  1. Pessoal, boa tarde, esse é o script do squid que utilizo
    http_port 3128 transparent
    icp_port 0
    hierarchy_stoplist cgi-bin ?
    cache deny QUERY
    acl apache rep_header Server ^Apache
    broken_vary_encoding allow apache
    cache_mem 1024 MB
    maximum_object_size_in_memory 256 KB
    maximum_object_size 512 MB
    minimum_object_size 0 KB
    quick_abort_min -1 KB
    cache_replacement_policy heap LFUDA
    memory_replacement_policy heap GDSF
    cache_swap_low 80
    cache_swap_high 85
    ipcache_size 1024
    ipcache_low 90
    ipcache_high 95
    fqdncache_size 1024
    cache_dir aufs /var/spool/squid/1/ 250000 16 256
    refresh_pattern . 15 20% 2280
    dns_nameservers 127.0.0.1
    acl all src 0.0.0.0/0.0.0.0
    acl SSL_ports port 443
    acl Safe_ports port 80 # http
    acl Safe_ports port 21 # ftp
    acl Safe_ports port 443 # https
    acl purge method PURGE
    acl CONNECT method CONNECT
    http_access deny manager
    http_access deny purge
    http_access deny !Safe_ports
    http_access allow localhost
    http_access allow all
    http_reply_access allow all
    icp_access allow all
    refresh_pattern -i \.jpg$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.gif$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.png$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.jpeg$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.bmp$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.tif$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.tiff$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.swf$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.exe$ 0 50% 21600 reload-into-ims
    refresh_pattern -i \.php$ 0 20% 1440 reload-into-ims
    refresh_pattern -i \.html$ 0 20% 1440 reload-into-ims
    refresh_pattern -i \.htm$ 0 20% 1440 reload-into-ims
    refresh_pattern -i \.shtml$ 0 20% 1440 reload-into-ims
    refresh_pattern -i \.shtm$ 0 20% 1440 reload-into-ims
    refresh_pattern . 0 20% 4320
    #Cache windowsupdate ( Faz cache do Windows Update ) ##
    refresh_pattern windowsupdate.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern download.microsoft.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern www.download.microsoft.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern www.microsoft.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern au.download.windowsupdate.com/.*\.(cab|exe|dll|msi) 4320 100% 43200 reload-into-ims
    refresh_pattern download.windowsupdate.com/.*\.(cab|exe|dll|msi) 4320 100% 43200 reload-into-ims
    refresh_pattern http://www.download.windowsupdate.co...b|exe|dll|msi) 4320 100% 43200 reload-into-ims
    #Cache atulizacao avira ( Faz cache do Avira ) ##
    refresh_pattern personal.avira-update.com/.*\.(cab|exe|dll|msi|gz) 10080 100% 43200 reload-into-ims
    #Cache atualizacao symantec
    refresh_pattern liveupdate.symantecliveupdate.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    refresh_pattern symantecliveupdate.com/.*\.(cab|exe|dll|msi) 10080 100% 43200 reload-into-ims
    #Cache avast
    refresh_pattern avast.com/.*\.(vpu|cab|stamp|exe) 10080 100% 43200 reload-into-ims
    ########### Cache Videos ###########
    refresh_pattern -i .flv$ 10080 90% 999999 ignore-no-cache override-expire ignore-private
    acl youtube dstdomain .youtube.com
    cache allow youtube
    #zph_tos_local 0x30
    #zph_tos_peer 0
    #zph_tos_parent off
    #zph_preserve_miss_tos on
    #mime_table /etc/squid/mime.conf
    pid_filename /var/run/proxy.pid
    debug_options ALL,1
    log_fqdn off
    forwarded_for off
    coredump_dir /var/cache/squid
    detect_broken_pconn on
    pipeline_prefetch on
    Gostaria de saber o que posso colocar o reticar dele para melhorar meu cache e ganhar em velocidade e poupar banda
    uso esse scrip em meu provedor de internet !!
    obrigado a todos !
  2. Olá, ao meu ver está bem completa sua configuração,assim que possível vou postar a minha para o amigo comprar.
  1. Cache
    Por l00k no fórum Servidores de Rede
    Último Post: 14-11-2002, 10:44
  2. Atualiizar cache
    Último Post: 11-11-2002, 13:15
  3. Cache do systema de arquivos.
    Por Celio no fórum Servidores de Rede
    Último Post: 16-10-2002, 10:42
  4. Cache
    Por Good_speed no fórum Servidores de Rede
    Último Post: 03-10-2002, 07:15
  5. como limpar o cache do squid?
    Último Post: 17-08-2002, 11:13
