    Padrão Saiu a nova versão airos 5.5
    Olá amigos,
    saiu a nova versão airos 5.5, não baixei ainda, mas vi que tem algumas novidades, como poder usar canalização de 3 e 8 mhz na linha m900.
    Também na linha m2/m5 a possibilidade de canalização de 8 e 30 mhz,
    vamos atualizar e ver as novas funcionalidades!
    Padrão Re: Saiu a nova versão airos 5.5
    opa ja to testando....
    May 2010
    Carapicuíba, Brazil, Brazil
    hummmmm
    interressante e por causa do airfiber ,compatibilidade .
    As Novidades.
    AirOS V Firmware Revision History====================================================================Supported products * Bullet M, Titanium * Rocket M * NanoStation M * AirGrid M / AirGrid HP M * NanoBridge M * PowerBridge M * PicoStation M * NanoStation Loco M * AirRouter * PowerAP N * Rocket M365 * Rocket M900 * NanoStation M365 * NanoStation Loco M900 * NanoBridge M365 * NanoBridge M900 * NanoBridge M3 * PowerBridge M10====================================================================Version 5.5 - Final Release (April 10, 2012)--------------------------------------------New product support:- New: Bullet M2 Titanium- New: Bullet M5 TitaniumNew functionality:- New: Management VLAN support- New: Advanced network settings configuration mode- New: RADIUS MAC authentication- New: Low TX power mode support for all M series models- New: AirMax client support for 802.11 a/b/g products- New: DHCP relay functionality in Router/SOHO Router mode- New: UPnP server support in Router/SOHO Router modes- New: Ability to Block WAN Access in SOHO Router mode- New: Fallback IP for PPPoE client- New: 3/8 MHz channel width support for M900- New: 8/30 MHz channel width support for M2/M5- New: 8/25 MHz channel width support for M3- New: 25 MHz channel width support for M365- New: Full range of channel width options in Compliance mode- New: Max allowed MTU size for newer HW revision models is 2024 bytes- New: Make Device name the Product Model by default- New: Separate throughput graphs for LAN0/LAN1 interfaces- New: Option to create support info file with ping watchdog before device reboot- New: Enable/Disable CDP option in Device Discovery section- New: Check for existing uploaded firmware image when opening System page- New: Prepare for IPv6 support- New: Traffic shaper for ingress traffic- New: Notification for software updates- New: Add PPPoE service name configuration- New: Kernel patches for SIP conntrack/NAT support- New: Show AirMax priority in Main page for Station modeFixes:- Fix: Configuration change causes device with a long uptime to lock up- Fix: Device stops passing traffic after some time and requires a reboot or "kick" to work again- Fix: Dynamic DNS update after PPPoE session initialization- Fix: Station list is empty when there are few stations associated- Fix: Port ID is mandatory in CDP packet- Fix: STA-WDS in bridge mode is passing back multicast/broadcast packets- Fix: "Antenna Gain" and "Cable Loss" fields are locked for LocoM900 with external antenna- Fix: Incorrect connection time reporting- Fix: Timestamps reset because of stuck beacon. Causes other manufacturers' (i.e. Tranzeo) devices to re-associate.- Fix: Can't launch airView with HTTPS enabled on IE8- Fix: Traceroute fails to DNS host with multiple addressesImprovements/Change requests:- Improvement: Linux kernel update to 2.6.32 version- Improvement: AirMax performance in large PtMP networks- Improvement: AirSync performance in PtMP networks- Improvement: ACL List: Dynamic list now allows instant changes (no restart or dropped connections required)- Improvement: ACL List: MAC list limit increased from 64 to unlimited- Improvement: ACL List: Ability to add comments to MACs- Improvement: ACL List: Ability to enable/disable a MAC without removing it from the list- Improvement: DFS functionality improvement according FCC/ETSI requirements- Improvement: Report Horizontal / Vertical antenna instead of "Chain 0 / Chain 1"- Improvement: New look for wireless mode configuration- Improvement: Various WEB GUI tweaks, changes, improvements- Improvement: Send NASID in Access-Request packet.- Improvement: Add internal speed test tool to DMZ exemption ports- Improvement: Hide Discovery Tool for read-only account - Improvement: Extension for Port Forward configuration. Allow to specify Public IPRegional Updates:- New: Initial Login page with Country/Language selection- New: Replace Obey Regulatory rules with Auto Adjust to EIRP Limit functionality- New: Remove possibility to change country for some countries (USA, Spain)- New: Remove indoor range for Brazil (5.1-5.3GHz frequencies)- New: Show Band C for UK Frequencies- New: Add Iraq country code- New: Add Nigeria country code- New: EIRP limits for US Regdomain on 2.4GHz and 5.8GHz band- New: Add German translation- Fix: Regulatory rules update for Australia- Fix: Devices with selected country Ukraine doesn't work in 5GHz bandAdditional Notes:- Note: SNMP interface indexes have changed with v5.5 due to advanced network configuration options- Note: AirControl v1 Configuration changes are not supported with v5.5 firmware- Note: Possible Web UI issues with out of date browsers (i.e. Firefox 3.6). It's recommended to use current browser software
    Alguem possui um tutorial, de ajuste fino do airos 5.5?
    Qual o melhor seria o canal adaquado, e potencia que a galera usa.
    Aqui esta assim eu estou comentendo algum erro?
    5765
    20 Mhz
    15 Dbm
    Não consegui usar canal diferente do 5.7xx.. dou um site survey só acha rede que está no canal 5.7xx., voltando para versão 5.3.5 acha todas...
    Já atualizei. Mas só funciona no canal 5.7...
