    Avatar de pagoto
    Feb 2011
    Manaus, Amazonas, Brazil
    Padrão Ajuda com Log de Erro VPN
    Galera, seguinte tenho uma VPN PPTPD no ubuntu, e quando vou conecta-la através de uma maquina WINDOWS
    consigo conectar, e quando mostra "Registrando o computador na Rede", dai eu recebo o seguinte erro: "Erro 629, o computador remoto interrompeu a conexão"
    já no UBUNTU, o log apresentado é esse.
    Jan 5 14:03:29 localserver pptpd[1595]: CTRL: Client 10.3.167.29 control connection started
    Jan 5 14:03:29 localserver pptpd[1595]: CTRL: Starting call (launching pppd, opening GRE)
    Jan 5 14:03:29 localserver pppd[1596]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded.
    Jan 5 14:03:29 localserver pppd[1596]: pppd 2.4.5 started by root, uid 0
    Jan 5 14:03:29 localserver pppd[1596]: Using interface ppp0
    Jan 5 14:03:29 localserver pppd[1596]: Connect: ppp0 <--> /dev/pts/1
    Jan 5 14:03:29 localserver pptpd[1595]: GRE: Bad checksum from pppd.
    Jan 5 14:03:32 localserver pptpd[1595]: CTRL: Ignored a SET LINK INFO packet with real ACCMs!
    Jan 5 14:03:32 localserver pppd[1596]: unknown host * in auth. address list
    Jan 5 14:03:32 localserver pppd[1596]: MPPE 128-bit stateless compression enabled
    Jan 5 14:03:33 localserver pppd[1596]: Peer is not authorized to use remote address 10.3.167.230
    Jan 5 14:03:33 localserver pppd[1596]: Connect time 0.1 minutes.
    Jan 5 14:03:33 localserver pppd[1596]: Sent 104 bytes, received 130 bytes.
    Jan 5 14:03:33 localserver pppd[1596]: MPPE disabled
    Jan 5 14:03:33 localserver pppd[1596]: Modem hangup
    Jan 5 14:03:33 localserver pptpd[1595]: CTRL: Reaping child PPP[1596]
    Jan 5 14:03:33 localserver pppd[1596]: Connection terminated.
    Jan 5 14:03:33 localserver pppd[1596]: Sent 138 bytes, received 262 bytes.
    Jan 5 14:03:33 localserver pppd[1596]: Exit.
    Jan 5 14:03:33 localserver pptpd[1595]: CTRL: Client 10.3.167.29 control connection finished
    ALGUEM PELO AMOR DE DEUS CONSEGUE ME AJUDAR?
    Padrão Re: Ajuda com Log de Erro VPN
    Bom dia
    Vamos fazer um teste
    vi /etc/ppp/options
    Colocar esta linha
    noauth
    Avatar de pagoto
    Feb 2011
    Olá amigo consegui resolver! parei para analisar o LOG detalhe por detalhe
    e o erro era o seguinte
    No arquivo CHAP-SECRETS, eu coloquei os " * "sem aspas para permitir conexão de qualquer IP.
    no arquivo /etc/pptpd.conf eu coloquei ao final do arquivo assim: noaccomp
    não sei pra que serve, mais vi em um forum e funcionou!
    Agora a duvida que ficou é, se consigo pingar por HOSTNAME?
    tenho um servidor WINS, mas mesmo assim não consigo pingar por hostname, somente por IP ... tem alguma dica?
    simplismente mudei isso e conectou na hora
    Boa tarde
    Seguinte, qual servidor de DNS você esta usando, preferencial, tem que ver pra resolver nomes dos Hosts internos.
    Se forem maquinas linux que não estão resolvendo os nomes, entre no arquivos
    $sudo vim /etc/hosts
    e adiciona ip e nome
    127.0.0.1 localhost
    192.168.10.1 svrwins
    Avatar de pagoto
    Feb 2011
    Cara, você é um genio!
    Muito Muito obrigado.
    Deu tudo certo!
    Bom dia
    Blz cara.....abraço
