/WrapI18N.pm line 130, <GEN1> line 5.
Essa linha fica se repetindo infinitamente, e não consigo instalar mais nada. Tentei usar um dpkg --configure -a e o erro se repete.
subprocess script post-installation instalado was interrupted
dpkg: problemas de dependência impedem a configuração de libmagickcore4:
 libmagickcore4 depende de libc6 (>= 2.3.6-6~); porém:
  Pacote libc6 não está configurado ainda.
Se alguem puder me ajudar!
 Re: Problema com o apt
							Poste o conteúdo do sources.list para dar uma idéia.
							o conteudo:
deb ftp://ftp.br.debian.org/debian/ stable main contrib non-free
deb ftp://mirrors.kernel.org/debian/ stable main contrib non-free
deb Index of /debian lenny main contrib
deb Index of /debian lenny main contrib non-free
deb Index of /debian lenny-proposed-updates contrib main
deb Index of /debian-multimedia lenny main
deb Index of /debian oldstable main
deb Index of /debian stable main
deb Index of /debian stable main contrib non-free
deb Index of / stable all
deb Debian -- Security Information lenny/updates main contrib
deb Debian -- Security Information lenny/updates main contrib non-free
deb Debian -- Security Information stable/updates main contrib non-free
deb Index of /debian-volatile lenny/volatile main
deb http://www.backports.org/debian lenny-backports main contrib non-free
deb Debian Multimedia Packages::Home stable main
deb-src ftp://ftp.br.debian.org/debian/ stable main contrib non-free
deb-src ftp://mirrors.kernel.org/debian/ stable main contrib non-free
deb-src Index of /debian lenny main contrib
deb-src Index of /debian lenny main contrib non-free
deb-src Index of /debian lenny-proposed-updates contrib main
deb-src Index of /debian oldstable main
deb-src Index of /debian stable main
deb-src Index of /debian stable main contrib non-free
deb-src Index of / stable all
deb-src Debian -- Security Information lenny/updates main contrib
deb-src Debian -- Security Information lenny/updates main contrib non-free
deb-src Debian -- Security Information stable/updates main contrib non-free
deb-src Index of /debian-volatile lenny/volatile main
deb-src http://www.backports.org/debian lenny-backports main contrib non-free
deb-src Debian Multimedia Packages::Home stable main
							Inicialmente não percebi nada de errado nos índices do sources.list, porém a indicação de outras versões podem gerar problema com versão de aplicativos e isso pode ser o que está acontecendo contigo.
Você usa o Lenny??
Observer que quando você refere "oldstable" e "lenny" nas linhas do source list você está apontando para os pacotes do LENNY, mas quando você aponta para "stable" você indica os pacotes do SQUEEZE. Evite manter essas referências de versões diferentes sempre ativadas.
Comente as linhas e tente o procedimento de update novamente.
							Uso o lenny amigo! Então, comentei aqui, porém continuou com o mesmo problema
							Tente executar o seguinte comando para limpar as indicações para instalação:
# apt-get -f install
							Tentei amigo, tanto o apt-get -f install, como o apt-get -f remove, ambos dao o mesmo problema!
							Digo, o comando é esse, sem nenhuma outra opção.
esse comando executa um flush no status dos arquivos à serem instalados.
						Última edição por  edsonrsjr; 17-08-2011 às 15:39.
							Então amigo, usei o comando ,mas continua dando primeiro erro mencionado!
							Amigo,
Faça o seguinte:
Na linha 130 de /usr/share/perl5/Text/WrapI18N.pm existe isto:
        $r = substr($string, $l);
 Comente e adicione isto no mesmo lugar.
        if (length($text) < $l) {             $r = '';         } else {             $r = substr($string, $l);         }
 Abs.;
							Obrigado amigo, funcionou graças a sua dica!
Obrigado!
							Opa!!
  Estamos aqui pra isso!!
