    Question configurar bgp - cisco 2800 series
    Olá.
    Preciso configurar um bgb em um roteador cisco, mas estou com diversas dúvidas:
    A configuração que me foi passada é esta que segue abaixo (devidamente editado por questões de segurança):
    porta: 0/1/0.1/2/4/2:1
    roteador aaaa01.aaa
    ip serial embratel 111.111.111.111 mascara 255.255.255.252
    ip serial cliente 222.222.222.222 mascara 255.255.255.252
    As informações de meu router cisco seguem abaixo (julgo estar informando o necessário, caso precisem de outra informação para me ajudar, basta pedirem
    >show version
    Cisco IOS Software, 2801 Software (C2801-SPSERVICESK9-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2)
    Technical Support: Support and Documentation - Cisco Systems
    Copyright (c) 1986-2010 by Cisco Systems, Inc.
    Compiled Sun 18-Jul-10 03:12 by prod_rel_team
    ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
    Router uptime is 3 hours, 20 minutes
    System returned to ROM by power-on
    System image file is "flash:c2801-spservicesk9-mz.150-1.M3.bin"
    Last reload type: Normal Reload
    This product contains cryptographic features and is subject to United
    States and local country laws governing import, export, transfer and
    use. Delivery of Cisco cryptographic products does not imply
    third-party authority to import, export, distribute or use encryption.
    Importers, exporters, distributors and users are responsible for
    compliance with U.S. and local country laws. By using this product you
    agree to comply with applicable laws and regulations. If you are unable
    to comply with U.S. and local laws, return this product immediately.
    A summary of U.S. laws governing Cisco cryptographic products may be found at:
    Export Compliance Product Report Application
    If you require further assistance please contact us by sending email to
    [email protected].
    Cisco 2801 (revision 6.0) with 357376K/35840K bytes of memory.
    Processor board ID FTX1110Y0DB
    2 FastEthernet interfaces
    1 Serial(sync/async) interface
    DRAM configuration is 64 bits wide with parity disabled.
    191K bytes of NVRAM.
    62720K bytes of ATA CompactFlash (Read/Write)
    License Info:
    License UDI:
    Device# PID SN
    *0 CISCO2801 FTX1110Y0DB
    Configuration register is 0x2102
    Router#show interfaces
    FastEthernet0/0 is up, line protocol is up
    Hardware is Gt96k FE, address is 001b.0c60.f356 (bia 001b.0c60.f356)
    Internet address is 10.0.2.126/24
    MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
    reliability 255/255, txload 1/255, rxload 1/255
    Encapsulation ARPA, loopback not set
    Keepalive set (10 sec)
    Full-duplex, 100Mb/s, 100BaseTX/FX
    ARP type: ARPA, ARP Timeout 04:00:00
    Last input 00:00:00, output 00:00:03, output hang never
    Last clearing of "show interface" counters never
    Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
    Queueing strategy: fifo
    Output queue: 0/40 (size/max)
    5 minute input rate 2000 bits/sec, 5 packets/sec
    5 minute output rate 1000 bits/sec, 1 packets/sec
    59986 packets input, 4311311 bytes
    Received 56929 broadcasts, 0 runts, 0 giants, 0 throttles
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
    0 watchdog
    0 input packets with dribble condition detected
    4685 packets output, 544470 bytes, 0 underruns
    0 output errors, 0 collisions, 4 interface resets
    1059 unknown protocol drops
    0 babbles, 0 late collision, 0 deferred
    0 lost carrier, 0 no carrier
    0 output buffer failures, 0 output buffers swapped out
    FastEthernet0/1 is administratively down, line protocol is down
    Hardware is Gt96k FE, address is 001b.0c60.f357 (bia 001b.0c60.f357)
    Auto-duplex, Auto Speed, 100BaseTX/FX
    Last input never, output never, output hang never
    5 minute input rate 0 bits/sec, 0 packets/sec
    5 minute output rate 0 bits/sec, 0 packets/sec
    0 packets input, 0 bytes
    Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
    0 watchdog
    25 packets output, 1500 bytes, 0 underruns
    0 output errors, 0 collisions, 0 interface resets
    0 unknown protocol drops
    Serial0/3/0 is administratively down, line protocol is down
    Hardware is GT96K Serial
    MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
    Encapsulation HDLC, loopback not set
    Last clearing of "show interface" counters 03:24:03
    0 packets input, 0 bytes, 0 no buffer
    0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
    0 packets output, 0 bytes, 0 underruns
    0 output errors, 0 collisions, 1 interface resets
    0 carrier transitions
    DCD=down DSR=down DTR=down RTS=down CTS=down
    Resumindo: não tenho a mínima idéia se devo ou como configurar o item porta: 0/1/0.1/2/4/2:1 conforme me foram passadas as instruções, em quais interfaces configurar os ip's e se tenho que fazer mais alguma coisa para ativar o bgp.
    Li e estou novamente relendo este material: Open Source Security1osPassosCisco.pdf mas como é a primeira vez que vejo um roteador cisco esta questão do bgp me deixa muito confuso, sem falar que este outro material Cisco IOS Release 12.0 Network Protocols Configuration Guide, Part 1 - Configuring BGP - Cisco Systems para mim está realmente muito complexo, travei logo neste item: Cisco IOS Release 12.0 Network Protocols Configuration Guide, Part 1 - Configuring BGP - Cisco Systems
    Toda ajuda é bem vinda. Obrigado desde já
    Avatar de maxrafa
    Nov 2010
    Rio de Janeiro, Rio de Janeiro, Brazil
    Padrão Re: configurar bgp - cisco 2800 series
    Faz um Curso da Cisco cara, pois BGP é pra quem sabe.
    Pois uma config ruim pode te gerar um dano muito pior.
    Se tiver como usar mikrotik aqui esta o passo a passo com explicações. Vc vai fechar BGP FULL?
    Citação Postado originalmente por maxrafa Ver Post
    Pensei na possibilidade de fazer um curso, porém o custo benefício para mim não compensaria. Pois em anos trabalhando com redes foi a primeira vez em que precisei fazer algo em um roteador Cisco. E não sei quando precisarei fazê-lo novamente, caso pague caro em um curso e não pratique, acabarei por esquecer e ficar desatualizado (na verdade minha área de atuação não é especificamente redes).
    De toda forma, obrigado a quem se disponibilizou em ajudar, acabamos por pagar alguem para fazer as configurações necessárias.
